Older Amiga A2000 Power supply repair
  • roadrash
    • Oct 2015
    • 490
    • U.K.
    My previous thread was for the later Amiga 2000 model sometimes called a B2000 but this is a early version Amiga A2000 and has a completely different Power supply. This one is also dead and so far I have replaced all the Electro caps and one IC (UA79M05). I haven't been able to track down the other IC I was going to replace if faulty. It is is marked with two numbers: "UC9432" and "7812". I cannot find any reference to what this actually is but is recognised by my tester. See the attached pics of this and Power supply with caps replaced. Can someone tell me if this is testing as ok and can identify it for me so I can get one for a spare.
    • 31090
    Re: Older AmigA A2000 Power supply repair
    7812 is a standard 12v 1a voltage regulator.
    • roadrash
      • Oct 2015
      • 490
      • U.K.
      Thanks that makes sense.
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        And the marking is (Fairchild Semiconductor logo) "UC8432". "UC" probably refers to the fab line, and "8432" means it was made in the 32nd week of 1984.
        PeteS in CA
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          For something so old, I would carefully check all of the solder joints first thing to look for cold or cracked joints
          • roadrash
            • Oct 2015
            • 490
            • U.K.
            Thanks everyone thats a 2nd success now 2 Amiga 2000's power supplies fixed.
            This has had all new caps and it looks like it may have been the 7812 regulator cos I hooked it up to by bench PSU and input'd 22v and got 17v out and it got hot in a few seconds too so ordered a new one which came today. Put it in and bingo running sweet again.
              by sam_sam_sam
              03-31-2024, 02:12 PM
              by sam_sam_sam
              07-01-2024, 06:34 AM
            • shamsudeen
              Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
              by shamsudeen
              Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
              I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
              i know that in linear power supply the noise will be very low comparing to SMPS supply....
              07-19-2025, 07:14 AM
            • JimBanville
              Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
              by JimBanville
              The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
              Opened it up and discovered the power supply is making a faint clicking or ticking sound.
              I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
              I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
              09-13-2023, 07:21 AM
