Hey all -
This is my first computer power supply to recap. I've recapped old gaming systems, arcade CRTs, the Samsung monitor I am typing this on right now, and done some other kit work here and there.
I acquired several early 2000s PSUs recently for $1 each along with some motherboards, cpus, RAM, and about 18 video cards. My current project was to test/benchmark all the video cards and see how they were doing.
I started off using this iCute power supply I acquired in the lot that tested well voltage-wise on the Frozen CPU tester. Then I paused to think about the fact I was suddenly going to turn this dusty thing with the suspicious brand "iCute" into a test bench power supply and start running all of these video cards through the ringer. Maybe I should check out the quality first.
Short version - I want to recap this guy and make sure he has solid quality caps inside before I continue testing all of these video cards. While I am sure he could be just fine, the caps are OUT & the process has begun.
1: What brands do you guys like for PSUs? I think I used Panasonic..FR? when I recapped this Samsung monitor I am using. I tend to order from digikey and can just run a top makes/models and see which ones offer the dimensions I need (although height changes shouldn't be a problem here)
2: Regarding the larger caps - Do you always replace the larger ones or play it by ear based on some criteria? At the moment, I have left the 2x 330uf 200V caps (C1 and C2) in the board.
3: Anything else i should check out on this guy besides caps or any additional concerns? No specialty tools here for it - I have a Fluke 87V and an oscilloscope at my disposal, but you have my attention no matter what.
Sadly left the heat on one of the prongs a bit too long while removing a wire, and...
I guess I need a new one of those as well.
Here is the list of stock caps for reference for anyone that reads the thread - present or future. Some infamous brands among you guys are listed here if my badcaps google-fu is in working order. Brand names included in the stats. All caps rated 105 degrees except the two larger ones @ 85 degrees. Dimensions are listed as height, diameter.
C1 330uf 200v (MK) [need to verify C# as it is under glue. Will edit later]
C2 330uf 200v (MK)
C5 10uf 50v (TNR) 11mm, 5mm
C6 10uf 50v (TNR) 11mm, 5mm
C7 10uf 50V (TNR) 11mm, 5mm
C8 22uf 50v (TEAPO) 11mm, 5mm
C9 1uf 50v (TEAPO) 12mm, 5mm
C12 2.2uf 50V (TNR) 11mm, 5mm
C14 1uf 50v (TEAPO) 11mm, 5mm
C15 1uf 50v (TEAPO) 11mm, 5mm
C19 3.3uf 50v (TNR) 11mm, 5mm
C21 470uf 10v (TEAPO) 11mm, 8mm
C22 470uf 10v (TEAPO) 11mm, 8mm
C29 680uf 16V (Fuhjyyu) 16mm, 8 mm
C30 470uf 10v (TEAPO) 11mm, 8mm
C31 1000uf 10v (TEAPO) 15mm 10mm
C32 1000uf 10v (TEAPO) 15mm, 10mm
C33 2200uf 6.3v (Fuhjyyu) 20mm, 10mm
C34 220uf 16v (TEAPO) 11mm, 8mm
C35 220uf 16v (TEAPO) 11mm, 8mm
C37 10uf 50v (TNR) 11, 5mm
C39 0.22uf 50v (TNR) 11mm, 5mm
C40 330uf 16V (CapXon) 15mm, 6mm
I guess I need a new one of those as well.Here is the list of stock caps for reference for anyone that reads the thread - present or future. Some infamous brands among you guys are listed here if my badcaps google-fu is in working order. Brand names included in the stats. All caps rated 105 degrees except the two larger ones @ 85 degrees. Dimensions are listed as height, diameter.
C2 330uf 200v (MK)
now u know why it was going for so cheap lol
actually. Should be very similar to this PSU:
