Delta DPS-250AB-24A Unstable voltages when loaded
  • cpt.charlie
    • Sep 2013
    • 270
    • Spain
    Hi, i have a PSU Delta DPS-250AB-24A that belongs to a compact computer and due to it's pinout and size i cannot use a generic ATX PSU, the problem is that the computer won't start at all, just a brief flash of the power on led.
    After removing the PSU if i short the green with black the psu starts normally and all voltages are fine, however if i connect a 3.3 ohm/10watt resistor to the 5V line, the voltage jumps to 5.64V, if i connect the same resistor at the 12V rail, the voltage drops to 10.5V, after removing the PSU case i found that secondary caps looked fine and ESR/capacitance were within spec, i haven't removed the primary filter cap, but looks OK, in fact almost all caps in secondary are good quallity caps (nichicon, rubycon nippon-chemi-con) solder joints seem OK and pcb is clean, can anyone suggest what could be the cause on this strange behavior?
    Thanks in advance.
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: Delta DPS-250AB-24A Unstable voltages when loaded
    I think this could also be a motherboard issue. The symptom you see PC lights flash and then turn OFF is typical for a motherboard that has a shorted MOSFET or ceramic cap.
    Therefore, first test the computer with another power supply. I understand this power supply is a special form factor, but if it uses a standard ATX pinout, you can use any other PSU at least to test the computer. If it works, then you know the problem is with this power supply. And if not, then we know it's probably a fault on the motherboard.
    Let us know what you find in your testing.
    • Th3_uN1Qu3
      Believe in
      • Jul 2010
      • 6031
      • Romania
      What you are seeing is normal behavior for a group regulated power supply, you have to load ALL rails at once like a computer would.
      I agree that there is likely something wrong with the mainboard.
      A working TV? How boring!
      • cpt.charlie
        • Sep 2013
        • 270
        • Spain
        I have checked the computer with a stardard atx psu and despite it needs some recapping it works just fine, the problem seems to be located on the PSU that for some reason it's unable to regulate properly when loaded, tomorrow i'll try to check the output rectifiers outside of the circuit as i'm getting weird readings when checked in circuit (like conducting in both ways but not shorted, maybe leaky? but i don't think so because the 3 rectifiers show the same behavior).
        momaka: you are right, the PSU has a special form factor and a slightly different pinout but it comes with an adapter to a standard pinout.
        Th3_uN1Qu3: I thought that computer PSU's had a single feedback circuit connected to +5v on old PSU's and +12V on modern units.
        • cpt.charlie
          • Sep 2013
          • 270
          • Spain
          After checking the rectifiers out of the circuit they seem to be OK, no leaky diodes.
          Brigde rectifier OK
          Mosfets OK
          Main capacitor OK
          Output rectifiers OK
          Looks like it's a problem with regulation circuit, any thoughts?
          Power supply supervision IC is a DWA103N (maybe an equivalent of TPS3513)
          Control IC is a UC3845B
          Thanks in advance.
            • 31028
            i would replace all the small caps with something like panasonic FR.
            • cpt.charlie
              • Sep 2013
              • 270
              • Spain
              The small ones on the control board? I couldn't check the ESR but capacitance was OK and they hadn't sings of damage.
              3 X 10uF 25V Ltec branded
              1 X 100uf 25V ltec branded
                • 31028
                all small ones you can find - they have the lowest lifespan.
                usually rated for 1000hours.
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Check power good signal (gray wire). If it comes up too late, mainboard will not start. It is a good idea to replace all small capacitors near supervisor chip.
                    master hoarder
                    • May 2008
                    • 12175
                    • Bulgaria
                    And quite often, that is the problem with them: they show okay capacitance, but ESR can be through the roof. No signs of failure, either. I learned this the hard way after banging my head a few times with power supplies that I couldn't figure out why they were not working.
                    So it's worth a shot replacing those caps. Especially around the supervisory IC, like uN1Qu3 suggested. This looks like a well-designed Delta Electronics PSU, so definitely worth trying to fix it.
                    • cpt.charlie
                      • Sep 2013
                      • 270
                      • Spain
                      I take my hat off to you, that was exactly the cause of the problem, the 10uF caps had high ESR, now the PSU is working perfectly.
                      • PeteS in CA
                        • Aug 2005
                        • 3581
                        • USA, Unsure of Planet
                        Lelonian crap, what a non-shock.
                        PeteS in CA
                        • Wester547
                          • Nov 2011
                          • 1268
                          • USA.
                          Actually, those are Luminous Town Electric. TH is a LTEC series, as is LZG. A 10uF capacitor reading 0.94uF is certainly a goner. Good job on the repair.
                            master hoarder
                            • May 2008
                            • 12175
                            • Bulgaria
                            Good to hear that!
                            To be honest though, I too am a bit surprised that the PSU stopped working because of that cap. While 6 Ohms is considered high/bad ESR, I don't think it's that bad for a small 5x11 capacitor. I have many legit 16V, 100 uF, Rubycon YXA and Chemicon KMG that typically read 1-2 Ohms ESR on my meter.
                            But then again, it is possible that the PSU wasn't designed to take such ESR deviation for that cap spot.
                            I see 9400 nF displayed on the screen of the meter above. 1000 nF = 1 uF. So that cap is reading in spec on the capacitance at 9.4 uF... unless *I* missed something here?
                            • Wester547
                              • Nov 2011
                              • 1268
                              • USA.
                              Whoops, I missed a 0. You are right, they read 9.4uF. I thought that was strange that it read so low for capacitance but okay for ESR. Maybe it's just me, but those 10uF caps look like they're shorter than 11mm... possibly 9mm long? That LZG looks mislabeled too (110˚C rather than 105˚C, although 110˚C is technically correct for the core temperature as the maximum permitted ripple current at the maximum rated ambient temperature will cause a 5˚C rise in core temperature).
                              • CapLeaker
                                Leaking Member
                                • 8158
                                Originally posted by momaka
                                Good to hear that!
                                x2
                                However, the ESR would be lower if the cap was measured, while it still was warm. We also don't know what the other caps measured.
                                In this case if he had warmed up the PSU first place with a hair dryer before using it, it should have worked also.
                                • cpt.charlie
                                  • Sep 2013
                                  • 270
                                  • Spain
                                  The 10uF caps had an esr of about 6-7 ohm at ambient temperature.
                                  • PeteS in CA
                                    • Aug 2005
                                    • 3581
                                    Mea goofa. The Ltec logo looks like the Lelon logo.
                                    PeteS in CA
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      • Bulgaria
                                      Yeah, I suspect that they are made by the same company, even though I think I've read otherwise.
                                        MSI Delta DELTA 15 A5EFK-008 Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta DELTA 15 A5EFK-008 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the DELTA 15 A5EFK-008 boardview and DELTA 15 A5EFK-008 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                                        09-07-2024, 03:40 AM
                                      • Junkrepair
                                        Calculating ESR from tan delta -- tan delta's dependence on capacitance
                                        by Junkrepair
                                        I'm finally recapping my Soyo K7VX6 motherboard (aka KT600 Dragon Ultra) and replacing Sacon SZ-series caps. The Sacon SZ datasheet provides a spec for tan delta, but not for ESR, while the candidate replacement caps are specified in terms of ESR.
                                        I found this nice little description of the conversion:
                                        Calculating capacitor ESR from Tan(delta)
                                        https://forum.digikey.com/t/calculat...-from-tan/2633
                                        It mentions that a general spec for tan delta has to be adjusted for the specific capacitance before plugging tan delta into the formula...
                                        06-12-2023, 02:45 PM
                                      • Capacitorial
                                        Powersupply has all the voltages - Monitor still no power
                                        by Capacitorial
                                        Hello guys,
                                        I have a Philips 240B7QPJEB. The monitor seems completely dead.
                                        I opened it and measured the voltages of the powersupply. I found that a mosfet was dead and replaced it.
                                        On the connector, that goes to the TCON board, all voltages 15-19V and 5V are present.
                                        The small connector on the left of the PSU has two cables with 18V and all the other have 0.2V. It connects on this small connector on the left ontop of the panel. I guess the backlight? Seens fine I guess.
                                        The weird thing is, that the Power LED is powered over the TCON board.
                                        On The TCON...
                                        12-28-2024, 02:12 PM
                                        MSI Delta 15 A5EFK-081AU Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta 15 A5EFK-081AU Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-081AU boardview and 15 A5EFK-081AU schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 06:11 AM
                                        MSI Delta 15 A5EFK-046UK Notebook 15 Specification for Upgrade or Repair
                                        This specification for the MSI Delta 15 A5EFK-046UK Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 15 A5EFK-046UK boardview and 15 A5EFK-046UK schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                        09-07-2024, 05:50 AM
