Shunt regulator question (not sure if posting it in the right place)
  • Dannyx
    CertifiedAxhole
    • Aug 2016
    • 3912
    Good day folks. Got a little question I'd like some help with. I know how a shunt regulator operates and what it does, but I can't understand something in a schematic I came across. Have a look at the two that I've posted: the first one is the original example. It's a transistor shunt which means the extra current is "shunted" through the transistor to ground with respect to the zener diode's value. To prevent a short circuit through the transistor when it switches on, there's a resistor R in series with the load and the collector of the transistor - I get that and it makes perfect sense. This brings me to my actual question: why is that resistor R not placed in series with just the C-E junction of the transistor, but instead it's in series with the load as well ? Have a look at my redrawn version and please tell me if there's a problem with doing it like that. What would happen then ? Cheers
    Wattevah...
  • R_J
    • Jun 2012
    • 9594
    Re: Shunt regulator question (not sure if posting it in the right place)
    The voltage is being dropped accross the resistor and then regulated, in your diagram all that will happen is you heat up the resistor. the voltage in is exactly the same as the voltage out.
      Vout = Vin = Vz+Vbe +Vre, when V supply goes up (so as Vout) so transistor conducts more, then Vre will Increase due to more current, it is not doing anything to regulate the output, the output Voltage is the same as the input Voltage, it is just a load (common Collector/ Emitter follower).
      "To prevent a short circuit through the transistor when it switches on, there's a resistor R in series with the load and the collector of the transistor" That is not the purpose of that resistor, that resistor serves the same function as used in shunt regulator using Zener Diode.
      Think of it this way, you have power source and you put the variable resistor across the output (same as using the circuit in number 2), as you vary the resistance, do you think the output Voltage will change much (as long as the power supply can supply the needed current to the load)? Try hooking up 1K resistor to the 1.5V battery and then try 500 Ohms, do you see much change in Voltage?
      Best is to build the circuit and see the result and you will be able to take measurement.
      The shunt regulator works on the ratio of the Vdrops of the series resistor connected to the load and the shunt element/load.
      As the Voltage goes up, then you will have more Vdrops on the series resistor and constant Vdrops on the shunt element/load to maintain constant output Voltage.
      http://www.circuitstoday.com/voltage-regulators
      • Longbow
        • Jun 2011
        • 623
        Drawing #2 is not a regulator. There is no voltage regulation in that arrangement because the transistor/resistor combination is simply a load on the power supply rails. Somebody got confused.
        Is it plugged in?
        • redwire
          • Dec 2010
          • 3912
          The resistor should have been in series on the base, not the emitter. It is to protect the zener and E-B junction from getting over-current if the shunt transistor is overloaded or overheated. The zener and E-B junction alone will act as a shunt reg.
          ASC solar charge controllers use a shunt reg. Basically when the battery is charged up, it just makes heat shunting away the excess solar panel voltage. Primitive but it works and guaranteed to initiate charging on a dead battery, unlike crappy Morningstar solar charge controllers.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            You mean like this ?
            Wattevah...
            • Longbow
              • Jun 2011
              • 623
              I doubt if either of these circuits would survive if you tried them out. The best plan is to discard them and substitute actual regulator circuits with parts values. Otherwise we are all just speculating.
              Is it plugged in?
              • srhofmann
                • Aug 2016
                • 135
                • usa
                Not to hijack the thread, but since we're talking analog voltage regulation, why does this supply have series resistance, R2-R5, on the output of the final power transistors?
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  True, it was just an empirical example, since I'm not too familiar with exact part numbers sadly - there are millions of transistors out there...
                  Wattevah...
                  • Dannyx
                    CertifiedAxhole
                    • Aug 2016
                    • 3912
                    As far as I know, when transistors are used in parallel, a series resistor on each of them is required to balance the load, otherwise one would do all the work. I faced this issue myself when I built a (badly designed) power supply.
                    Wattevah...
                      That is just a simple linear regulator circuit, Vout = Vz- Vbe.
                        Those resistors on the Emitter are used to balance out those output transistors.
                        http://education.lenardaudio.com/en/12_amps_5.html
                        • srhofmann
                          • Aug 2016
                          • 135
                          • usa
                          Thanks to budm and Dannyx. I had done some google searching put hadn't tried parallel output transistors. I found a good explanation of how the resistors balance the outputs of the transistors at
                          https://www.allaboutcircuits.com/tex...-4/bjt-quirks/
                          • jinu_j
                            by jinu_j
                            Hi
                            05-03-2025, 10:51 PM
                            ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
                            Optimized Multi-Phase PWM Controller
                            with 6-Bit DAC for VR10.X Application
                            The ISL6556A controls microprocessor core voltage
                            regulation by driving up to 4 synchronous-rectified buck
                            channels in parallel. Multi-phase buck converter architecture
                            uses interleaved timing to multiply channel ripple frequency
                            and reduce input and output ripple currents. Lower ripple
                            results in fewer components, lower component cost, reduced
                            power dissipation, and smaller implementation...
                            11-05-2024, 03:10 PM
                          • MidnightRoller
                            Can a resistor lose resistance after hot air?
                            by MidnightRoller
                            I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                            I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                            02-02-2022, 11:46 PM
                          • artvandalai
                            What resistor ohm will work better to repair this waterpik?
                            by artvandalai
                            The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                            01-05-2025, 04:10 PM
                          • bimole
                            Weird behavior on 3.3V rail of a CORSAIR CX600
                            by bimole
                            A colleague gave me an apparently ill CORSAIR CX600.
                            He told me that he heard a banging noise, and smelt the magic smoke.
                            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
                            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
                            It's another story on the 3.3V rail...
                            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
                            02-13-2025, 04:49 AM
