This looks like run-of-the-mill generic low quality PSU, so I am 99.99999% certain you won't find an *exact* schematic for it.
That said, the three transformers in the middle and SG6105 PWM controller tell me this is just another typical half-bridge topology PSU. So you can grab the schematic off of any half-bridge ATX PSU available online and use it as a *guide*. Here is one I found that is based on a SG6105 PWM IC: http://danyk.cz/s_atx02a.png
Again, use this only as a rough guide, and don't expect component values or positions to match. Your PSU should be similar to what is shown on that schematic, but very likely NOT the same.
You should also notice that there is no second output toroid for the 3.3V rail and no small torroid(s) near the main transformer. This suggests the 3.3V rail is linearly regulated - a cheap method that is very inefficient.
In my opinion:
this PSU appears to be very low quality crap. I wouldn't attempt fixing it if I was in your position - not for computer use anyways (I've fixed some similarly crappy power supplies, but only as a learning experience or for fun).
It's for fun and learning experience.....usually I'll another rectifier SBL2040 and output toroid filter on 3.3V rail....
Do you reckon it has a secondary rectifier issue ? I measured SBL2040 on 5V rail with DMM diode test mode and got only 0.12V.....that's bad, isn't it ?
It's a Linkworld. The LPF2SS model number points to a 300W Linkworld,however I have doubts it can do a watt in spec. (it's beyond the definition of garbage,and not worth anything )
In my opinion:
So what's the faulty of this Ritmo ?
Is it possible that SB1040 is faulty ?
I've tested on DMM = 0.17V but when I tried with LED, 1K and 9V battery it's doing normal way of diode...forward bias LED = on...reverse bias...LED is off...
If this SB1040 is not faulty ...what else can be faulty ?
it was shorted accidentally between 5 to ground or 12 to ground...and shut off......could be SG6105 ?
If the SBL1040 passes the diode test that you did with the LED, then it is NOT faulty. Do the same test with the other diode rectifier (the SBL2040)
No.
Those controllers (SG6105, TL494, KA7500) are very robust. Only a severe case of run-away 5VSB rail (over-voltage) can damage it, which is very rare. Also, if it was damaged, you'd have very burned spots on the board. I know because I've worked on such PSUs. Typically, the damage looks like this: https://www.badcaps.net/forum/attach...3&d=1334112631
A lot of things could be wrong, so lets start with some order.
First, check mains fuse and NTC thermistor on input, as well as input bridge rectifier (typically 4 diodes on cheap PSUs).
If these are okay, next item is plug in the PSU and check the 5VSB rail (purple wire on ATX connector for your PSU) - you should get 5V +/- 0.25V.
So check these things and we will go from there. Also, we really DO need better pictures to help you troubleshoot this PSU.
This one is good (it's helpful): https://www.badcaps.net/forum/attach...1&d=1472539862
