6.3V caps on 5V rail - not recommended?
  • espresso
    • Aug 2008
    • 24
    • Serbia
    Would it be safe to put 6.3V capacitors on 5V rails in PC power supplies?
    I read somewhere that in PC supplies one should use 10V caps on 5V rails.
    And for example, National Semiconductor's datasheet for switching regulators states:
    The capacitor's voltage rating should be at least 1.5 times greater than the output voltage.
    Are there any voltage spikes that can harm the capacitors in the long run?
    I bought some FM Panasonics to replace the existing caps but they are 6.3V rated unlike the original ones which are 10V.
    Also, Panasonics have much lower esr than the caps I used before so I hope replacing won't cause instability.
  • acstech
    GrumpyModerator
    • Jul 2007
    • 1432
    Re: 6.3V caps on 5V rail - not recommended?
    As long as they're quality caps I wouldn't worry about putting 6.3v caps on a 5v rail. Panasonic FM is a quality cap, so I wouldn't worry about it.
    A man convinced against his will is of the same opinion still.
      by momaka
      03-15-2023, 10:17 PM
      by momaka
      03-12-2025, 03:42 PM
      Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
      by momaka
      This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
      Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
      Macron Power Technology Co. LTD.
      Let’s look at the PSU itself.
      The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
      06-02-2021, 10:05 PM
      no-name Radeon 9600 XT recap and cooler
      by momaka
      I've been seeing a lot of cheap-looking (but not always so cheap) no-name AGP video cards on eBay for a while. They started popping up quite a bit when the market for AGP cards became more alive all of a sudden due to interest in “retro” PCs. One thing that struck me about these cheapo cards is that they almost always seem to come with garbage caps - including the abominable Sacon FZ. That aside, though, I've been wondering about the rest of the quality (or lack of?) on these cards. So I decided to satisfy my curiosity yet again.
      This one was actually suggested to me by ChaosLegionnaire....
      11-06-2020, 07:54 PM
    • SarcasticOP
      General question about MacBook power rails for repair.
      by SarcasticOP
      I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
      • PPBUS_G3H (12.6V-12.8V)
        • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
      • PP3V42_G3H (3.42V)
        • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
      • PPVRTC_G3H (3.3V)
        • This
      12-12-2024, 05:50 PM
