Replacing SBL1040 and FR302 with 1N5407 3A ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Is it possible for me replacing SBL1040 and FR302 with 1N5407 3A ?
    I have some 1N5407 on my hand..
  • bianchi77
    • Jun 2016
    • 1121
    Re: Replacing SBL1040 and FR302 with 1N5407 3A ?
    maximum recovery time for FR302 is 150ns and 1N5407 = 1500ns...10x slower...
    but is it enough for switching speed of the supply ?
    • bianchi77
      • Jun 2016
      • 1121
      What's the switching frequency ?
      • CapLeaker
        Leaking Member
        • 8352
        I think I did answered that already in the other thread. If there is a fast recovery diode in there you need to replace it as such. A normal rectifier diode can't keep up with the pace. You just cant replace the SBL1040 (Schottky) or the FR302 (fast switching) with a 1N5407 and think all is ok. The diodes will blow.
        • bianchi77
          • Jun 2016
          • 1121
          In which post ?
            • 31304
            UF5408 may work
            • bianchi77
              • Jun 2016
              • 1121
              so it will not work on 1N5407 ? or it works ?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                No...It will not work....the 1N5407 will overheat and burn almost immediately....CapLeaker is 100% correct.....the FR302 could probably be replaced by the UF5408 as stj suggested...
                • bianchi77
                  • Jun 2016
                  • 1121
                  Ok, I need to wait then...thanks guys
                    by sam_sam_sam
                    03-31-2024, 02:12 PM
                    by sam_sam_sam
                    07-01-2024, 06:34 AM
                    by sam_sam_sam
                    After all of...
                    07-13-2024, 08:14 PM
                    DVR camera recorder switching power supply capacitor failure really
                    by sam_sam_sam
                    These cheap non brand capacitors at it again
                    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                    Well at least I have the cameras back on line I to try the...
                    01-22-2022, 06:28 PM
                  • Cicciotest
                    HP 250 G9 - short circuit 100%
                    by Cicciotest
                    Good morning guys.
                    I made a mess. I opened the new laptop, replaced the NVMe SSD, and closed it. When I plugged in the power cord, I saw the orange LED glow dimly several times, so I immediately unplugged it. I could also hear a strange buzzing sound coming from the laptop. Then I opened it again, and only later noticed that underneath the SSD was an aluminum plate that touched practically all the underlying components... what a disaster. I still don't understand how I didn't notice. Anyway...
                    I thought, okay, I'll just remove the plate and go. But now the power LED won't even...
                    10-17-2025, 12:23 AM
