Replacing SBL1040 and FR302 with 1N5407 3A ?
  • bianchi77
    • Jun 2016
    • 1121
    Guys,
    Is it possible for me replacing SBL1040 and FR302 with 1N5407 3A ?
    I have some 1N5407 on my hand..
  • bianchi77
    • Jun 2016
    • 1121
    Re: Replacing SBL1040 and FR302 with 1N5407 3A ?
    maximum recovery time for FR302 is 150ns and 1N5407 = 1500ns...10x slower...
    but is it enough for switching speed of the supply ?
    • bianchi77
      • Jun 2016
      • 1121
      What's the switching frequency ?
      • CapLeaker
        Leaking Member
        • Dec 2014
        • 8296
        I think I did answered that already in the other thread. If there is a fast recovery diode in there you need to replace it as such. A normal rectifier diode can't keep up with the pace. You just cant replace the SBL1040 (Schottky) or the FR302 (fast switching) with a 1N5407 and think all is ok. The diodes will blow.
        • bianchi77
          • Jun 2016
          • 1121
          In which post ?
            • 31161
            UF5408 may work
            • bianchi77
              • Jun 2016
              • 1121
              so it will not work on 1N5407 ? or it works ?
              • Andrew F. Ali
                • Jan 2014
                • 2450
                • Trinidad & Tobago
                No...It will not work....the 1N5407 will overheat and burn almost immediately....CapLeaker is 100% correct.....the FR302 could probably be replaced by the UF5408 as stj suggested...
                • bianchi77
                  • Jun 2016
                  • 1121
                  Ok, I need to wait then...thanks guys
                    03-31-2024, 02:12 PM
                    07-01-2024, 06:34 AM
                    After all of...
                    07-13-2024, 08:14 PM
                    DVR camera recorder switching power supply capacitor failure really
                    These cheap non brand capacitors at it again
                    Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
                    Well at least I have the cameras back on line I to try the...
                    01-22-2022, 06:28 PM
                  • michel74
                    How does this switching PS work ?
                    by michel74
                    Yes ! How does this switching PS works ? :-)
                    I understand (not in deep, of course) the switching PS principle; typically, I'd expect to get a VCC just to "feed up" the STR or the Switching regulator, but I cannot figure how this VCC is "created" (on a TV switching PSU, I often see some cascaded resistors, but here, I believe that one of the transformer input should make the permanent VCC, but I cannot figure where )
                    Thanks for your help. I already wrote some explanation of what I was having and did some measurements here ...
                    11-02-2023, 12:35 PM
