echo star "480w".just when you thought you had seen it all...
  • Krankshaft
    • Jan 2007
    • 2328
    Re: echo star "480w".just when you thought you had seen it all...
    While browsing MPJA a site I frequent for electronic odds and ends I found another Echostar before I read this post.
    http://www.mpja.com/prodinfo.asp?number=17714+PS
    It gave me an odd feeling and I thought it was crap especially with the cheap label on it. They claim this one is 600 watts . They're gonna need bigger weights .
    I'm sure the fan is loud as hell too just like ALL dirt cheap supplies.
    • KeriJane
      Mac Enthusiast
      • Sep 2008
      • 681
      "Echo Star"
      Does that mean it goes "BOOM" loud enough to echo?
      Have Fun!
      Keri
      PS> DUCK!
      The More You Learn The Less You Know!
      • RJARRRPCGP
        • Jul 2004
        • 6304
        lol
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Hey wait:
          I had an Echo Star 580 watt that kicked butt on an Antec TP2-550.
          It had Teapo and Cheng capacitors as I recall.
          Was a feather-light gutless wonder but at least it ran.
          Nah, the echo is from hitting the side of the junk box on the other side of the room.
          Mann-Made Global Warming.
          - Dr Seuss
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            The star is 2 points for actually getting it in the box.
            - Dr Seuss
            • Gianni
              • Jul 2008
              • 681
              • Italy
              #26
              What feeling do you have thinking they produce also a 680W unit?
              Gianni
              "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
              H. J. Brown
              • 370forlife
                Large Marge
                • Aug 2008
                • 3113
                Was a little heavy in the +5v there, sounds like its more designed for a old athlon or pentium 3 system. probalby all use the same pcb board.
                • RJARRRPCGP
                  • Jul 2004
                  • 6304
                  That means it would be suited for an Asus A7N8X.
                  And NOT for an Athlon 64.
                  And NOT for an Abit NF7.
                  And NOT for an LGA 775!
                  In addition, some LGA 775 motherboards require the 8-pin connector!
                  The Asus P5QL Pro don't require any 8-pin.
                  Thus, there's a good chance that it's gonna be incompatible, even if the PSU turns out to be a fine PSU.
                  In addition, it may not even have a 24-pin ATX connector!
                  Arc A770 16 GB
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    From looking at the ones I had they are still using the old old ATX PCB layouts.
                    Might be okay for an old P3/P2 (or ATX Socket 7). - Except.
                    I checked them and the voltages were all over the place.
                    Some high, some low.
                    Didn't wanna mess with it.. -- Hook Shot!
                    - Dr Seuss
                    • UraBahn
                      Scrapheap Hound
                      • Nov 2004
                      • 165
                      Gluing chunks of (what appears to be) iron to the PSU case to add weight to a gutless wonder is truly shameful.
                      They could at least have used a heavier (as in made using heavier plastic) fan.
                      Funny thing is, I never had a gutless wonder go pow on me (knock on wood.) I've seen several that DID go pow, though, including one whose Fuhjyuhuhyyhuyuji's went south, sending a number of undersized support components to kingdom come. Client brought it in claiming that the fan was dead. Ironically, the fan was just about the only thing that was still working in that mess.
                      The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
                      I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
                      • Wizard
                        • Mar 2008
                        • 2296
                        #31
                        Marginal design PSUs will POW regardless if pulling enough current. Several good PSU reviewers have load cell equipment that can pull specific loads to determine how good PSU can hold up all the way to torture levels (around 80% or so in hot box).
                        Cheers, Wizard
                        • kc8adu
                          • Nov 2003
                          • 8832
                          • U.S.A!
                          #32
                          hey i just figured out what the 480w rating is!
                          output 480w worth of heat as it blows up!
                          • gustie
                            • Dec 2008
                            • 76
                            #33
                            Originally posted by jpdoe
                            priceless!
                            or worthless?
                            DFI Lanparty NF2 Ultra B
                            TICTAC 619XT Bios
                            AMD Athlon XP-M 2600+ FQQ4C IDYHA I-Stepping
                            Speeze Vulture spin 3 Heatsink and Fan
                            2x Mushkin XP4000 1024m DDR500 (1:1) @ 2.5-3-2-8 1T
                            GeForce FX 5700 256m
                            Zalman VF900 CU GPU cooler
                            Skyhawk 400W Aluminium psu
                            Sharkoon Silent Eagle 1000 case fans
                            • mr.infamous
                              • Apr 2009
                              #34
                              Got the 680w with a bundled rig I bought off of ebay. Ive had it one month and the ps blew to knigdom come this morning. I had it on a DFI LP 790fx w/ a Phenom ii x4 920. I hope I can salvage everything. Ive never seen transistors and diodes scatter across a room before. If this is all you have money to buy, save yourself the heartache, and go to the library or a cafe. What a mess.
                              • Toasty
                                • Jul 2007
                                • 4171
                                #35
                                >>Ive never seen transistors and diodes scatter across a room before.<<
                                You should have been in my tech school electronics class...
                                Question: How many capacitors can you fit into an 8 foot outlet strip?
                                veritas odium parit
                                • kc8adu
                                  • Nov 2003
                                  • 8832
                                  • U.S.A!
                                  #36
                                  several in each outlet.extra credit for using caps with no vents.
                                  a real powmax power strip.
                                  • Krankshaft
                                    • Jan 2007
                                    • 2328
                                    About a year ago I took an outlet strip outside and put an old selenium rectifier in there to see what this horrible stink smelled like ugh I won't do that again .
                                    • Toasty
                                      • Jul 2007
                                      • 4171
                                      #38
                                      >>About a year ago I took an outlet strip outside and put an old selenium rectifier in there to see what this horrible stink smelled like ugh I won't do that again .<<
                                      You do understand that gas is toxic, correct? Hydrogen selenide. A cousin to hydrogen sulphide (rotten egg) gas.
                                      Never bothered me though...
                                      >>several in each outlet.<<
                                      Close. You're on the right track, however.
                                      >>extra credit for using caps with no vents<<
                                      We didn't have vents them back then... Every one was a tiny missile!
                                      Okay, back on topic. Noticed the lack of UL certification... I wonder why...
                                      LOL!
                                      veritas odium parit
                                      • Krankshaft
                                        • Jan 2007
                                        • 2328
                                        Yeah I won't be doing that again the stench was nasty I can only imagine it going up in someones room .
                                        Well lead and rosin fumes are toxic too but I don't spend my time breathing the concentrated vapors.
                                        It's wierd if they defrauded their customers with dummy weights why not stamp the UL logo on there?
                                        They couldn't do anything to shock me after the weights.
                                        • kc8adu
                                          • Nov 2003
                                          • 8832
                                          • U.S.A!
                                          #40
                                          http://www.powsun.com/pcpower_8868two.htm
                                          might have found the oem?
                                            HP 260 G2 Desktop Mini PC (ENERGY STAR) 4405U Specification for Upgrade or Repair
                                            This specification for the HP 260 G2 Desktop Mini PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the 260 G2 Desktop Mini PC (ENERGY STAR) boardview and 260 G2 Desktop Mini PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            09-12-2024, 03:44 PM
                                            HP Z240 Tower Workstation (ENERGY STAR) i7-6700K Specification for Upgrade or Repair
                                            This specification for the HP Z240 Tower Workstation (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Z240 Tower Workstation (ENERGY STAR) boardview and Z240 Tower Workstation (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no...
                                            HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) Slimline i5-6400T Specification for Upgrade or Repair
                                            This specification for the HP Slimline Slimline Desktop - 260-p025il (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slimline Slimline Desktop - 260-p025il (ENERGY STAR) boardview and Slimline Slimline Desktop - 260-p025il (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant...
                                            HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                                            This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            HP ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) ProDesk 400 i5-6500 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) boardview and ProDesk ProDesk 400 G3 Microtower PC (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
