Re: JVC THS9 Home Cinema System SMPS No outputs or standby power
IC901 STR-G6651 Pin 5 (OCP/FB) is terminated to the primary circuit GND through R906 (680 Ohms) in series with the SOURCE current sensing resistor R907 (0.47 Ohms). Very low resistance compared to the 940K (TWO 470K resistors in series), so you are going to get much Voltage on pin 5.
You will get more Voltage at FB when Opto PC901/902 are active.
Feedback Threshold Voltage VFDBK Drain waveform low to high1 0.68V(min) 0.73 (typ.) 0.78 V (max)
I would directly replace IC 901 if all the surrounding cap, diodes and resistors are checked OK. Look at Q991, Opto-Isolators PC-901 and 2. And yes Zener diode ZD 991, too.Leave a comment:
budm: Sorry about the photo, I did another I hope it is OK.Leave a comment:
Jiroy: Yes, and have also taken test of resistor values as Capleaker suggested with one leg removed from board, it certainly does not make sense to me!Leave a comment:
I really dont get it how R910 and R911 are in series and there is only 0.225 vdc . on R911 while R910 gets 160 vdc . both are mentioned for 750k. One could assume R911 open . Are those tests accurate ? .Leave a comment:
Capleaker: Mistake yes Pin 4 Vin, pins 1-2 open 1-3 open 2 to 3 shorted.Leave a comment:
Wrong pin. Vcc is on pin 4.
The spec sheet sez:
On-State Voltage: min 14.4V, typ 16V, max 17.6V
So lets say if pin 4 had only 13.18V, it would probably not turn on. as turn off would be max 11V and the IC has under voltage lockout.
See if pin 1, 2 and 3 are shorted?Leave a comment:
https://www.badcaps.net/forum/attach...4&d=1485790567
Can you please provide focused picture?Leave a comment:
Thank you all for your help so far....
Capleaker: Measurements as follows R910= 465k, R911= 466k, R905= 67.5k.
Shall I resoldered them back in as within spec?
The IC901 has 13.18vdc to pin 1, data sheet states on state voltage between 14.4-17.6vdc.
So appears that voltage is too low, but why?
STR-G6651 data sheet uploaded.
budm:
Pictures of PCB top/bottom uploaded.
Owned from new, not used much, but just started using more now that 5.1 surround is being broadcast here on some programmes, we power it off/on as we use it, never use standby mode in the interest of energy saving.
Redwire: Thanks for the headsup..
PercyLeave a comment:
Wait a sec... Make sure there is no charge on C907, measure it with a multimeter before messing with R910, r911. I think these two resistors are also bleeder resistors for C907. In any event, it is always good practice to make sure the primary filter cap is discharged before soldering etc. near it.Leave a comment:
Can we see the pictures of what we are dealing with?
History of the unit?Leave a comment:
Lift a leg of R911, R910 and R905. Then measure each resistor in Ohms mode and verify on the schematic the values for each resistor. If a resistor goes bad, it goes either open or high in value.
Then check IC901 that is is getting Vcc on pin 4. IF those resistors named above went high in value, the IC thinks there is a under voltage condition and wont do anything. Pull up the data sheet for STR-G6651 for voltages you should expect.Leave a comment:
Greetings to all you knowledgeable people,
I am looking for some help and guidance with the above issue, luckily I have managed to find a circuit diagram, but do not have the experience to use it properly!
but I do have a DMM and lots of enthusiasm to find the guilty component.
I have attached the said diagram, there is no visual sign of any damage and fuse is unblown, I have 345 vdc to Grd across the primary winding, and 13.2 vdc to Grd after R905. 160 vdc after R911 but 0.225 vdc after R910
I will upload pictures of the board if needed.
I do hope there is someone familiar with this circuit, or the experience to diagnose the culprit.
PercyAttached FilesTags: None
by PedroGG90Hi everybody.
I have two 3 phase 400 vac smps siemens sitop 24 vdc giving red light overload and higher output 33 vdc.
The switching is controlled from micro controller.
Is it micro controller or transformer ? Or else pls ,?...Badcaps Electronics Repair Forum & Schematic Search -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
by dkneyleThis relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
