Help me repair a TT850W PSU
  • KAMENi
    • Sep 2008
    • 21
    Re: Help me repair a TT850W PSU
    i keep it on when there is no load.
    once i connect anything to 5v wire, it shuts down after 1 or 2 seconds top
    • i4004
      • Oct 2006
      • 2029
      so without load you have 5v there?
      you should check the protection ic(if it has one) or main pwm ic to see why is it shutting down.
      could be faulty ic itself, or some passive component near it.
      but what bothers me is the fact other voltages are fine. this can suggest transformer is faulty, because it's the only thing separating output voltages.
      if the primary side is working ok(and if you have(for exmple) 12v ok it probably is)
      i really see no way of 5v being faulty other than trafo.
      anyhow if you don't succeed with repair you can send it to me, so i'll try to see what's happening.....if you wish.
      if i find something i won't charge you anything(but i won't be buying comeponents to repair it either...i would send it back to you), if i don't, to trash bin it goes...before that i'll remove the trafo and then dismantle it, as final post-mortem..hehe...
      • KAMENi
        • Sep 2008
        • 21
        i doubt it can be the transformer because if it were malfunctioning it wouldnt give out -5v either
        i will replace the ic1 ASAP
        • KAMENi
          • Sep 2008
          • 21
          i have unsoldered the ic1. it's a cm6800g.
          i'll post the results when i replace it.
          if anyone has any other ideas, you're all welcome to share them
          • KAMENi
            • Sep 2008
            • 21
            of course, I cant find this IC anywhere in Zagreb.
            i have asked a shop if they can order it, but they'll let me know on monday, tuesday.
            • Gianni
              • Jul 2008
              • 681
              • Italy
              #26
              I agree with i4004.
              Now you have removed the IC so I think you can't do more test.
              Have you tried to load only the output +3.3V or +12V without loading +5V?
              If you can do this test, maybe using some power resistor, and the PSU stays on, than the problem is only on +5V.
              I think it is possible that, due to parasitic elements/coupled inductance/bad joints, the +5V rail is OK without load and as soon as you load it, the voltage drop and the PSU shut down for undervoltage protection.
              This could be related to faulty transformer too.
              I don't know how the transformer is built but if there is a cold/cracked joint inside it, that could explain the problem.
              I had built (long time ago) for job some transformers, they had the secondary output made by a thin copper foil. To connect the output to the PCB I had to solder the wire on the foil and than I had to wrap it on the bobbin. If the solder is not good, when you wrap the foil on the bobbin you can get some crack between wire and foil.
              So if you have a bad joint inside the transformer you can have the right voltage as long as you don't sink current, when you try to get current than the voltage drop due to the high resistance between foil/wire.
              A scope and an active load would be useful to test it but I know they are no "common tools" and moreover they are expensive.
              I hope you can get the IC because it is difficult to find some kind of components.
              Keep us informed
              Gianni
              "In the confrontation between the stream and the rock, the stream always wins...Not through strength, but through persistence."
              H. J. Brown
              • KAMENi
                • Sep 2008
                • 21
                #27
                i have tried loading only 12v and it works normal (i connected old cpu fan). you know what load on 5v does. i didn't try on 3.3v because i didnt think the fan would start working on so low voltage.
                do you think i can check the transformer myself? if i find it malfunctioning, i can get it rewound so that wouldnt be a problem
                p.s. i can still solder the IC back on while i'm waiting for the shop to let me know if they can get it
                • linuxguru
                  • Apr 2005
                  • 1564
                  #28
                  Put it in a DIP socket - it will simplify future maintenance. Use machined sockets with cylindrical gold-plated pin-sockets.
                  • KAMENi
                    • Sep 2008
                    • 21
                    #29
                    i didnt exactly unsolder the IC itself, i unsoldered the whole PCB board with it. it's 1 in x 1 in
                    • Gianni
                      • Jul 2008
                      • 681
                      • Italy
                      #30
                      Well... you can try to check but the best thing would be to check the waveform on the +5V diode to see what's happening when you load it.
                      Since you don't have a scope, you can only check the resistance between the +5V winding respect to ground, it must be very low in the order of few mohm.
                      I don't think you can rewound it because probably ferrite are glued and you must break them to free the bobbin and winding.
                      To replace them you need the exactly type (core material/shape/air gap if present) and very often they are not standard/commercial ferrite.
                      Gianni
                      H. J. Brown
                      • KAMENi
                        • Sep 2008
                        • 21
                        #31
                        all 3 secundary points have 0.2 ohm to ground
                        • Gianni
                          • Jul 2008
                          • 681
                          • Italy
                          #32
                          So the secondary windings are not open; I have measured a secondary winding of a trafo with Agilent 34401A DMM, it's a 6½ digit, and the resistance was 6mohm. I think the 200mohm should be OK if you are using a common DMM, probably if you short the DMM probe you still have 70~100mohm due to the DMM probe cables. It's hard to say if the remaining 100~130mohm are due to DMM limit/accuracy or if they are real.
                          In case they are real, it would justify the voltage drop under high load: by Ohm's law if you apply 10A to a 130mohm resistor you obtain 1.3V, so if you lose 1.3V on 5V, you have 3.7V as output voltage.
                          At this point I really don't know what to tell more to help you ; I would like to have the PSU here in my lab to understand what's going on.
                          I was also thinking about a problem with overload protection, but in this case, when it is triggering not only +5V must drop but also other rails.
                          This is a very light load, I think it can consume around 160~200mA, and it is very low compared to MOBO current consumption.
                          If you don't have power resistors to check PSU with higher load, you could use some car's lamps, they are rated for 12V and can draw much current.
                          You can use them also on +5V and +3V output, you can connect some lamps in parallel to increase the current.
                          The only problem with lamps is that they have a very low resistance when they are off, so maybe they can overload the PSU at start up and until they are in steady state condition.
                          Anyway I would give it a try, lamps are not so expensive and you can keep them as spare parts for your car.
                          If you use them, protect your eyes from the light and place them on something that doesn't burn, they become very hot when are on.
                          I would consider the offer made by i4004, if you can send the PSU to him maybe he is able to fix it.
                          Ciao
                          Gianni
                          H. J. Brown
                          • i4004
                            • Oct 2006
                            • 2029
                            #33
                            and if i can't i'll send it to gianni: god damn, machine shouldn't win!
                            hehe...
                            anyhow, i do have a scope.
                            • KAMENi
                              • Sep 2008
                              • 21
                              #34
                              i'll try to replace the IC if they can order one. if not, i will send it to i4004
                              thanks for your support guys
                              • KAMENi
                                • Sep 2008
                                • 21
                                #35
                                unfortunately, i didn't find this IC anywhere in Zagreb, and no shop can order one.
                                i4004, thank You very much for the best intentions, but i'll have to say no to your offer. it's not my PSU and my cousin doesn't want to send it
                                thank You anyways
                                if someone should happen to run into a store that has this IC in its offer, please tell me their website, or contact via e-mail so i can order it
                                once again, thanx for all the help and support from both of You, Gianni and i4004
                                • Gianni
                                  • Jul 2008
                                  • 681
                                  • Italy
                                  #36
                                  I'm sorry our help didn't solve the problem but at least you have done your best.
                                  I don't know where to look for the IC but I doubt you can find it easily.
                                  I can't check RS because is down right now, I serched in Digikey but I don't find it.
                                  Good luck and don't give up till you know there's nothing more to do.
                                  Gianni
                                  H. J. Brown
                                  • PCBONEZ
                                    Grumpy Old Fart
                                    • Aug 2005
                                    • 10661
                                    Check around for dead PSU's that might happen to have one.
                                    Mann-Made Global Warming.
                                    - Dr Seuss
                                    • KAMENi
                                      • Sep 2008
                                      • 21
                                      #38
                                      i will surely check every psu that comes into my hands for that IC
                                      if anything new should happen, i'll let you know
                                      thanx again
                                      • Baste
                                        MBR3045CT and SR3045LCT Schottky diode testing help.
                                        by Baste
                                        Hello experts,
                                        Can anyone educate me on how to test MBR3045CT and SR3045LCT Schottky diodes? I'm totally a newbie in electronics, so forgive me if I have cheap tools. In my effort to repair a Gigabyte PSU, I stumbled upon the two diodes, which I suspect are leaky. I tested this with my two cheap multimeters and the newly bought LCR-T4 MC328, and I got confusing results. Below are my test results.
                                        Aneng ST182 Meter.
                                        Diode mode.
                                        MBR3045CT:
                                        Diode mode
                                        Pin 2-1 - 0.150v
                                        Pin 2-3 - 0.150v ...
                                        10-21-2025, 06:14 AM
                                      • Damex 29
                                        Dynabook l50-g 11j scheme
                                        by Damex 29
                                        looking for scheme robusta 6050a3128301 a01
                                        Dynabook l50-g 11j
                                        04-02-2025, 03:51 PM
                                      • iyas132
                                        Corsair RM 750 blown schottky diode near ES1DF
                                        by iyas132
                                        Hi there, i am currently diagnosing my corsair rm750 that wont turn on, after a power trip.
                                        Before the power trip, previously i need to push power button on my pc case quite a bit in order to turn the pc (and power supply on), however after the power trip now i cannot turn the pc on at all and i opened the power supply, and found out some of the component(s) are blown. (picture attached)
                                        My current diagnostic is that the (schottky) diode marked "SF" in the 5Vsb circuit are blown and possibly the ES1DF diode too.
                                        Can anyone help me identify the component...
                                        12-30-2024, 01:34 AM
                                      • piipo
                                        HP ZBook 200W power adapter blue pin question
                                        by piipo
                                        Hi, I have non original 200W power adapter for my ZBook but it limits the computer power. It looks this depends on the resistor value between the middle pin and the main 19,5 rail. Can somebody with an original HP 200W blue pin power adapter to measure between the middle pin and the plus, the resistor value so I can apply the same to mine? On the attached image it's the resistance between the "positive high" and "positive low" - the pin and the inner side of the connector. Thank you so much!
                                        02-01-2023, 07:17 PM
                                      • Art Em
                                        Need electric scheme for HP ENVY 13 with Moorea 13CS ICL 19728-1
                                        by Art Em
                                        Would be grateful if you send me the electro scheme for this motherboard, mentioned in title. If anyone is interested why:
                                        -first keyboard backlight stopped working
                                        - a couple months later the keyboard itself stopped working.
                                        - then, in two days, the laptop itself stopped booting.
                                        Thanks everyone in advance
                                        04-13-2024, 01:13 AM
