DC boost converter max power ?
  • joshnz
    replied
    Re: DC boost converter max power ?
    Originally posted by bianchi77
    ATX power supply
    the power supply you are using maybe 5v regulated and will need a load on the 5v rail to provide good voltage and current on the 12v rail.
  • bianchi77
    replied
    I'm using 12V ATX power supply...the output is 11.4V
    I put fuse for protection...
  • joshnz
    replied
    what are you supplying this with
    if you use 330uf inductor use 15khz oscillator.
  • bianchi77
    replied
    I'm thinking obtaining 330uH or 470uH inductor in one piece, since I'm using multiple inductors in series now, a lot flux loss down the wire, reducing efficiency a lot..
  • bianchi77
    replied
    Nearly the same result with FR107 ...216V at RL = 7K
  • joshnz
    replied
    so if the output voltage is larger than diode breakdown voltage, it will reverse backward through diode...I see
    that is correct.
  • bianchi77
    replied
    may be it will answer one of my puzzle...
  • bianchi77
    replied
  • bianchi77
    replied
    Originally posted by joshnz
    Wasted power as it goes backwards through diode.
    Ok, I'll see your suggestion
  • joshnz
    replied
    what happen if reverse blocking voltage is smaller than Vo ? will it reduce the output voltage ?
  • joshnz
    replied
    1N5822 40v not good enough
    FR107 1000v good up to 1000v will work for your application.
  • bianchi77
    replied
    fr302 = 100 reverse blocking voltage.
    you need FR304 at least.
  • bianchi77
    replied
    Fr107 ?
  • joshnz
    replied
    Diode = FR302 on frequency 921Hz, Vo = 216V and RL=7K..
  • bianchi77
    replied
  • joshnz
    replied
    What is the output diode you are using?
  • bianchi77
    replied
    I got 234mV on Vo for 47uH and 150KHz....
  • joshnz
    replied
    in your drawing it shows output diode as 1N3822 is that correct?
    Your output diode will need to be fast switching type.
  • joshnz
    replied
    so for 47uH probably 150KHz ?
    yes
  • bianchi77
    replied
    where did you get that from?
    just a guess
