Re: Linear regulator question
"Now, question: you say a transistor should read around 0.7V between the emitter and base ? Why ? Does the datasheet tell you something I'm not seeing ?"
This where you need to know what the device is on how it basic function is.
https://cdn.badcaps-static.com/pdfs/...102e6e50a7.pdf
http://www.learningaboutelectronics....f-a-transistor
Use you DMM in Diode mode and see what the reading on the B-E (forward bias) of the Transistor shows (you are reading the junction Voltage).
Don't have the patience to read anything right now...will check it out someday maybe - my head kinda spins
