Need help finding a substitute pwm controller
  • The Performer
    • May 2013
    • 60
    • United states
    Hi everyone, have an issue with a charger for an led work light that snap on tools no longer makes or can replace. The issue is inside of the charger it has an 8 pin controller that is starting to fail (I can spray canned air on it and the circuit works fine until the chip heats back up)
    Anyway, the problem I am having is finding a replacement ic online. The part number on the IC is GW6203. From what I can gather is it is a proprietary ic made specifically by the chinese for this charger and no longer able to source a replacement.
    Any help is greatly appreciated!
    • 31041
    Re: Need help finding a substitute pwm controller
    foto's ?
      • 31041
      did you read the datasheet?
      it's a clone of 2 other chips.
      • The Performer
        • May 2013
        • 60
        • United states
        Actually I looked at the data sheet but didn't know that's what the "compatible with" meant.
        Thank you very much buddy, found the rm6203 on ebay for a $.99
        • japlytic
          • Oct 2005
          • 2086
          I've seen a number of these "exotic" Chinese PWM controllers before.
          • flat-earther
            ASUS X54H laptop thinks it's always charging even with charger unplugged
            by flat-earther
            The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
            Windows also shows ''Plugged in'' when charger is not connected.
            This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
            Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
            If I let battery run out and say it has 3% Windows will...
            06-24-2025, 09:32 AM
          • ktmmotocross
            ACER Spin 5 SP514-51N after usb-c controller ic change no reaction to charger - must it be programmed first?
            by ktmmotocross
            Hello.
            Have this ACER Spin 5 SP514-51N that have only 5V on usb-c charging ports and usb-c comtroller CYPD5225-96BZXI heats up. so i order new controller and replace it. now u have no reaction to charger. must be this ic programmed first and if yes than how...
            06-17-2025, 12:11 AM
          • motormayhem
            Lenovo T460 Only Charges on One Charger
            by motormayhem
            Laptop Question
            I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
            A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
            05-12-2023, 01:46 PM
            NVDC charger configuration...
            11-05-2024, 03:28 PM
          • master3112
            ASUS ROG Strix- G513IH-HN008, G513-6050A3249301- MB-A04 (A4) damaged Embedded Controller
            by master3112
            I have an ASUS ROG Strix- G513IH-HN008, motherboard G513-6050A3249301- MB-A04 (A4)
            When I received the device, the device has no function. After an investigation, I found that the PWM CONTROLLER RT6575B (U6100) is getting warm and there is a short circuit at the 3V3 output. This normally supplies 3V3 for the embedded controller IT5571E-128 (U301). When measuring and analyzing with a thermal imaging camera, I found that some components are damaged: SLG4E42553VTR (U8500), IT5571E-128 (U301), LAN RTL8111H (U450), LOGIC 74LVC1G08GW (U1900), RT6575B (U6100) All these components are on...
            10-29-2024, 09:32 PM
