Re: JVC THS9 Home Cinema System SMPS No outputs or standby power
39uF is a very odd value, but that is what the schematic shows too... I thought that was a misprint. Put the original cap back in its place for now and change that IC. Because we need to know that the IC is working to hopefully fix the situation or troubleshoot it further.
Having too much voltage on the cap isn't good, but I am wondering "what" you actually measured. I expected the voltage to rise on the cap, when the IC is gone, but surely not a value of 76V.
Lets see if budm sees this.
To clarify the 76vdc was there with the 47uf 50v cap in there.
But the original 39uf 25v is still producing 37vdc, too much for its spec isn't it?
Or will it drop when the IC is replaced?Last edited by Percyveer; 02-01-2017, 06:54 AM.Leave a comment:
Hi Capleaker, it was 39uf 25v.Leave a comment:
The spec of the original which is now back in is 39uf 25v.Leave a comment:
O.k. so the voltage did rise when you took it out. Right now I'd be changing that IC901.
I can't see having 76V DC there. Vinceroger is right... something should went poof. What was c914 originally? The schematic doesn't show correctly.Leave a comment:
what voltage is the capacitor you replaced? at that voltage running through it supprised it did not explode.Leave a comment:
Thank you all for assisting me thus far, it is greatly appreciated.
Well I carried on and removed the STR G6651, and the voltage across the start up cap charged up to 76vdc, thought that a bit high so replaced the existing cap that appeared to be OK and the cap is now charging up to 37vdc.
With the IC removed I have tested across all the pins to each other and there are no shorts. Is it defective?Leave a comment:
The voltage now across the cap is difficult to measure, as it is oscillating, but is somewhere between 12.5 and 13.8vdc.
No change in any other voltages.Leave a comment:
It may be the circuit inside the IC on VCC pin 4 is loading down the Voltage, when check the resistance with the Ohm meter on pin 4 and GND it may not be valid due to the meter does not put out high enough Voltage to cause the circuits inside the IC to conduct.
One way to find out is to use isolated external power supply to feed the IC pin 4 VCC.Leave a comment:
It has to be at least a 25V cap. I'd try the 22 or better a 47uF. 25V, 35v 50V doesn't matter. 50V 47uF are very common.Leave a comment:
You must be real careful because you are working in the primary side.
You can run the VCC test by running the board by itself, DO NOT CONNECT THE BOARD TO AC, hook up the 18V batteries, negative to GND, the positive lead to 100 Ohms 1/4 W resistor, the other end of the resistor to pin 4, then check the DCV on pin 4 and GND to see what you get.Leave a comment:
i would change c914 unless you have a capacitance/esr tester too test it correctlyLeave a comment:
Something is holding that startup Voltage down from reaching 16V startup pointy, but I wonder if there was any output Voltage for seconds not when first power is apply. he may have to leave the Volt meter on the output to see if it jumps up, or on the startup cap to see if it jumps up to more than 16V or not.
At this point I would just replace the IC if all other parts tested OK.Leave a comment:
Those 3 resistors are within spec. So that isn't it. You can solder them back into place.
The short you measure on IC901 between pin 2 and 3 is due to R907 being so low in value. So by rights, if you lift a leg from R907, the short on IC901 should be gone.
Check / replace C914. Check D904 and R903 and that section.
So there are no shorts on any of the secondary output rails to their corresponding GNDs, correct? Also there is absolutely nothing coming out on any of these secondary power rails?
I can confirm short across IC901 pins 2 and 3 goes when R907 is removed (have resoldered).
C914 reads megohms when tested across its leads, and rises as it charges so would appear OK?
D904 0.4 forward voltage, open when leads reversed.
R903 as spec.
I have again checked, and the only voltage coming out of the secondary side of T901 is 0.2vdc on pins 7 & 8 to secondary Grd point indicated on diagram.
Secondary output terminal pin measurment results in post 21.Leave a comment:
Yes guys thanks, working on your feedback now......Leave a comment:
by PedroGG90Hi everybody.
I have two 3 phase 400 vac smps siemens sitop 24 vdc giving red light overload and higher output 33 vdc.
The switching is controlled from micro controller.
Is it micro controller or transformer ? Or else pls ,?...Badcaps Electronics Repair Forum & Schematic Search -
Then today it randomly sprung to life like a zombie but shortly died thereafter. I have no idea why it would have done that and its the first time I've seen it running. I discharged capacitors on the board last night, then it was sitting today.... -
by fharris1977Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.1 Photo
by dkneyleThis relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS... -
by shamsudeenHi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
i know that in linear power supply the noise will be very low comparing to SMPS supply.... - Loading...
