Dell / Newton NPS-250DB Power Supply
  • bgavin
    • Jan 2007
    • 1355
    I have a Dimension 8100 on the bench where the customer wants to replace the power supply before it fails. Working fine right now.
    This one has propriety 16-pin connectors that I've not seen before. I've ID'd the PSU as E173738, Newton NPS-250DB. There is a suggestion replacement in the FSP400-60-PFB-M unit at $82.
    1) Can anybody describe the proprietary conntors?
    2) Is a Newton a candidate for recapping, or should it be replaced?
    Thanks in advance..
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: Dell / Newton NPS-250DB Power Supply
    Look at pinouts.ru, it's the reference about stange or proprietary pin layouts. The Dimension 8100 ATX connector is described here.
    Zandrax
    Have an happy life.
    • stevo1210
      • Oct 2006
      • 4156
      Newton is a PSU company that is owned by Delta electronics if I remember correctly. Their PSUs are very good in terms of quality and PSU build.
      I usually buy Newton made PSUs that come from faulty Dell systems and they were perfectly, though they could have done a better job with the caps they chose for the unit. All the caps in my Newton units are made by Ltec, but none are bad. Though it would be a great candidate for a recap.
      • bgavin
        • Jan 2007
        • 1355
        Zandrax, many thanks. I printed that page to a PDF for my library.
        My thoughts were about getting a more standard PSU, and using the old16 pin connector with the AT12 wiring. The Blue/White 3.3v line appears to be a stumbling block.
        I have two of these PSU, both working. Perhaps it would be a better idea to recap them both, and leave them in service?
        • Scenic
          o.O
          • Sep 2007
          • 2642
          another pinout for Dell PSUs... (including the white/blue wires)
          (scroll down to dell)
          http://translate.google.de/translate...hl=de&ie=UTF-8
          • bgavin
            • Jan 2007
            • 1355
            Thanks for that one also. I found the older Dell are non-standard for their pinouts. Damn annoying, having to use factory proprietary junk.
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              Newton makes very good PSUs and if it says 250 watts it IS 250 watts.
              Can usually make something work by rearranging the pins in the plastic connector.
              Mann-Made Global Warming.
              - Dr Seuss
              • bgavin
                • Jan 2007
                • 1355
                It sounds like recapping is a better option than preemptive replacement on this one.
                I'll haul the PSU out of the scrap 8100 I have in the bin and recap it first. Then I can swap it into the client machine without downtime, then recap that one for a spare. I have a few 8100 systems in service, so a recapped spare is a good thing.
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                  03-31-2024, 02:12 PM
                • Info13
                  Dell H235P-00 Power Supply Failure
                  by Info13
                  A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
                  After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
                  ➡️ First test:
                  The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
                  A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
                  I then followed the advice from the forum and replaced...
                  10-22-2025, 01:52 PM
                  HP Compaq Elite 8100 SFF Compaq Elite 8100 i3-550 Specification for Upgrade or Repair
                  This specification for the HP Compaq Elite 8100 SFF can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Compaq Elite 8100 SFF boardview and Compaq Elite 8100 SFF schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-12-2024, 03:44 PM
                  DELL Vostro 3470 Vostro 3400 i3-8100 Specification for Upgrade or Repair
                  This specification for the DELL Vostro 3470 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Vostro 3470 boardview and Vostro 3470 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro...
                  09-12-2024, 03:36 PM
