Mitsubishi Melservo MR-J2S-100A alarm: AL.E9
  • Per Hansson
    replied
    Re: Mitsubishi Melservo MR-J2S-100A alarm: AL.E9
    Exactly correct!
    I even bought it at the local food market
  • ChaosLegionnaire
    replied
    nice... u used acetic acid? isnt that whats in vinegar?
  • Per Hansson
    replied
    Nice to see so many new members in this thread, welcome to Badcaps!
    On that theme I present you the latest repair:
    I was hoping for it to be an "easy" fix but for the first time was greeted with leaking SMD capacitors in this servo!
    The electrolyte had started attacking the through hole vias and crystalline formations had formed on the negative legs.
    I used acetic acid and it worked a treat, I did not photograph the acids process in the first two caps but after what I saw was ready on the next couple.
    I made this little GIF showing the action, the board turned out great after the cleanup thankfully!
    P.S: I attached several high resolution photos of the before/after process as well, oh, and the SMD caps measured around 80 to 140 in ESR!
    replied
    Originally posted by macona
    I also had this same issue with my MR-J2S-100A on my cnc mill Y axis. Replaced that opto today and she is alive again. Thanks for posting all this!
    If this is a drive that is over 10 years old I would highly recommend that you recap the switching power supply board at a minimum and also recommend that any capacitor under 100uf replace them
    replied
    ( these Servo drives are a pain in the ass to repair )
    I have tried in the past to repair Servo drives that have a low buss voltage with limited success on some models it just replace all of the small value capacitor and that seems to fix the issue but not always the case
    I have even replaced an IGBT module on one and never figured out what the problem was
    With over current error message I have been more successful repairing this kind of fault
    I have even repaired Servo drives that have priority controller boards this is even more channeling because if the controller board has issues it basically unrepairable but ( if the controller board still working) if you can find the same exact model then use the replacement drive with the original controller board and this dose work I have done this a few times before
  • macona
    replied
    Oh, and I thought I should add it does seem temp related, it was not until the shop got cold that this issue cropped up.
  • macona
    replied
  • bench22
    replied
    Thanks! also fixed my servo with alarm 9.
  • fazal kareem
    replied
    IF Driver Shows
    AL.E9 change ic chip 7800 80% solved
    AL.24 change module 50% solved
    but
    AL.30 ?
    AL.17 ?
  • jae2020
    replied
    Hi, these two caps came from a unit that otherwise is full of Nichicon caps:
    Nichicon GQ, GU & PJ manufactured late 2001.
    Got any idea what model they are? (See picture).
    The 33uF cap has an ESR of 40 so it's in dire need of replacement
    I could get it down to ca 5 by heating it with my iron, then matching the other cap...
    I ordered the "A" version of the 7800 optocoupler linked above from Mouser, actually it was the only one in stock.
    It worked a treat, the bus voltage reading is now correct
    Thanks. I solved alarm E9 after replacing this IC.
  • Per Hansson
    replied
    The bus voltage depends on the incoming AC voltage.
    If you measure 200VAC input then 280VDC bus voltage is normal.
    Calculation: √2 x 200VAC = 282.8VDC.
    If not and you believe you have a heat sensitive component then heat it up with a heatgun carefully and see if the voltage changes.
    Or cool it down and see if the voltage changes.
    This is the way I used to pinpoint that it was component O15 the HCPL-7800 that was the culprit as described here.
    And yes, the servo might be sensitive to the value of the capacitor, especially capacitor C6.
  • Alex-Signals
    replied
    hi, I made the change of the caps, and the HCPL7800A, in the DC BUS marks me an output of 280 vcd, the equipment was already installed in the machine and I am still working.
    Since I don't have 33uf caps, install some 47uf caps. they believe that for this reason I am giving a bus voltage of 280 vcd, the caps I use are low ESR
    replied
    When I have done these drive before I have given them a recap and change the switching regulator ic chip and now when I do another one of these drive I will change the optic sensor and the surface mount capacitor as well
    After reading your post
  • Leopard
    replied
    Hi, the ones I've seen have shown AL.E9 as first & only error AFAIK.
    I work as a service technician, so I get called whenever the customers can't get the machines working again...
    So far I've repaired quite a few of these and had 100% success so far, and no returns...
    Actually I'm near Tampere sometimes for customers too (actually in Lempäälä) but not right now.
    Thanks for the response. Nice to hear that the failure mode has been consistent.
    We've luckily had spare units for the ones that have been acting up, but apparently this model is outdated and hard to get nowadays.
    I'll order some optocouplers and will see if these can be brought back to life.
    replied
    Thank you for this posting I also repair servo drives I have had switching power supply problems from bad capacitor to bad switching regulator IC chips but have not yet seen this problem
    Thanks again for sharing this post
  • Per Hansson
    replied
  • Leopard
    replied
    Hi Per,
    Sorry about the thread necro, but anyway:
    We are slowly starting to get failures of these Melservo units at work.
    What were the initial error codes & symptoms?
    We have two units which show AL.33 (overvoltage) and two units which had a hard time getting to a working state, initially showing AL.16 or AL.E9. Once they warmed up, they would work normally, but this took longer and longer as months passed.
  • Per Hansson
    replied
    Yea, in this case that's not really possible though.
    The HCPL-7800 is not driven directly, as I mentioned it's a digital device with a DAC on both sides.
    The advantages is that it's a very well behaved device.
    It would still be possible to misuse it though, the DAC on each side requires a 5v supply, it's derived in this implementation from a 17v supply i think, with a zener diode to get it down to 5v.
    But then the sense pins should ideally be driven with max +/- 200mV, it can operate up to +/- 2v but with reduced accuracy.
    In not sure if the problem is there maybe: I could see how an overvoltage during motor breaking would increase the bus voltage for example...
    replied
    opto failure used to be common, specially in philips tv's
    people used to overdrive the led and the output dropped over time.
  • Per Hansson
    replied
    Yea Behemot it's a bit interesting failure mode.
    Maybe it's being driven too hard or improperly in this implementation.
    But due to where it's mounted it's not really very easy to test that.
    And if it lasts another 15 years I'm happy
    Of course a photocoupler has both a LED that will degrade, and also a phototransistor that will degrade.
    The correlation is described in this article, that said I think a high-end device like this:
    Which has a DAC on both the primary and secondary side will behave extremely well over it's lifetime.
    So the failure could be caused by something different all together.
    As a fun test I wired it up to 5v, and used simply the diode test mode on a meter to send it a signal.
    I watched the output on a scope: it was a nice well-behaved waveform.
    Then I heated it up and the waveform only became smaller, not distorted in any way.
    So it's really a quite linear failure mode, at least it makes the troubleshooting much more convenient
    Oh, and the second servo is now completed and seems to behave equally well too
  • DrewPhillips
    Capacitor Diarrhea - Nichicon PL Series
    by DrewPhillips
    Hello All, I have on the bench a couple of PSU's which have some failed Nichicon PL series caps. They didn't "puke" their guts through the top, but instead "diarrhea'ed" corrosive brown electrolyte through the bottom, down the legs and onto the board. On one cap, the electrolyte rotted the cap right off the board leaving 2 little stubs, and also corroded a trace on the foil side.
    The PSU's are Power-One MAP series and are ringing-choke topology. The semiconductors have date codes in 1993. The PSU's were used in a commercial application, fan-cooled. They had failed...
    03-02-2025, 10:18 PM
  • Tom41
    Honeywell Accenta G3 tamper alarm
    by Tom41
    This house has a Honeywell Accenta G3 alarm system. If the main unit loses power for any reason, the external siren sounds - even if the alarm is not even armed! Entering the code to disarm it is not an option as the keypads are completely dead when the power is out.
    I presume this means the backup battery inside the box has failed, but I can't get in there and replace it without also setting off a tamper alarm! Is there any way to disable the tamper alarm so that electrical work can be carried out with the power off? Or a way to replace the backup battery without setting off the...
    08-31-2023, 04:00 AM
  • nick3092
    Mid/late 80's Nichicon Yellow Caps
    by nick3092
    I recently acquired a set of Bose Roomate speakers from the mid to late 80's. Basically the right speaker cabinet is completely passive, and the left one has the power transformer and amplifier circuit in it. Out of curiosity, I opened it up to see what the circuit looked like. Looks like they used all Nichicon VX (2x 4700uF/16v for smoothing off the bridge rectifier), a couple random Nichicon SE series sprinkled on the board, and what really caught my eye - 2 yellow sleeved Nichicon caps (both 1uF/50v with no real series marking. Below are pictures of the caps. The only thing not shown in these...
    08-28-2022, 03:56 PM
  • slybunda
    Alarm Siren issue
    by slybunda
    Apologies if this is in the wrong section but being a car alarm siren that makes noise i thought it be best to put it in the audio section.
    Had weird alarm issues where siren made a strange noise: https://www.youtube.com/watch?v=ZjsqndhionU
    took siren out of the car and checked it out and pics attached seem to be the source of the issue.
    shockingly the alarm still makes its normal sound if i trigger it manually so speaker seems to be intact.
    getting a replacement is gonna be next to impossible, its a Toad Ai606 which is no longer in production and cant see to find a replacement...
    02-04-2024, 11:01 AM
  • Ady2017
    Does anyone know about 16x2 LCD screens used in alarm keypads?
    by Ady2017
    I have got an old Gardtec GT595 alarm which has got a faulty keypad with a failed LCD screen. This was apparently a very common problem with these and many people have had to replace the whole alarm because of this problem. Somebody claims to be able to repair the keypads by replacing the screen and I have tried it myself by replacing the LCD with a commonly available HD44780 1602 16x2 Serial LCD screen but it is not working. I am sure it is a problem with a driver or simular which is not allowing the screen to talk to the rest of the electronics. Does anyone know what this original screen was...
    06-02-2025, 04:56 PM
