Shuttle PC35I2402 Power Supply
  • jedwar10
    • Aug 2009
    • 43
    I have an old shuttle ITX PC that i'm fixing for a client that came in with a bad power supply and motherboard. I found a motherboard online and replaced it and it is running fine now. I cannot find a suitable replacement power supply. (very small dimensions 42mm x 62mm x 190mm)
    I am attaching some pictures of the components. When I first opened the unit it had a swollen OST RLS series 10V 2200uf cap. I replaced it with a Nichicon HZ with the same values. I also used my "Blue ESR meter" to test the other caps and they seem to be within normal ranges.
    Please help with whatever you can.
    Thanks,
    Jason
    • 31218
    Re: Shuttle PC35I2402 Power Supply
    you dont say anything.
    is the psu running?
    if not, is the standby 5v running?
    • jedwar10
      • Aug 2009
      • 43
      Sorry for the missing info.
      When i plug it into my power supply tester the +12V & +5V light up but start fading away immediately.
      As a side note I just found out with it pulled apart without the cooling fan plugged in it lights all of the indicators except -5V.
      As soon as i also tried plugging in a molex plug or the cooling fan into the tester it only lit 12V & 5V again and started fading away.
      It does not run a PC or the PSU tester. I have a DMM and can test farther with some guidance.
      Thanks for your help!
        • 31218
        well i would start by replacing all the small caps with god low esr ones.
        • japlytic
          • Oct 2005
          • 2086
          As I said elsewhere, electrolytic capacitors can go bad without any visible signs.
          • jedwar10
            • Aug 2009
            • 43
            Thanks to both Japlytic & STJ for the help on this one. I've been slammed at work and just got back to this project. After suggestions from both users I went back over the board with my Blue ESR meter for the smaller caps. I only tested the larger caps originally. I found a small 100uf 25v cap (circled in red on the photo) that wouldn't register on my ESR meter at all, even after removing it from the circuit.
            I have since replaced the offending electrolytic with a Rubycon ZL of the same values and the tiny PSU is back to life.
            Thanks again Japlytic & STJ
            Jason
