Need help identifying transformer
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    I have a soldering re-working station ... an Amazon - el-cheapo - heres a pic:
    and the transformer suddenly decided to go into melt down mode (literally let the smoke out of the transformer) ...
    Unfortunately, all of the print on the transformer is in Chinese:
    Just for giggles, I decided to throw a volt meter on it to see what I'm getting on each of the three taps when 120 is applied to the main (the taps with the highest resistance), and I think the meltdown did it in, because the readings I got were as follows:
    Yellow leads: .7 Vac
    Red leads: .8 Vac
    Black leads: .4Vac
    Obviously these couldn't be the proper voltages as they would hardly operate a re-working station.
    Can someone please help me identify this transformer so I get purchase a replacement?
    Thank you,
    Mike Sims
    sigpic
    • Jul 2011
    • 6070
    Re: Need help identifying transformer
    Here is what I would do on the top of transformer where the secondary winding are carefully take off the yellow tape until you see the wire you may find a thermal fuse in there or in the primary winding there maybe on it that you can by pass it to see if it still works if it dose there are some thing you can do
    Check the secondary winding with an ohmmeter and see if it has any reading at all on any wire if so then go head and try what I was talking about earlier
    • keeney123
      Lauren
      • Sep 2014
      • 2536
      Can't read chinese but I think this is your replacement.
      http://www.ebay.com/itm/like/1515315...&ul_noapp=true
      • mikey5791
        • 521
        • Malaysia
        The chinese writing are not that important; the first row means "Approved" while second row says the input/Tested at 110V and the last row is production date which is November 2015.
        You should follow sam_(x3) advice : try carefully peel off the yellow tape and see if you can find a thermal fuse, if it is burnt you might as well replace an equivalent type or else buy a new replacement transformer. Good luck then.
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          bet you have a short on one of the secondaries.
          thermal fuse may have caught it in time.
          you might be able to bypass fuse for a TEST ONLY and run it disconnected.if it gets hot its toast pardon the pun.
          look for shorted diodes,ect.seen bad heaters do this in cheap stations too.
          fuse is in the primary side.bottom section.
            • Jul 2011
            • 6070
            Originally posted by kc8adu
            you might be able to run it disconnected if it gets hot its toast .
            I have seen a few transformers do the with no load on them with in a few minutes it would get so hot that you could not touch it if this is the case do NOT use it any more
            • EasyGoing1
              Shock Therapist
              • Sep 2016
              • 977
              When I plug it in, it starts to smoke within a few seconds.
              sigpic
              • EasyGoing1
                Shock Therapist
                • Sep 2016
                • 977
                Thank you ... the cost of the transformer with shipping is almost as much as buying a new unit... ill keep looking around and see what I can find. If I can get the output voltages, I might have one laying around that will work.
                sigpic
                • keeney123
                  Lauren
                  • Sep 2014
                  • 2536
                  Henry Ford would be proud of them. Sell the unit at a cheap price and make your money off of parts.
                    • 31283
                    i have not seen those fail before.
                    as i cant see any of the damned pictures because they arent uploaded to the forum, give me the station model number.
                    maybe it can be bodged with a 24v toroid.
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Can you see these links and click on them? They are links to the images.
                      Unit Face
                      Transformer 1
                      Transformer 2
                      Transformer 3
                      But just in case, the model is a 862D
                      sigpic
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Here, I think I got them uploaded now...
                        sigpic
                        • learnmore
                          Help choosing replacement transformer for Levoit 600S SMPS
                          by learnmore
                          Hello Community,
                          I'm attempting to repair the SMPS on a Levoit 600S air purifier. The transformer is likely open. It has six pins. 2 pairs on the primary side (one pair tested open) and 1pair of legs on the secondary side. Legs on the secondary side are spread wide apart (end-to-end). I've circled them in blue. Dimentons of the transformer are 22x23mm. Marking on the transformer are EE16 1.9mH-B. Fuse for the powerboard is fuse 250V 3.15A. I've been unable to find an exact match and I'm hoping for some help here to find a suitable replacment.
                          Peace
                          LM...
                          11-04-2025, 09:35 AM
                        • ohren
                          Original Xbox 1.0 PSU: Foxlink FTPS-0002 Rev. B. — 12 V low, 5 V high — transformer?
                          by ohren
                          Hello!
                          I'm looking at an original Xbox PSU: Foxlink ftps-0002 rev. B. The 12 V output is too low, and the 5 V output is too (?) high. Unfortunately I don't have an oscilloscope but only a DMM for diagnosis.
                          Measured voltages with no load:
                          After rectifier diodes
                          12V: 6.17 V
                          5V: 5.67 V
                          Secondary transformer pins AC measurement (really don't know if this says anything)
                          12V: 2-2.5 V
                          5V: 1.04 V
                          I also have another (working) Xbox psu from Delta. The same measures there, in order, being: 10.79,...
                          03-18-2023, 10:33 AM
                        • mikey5791
                          Is it possible for transformer substitution?
                          by mikey5791
                          Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
                          Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
                          My questions are
                          1. How do i test to see if the transformer is in good working condition?
                          2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
                          Hope you guys understand what i was asking. My intention is...
                          11-03-2022, 02:11 AM
                        • dennis_elx33
                          3PHASE STEP-DOWN Transformer in Check
                          by dennis_elx33
                          Hello All,
                          i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
                          Problem statement: Power tripped Off
                          Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
                          Action Done:
                          1) Replaced the faulty parts with good spare.
                          2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
                          12-02-2024, 06:52 AM
                          ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) Book Specification for Upgrade or Repair
                          This specification for the ASUS Transformer T101HA - X5DHD Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T101HA - X5DHD boardview and T101HA - X5DHD schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                          09-06-2024, 04:40 PM
