Hey guys, this year I'm doing my own eBay store so I've contacted a lot of manufacturers of various products.
I found this one and they make some really decent shit and have a good reputation. They make a very simple replacement power supplies that will be fine for most applications. The two pictures below are of a 24v, 2.5A power supply. I tested it by putting it under 3A of load, voltage drop wasn't too bad, and it didn't even get that warm. Under rated load it performed beautifully with 0 hiccups whatsoever and perfect voltage.
The caps used are KYS branded and LScon branded. I've not seen LScon before, I've seen KYS in a LOT of logitech products, never had a problem with them so I'm okay with that. The LScons I've never seen, but they seem to do okay? They both test perfectly (there are two, one is 100uF 400V, the other 50V 10uF) Who knows, time will tell.
Main mosfet is a MagnaChip MDF7N60B 600V 7A rated, I'm definitely okay with that. Rectifier is a KBP206, 1000V 2A. for something that's not even gonna draw an amp, I'm impressed so far as to how overkill a lot of these parts are. The output rectifier is a Diodes Incorporated MBR20100C, it's a schottky rectifier rated 100V peak/working, 10A. I'm impressed with this little shit. For being rated so low, it's got a lot more beef in it than is necessary. I know my 4A 24v power supply has a 100uF primary and the same amount of output filtering.
As far a as safety goes, this thing packs a massive isolation isolation gap, and loads of white glue which was very hard to remove over all of the components. Capacitors, wires, and the PCB and transformer were all glued to the case. This thing was definitely made with quality in mind.
This does pass CE, RoHS, and FCC certifications, as do all of their products. The lack of input filtering sucks, but that's only because this is meant for being a basic power supply, not for a laptop. The laptop ones have filtering if I am not mistaken. Also for those complaining about the lack of output filtering, there is a coil in the cable itself, oldschool style, no inductors on the PCB.
Forgot to mention, there is shielding on the inside of the case it came in, that's how it passes FCC standards.
Also, the damage to the PCB was done by me and a chisel trying to get this infernal thing open. It took so long to open it, I was impressed by the case thickness.
Now, the real kicker is the price of these things, 2.47$ USD each. Price gets lower with higher quantities. After shipping it'll be a little bit more, but it's worth it. I should be able to sell these for around 7-10$ usd, and know they're not going to fucking kill someone from a shitty solder joint or faulty transformer.
If there is anything I am missing, or am not noticing, please inform me. I want to sell decent products, not the best out there. Just want to try and launch this business off the ground and see what happens.
