Corsair HX1000 not powering on
  • Gabriel
    • Jan 2010
    • 620
    • Norway
    Nothing happening when powering on this psu, fuse is ok and I do have power both in and out of the rectifier. I cant find a short between 3.3, 5, 12v1 or 12v2 either.
    Any ideas how to proceed ?
  • Behemot
    • 4845
    • CZ
    Re: Corsair HX1000 not powering on
    Do you have stand-by rail?
      • 31015
      it probably died from a lack of oxygen!
      seriously, they need to start putting these 600w+ psu's in double-height cases like the old days.
      pushing it all together like that is bullshit.
      • Behemot
        • 4845
        • CZ
        It was about prestige to have 1kW unit back than so they had to try
        • Gabriel
          • Jan 2010
          • 620
          • Norway
          Yes I do, it's at 5.131V and pson is 3.513V.
          Hehe you might be right, hopefully with some fresh oxygen I will be able to get it back to life.
          • Gabriel
            • Jan 2010
            • 620
            • Norway
            Back from vacation and have some time to play with this psu again, I'm taking the boards out of the casing to have a look on the underside.
            Any suggestions for what to check while I'm at it ?
            • Behemot
              • 4845
              • CZ
              I'd guess some small SMD components on the feedback. There are shitloads of them, this is lately the usual condition for which PSUs die. The more complicated it is the higher the chance something goes wrong.
              • softm
                check high voltage on filter capacitors.
                Than check main dcdc converter ic (what is it? ) power voltage.
                • Gabriel
                  • Jan 2010
                  • 620
                  • Norway
                  I do I have 330V on both main capacitors so both rectifiers are working, the psu has a monitoring ic from Siti, a ps229.
                  • Gabriel
                    • Jan 2010
                    • 620
                    • Norway
                    Forgot to mention, the ps229 is provided 4.5V
                    • Gabriel
                      • Jan 2010
                      • 620
                      • Norway
                      I tried to heat up main and and riser board components with a heatgun but it made no difference, didn't turn on using freeze spray either.
                      Borrowed a flir one and took some photos, as you can see both 500W supplies heat up in the same place around primary capacitors and both riser cards to the left of main capacitors heat up equally.
                      • UHU
                        • Sep 2016
                        • 35
                        Had a series of Corsair Power Supplies fail.
                        First was an HX620 failed at 2.5 years of age (5 Year Corsair warrantee) wouldn't start PC one day contacted Corsair technical help by telephone and was sweet talked into putting a 13Amp fuse in the plug which resulted in a shower of sparks out of the back of the PSU onto my face as I was plugging the mains back in to the PSU which also tripped the Earth fault RCD protector and Circuit Breaker MCB in my house fuse box - next was the...
                        Corsair AX850 exploded at switch on (with shrapnel strewn throughout PC case) at 18 months of age (7 year Corsair warrantee) had double factory seal stickers (one almost exactly stuck over the top of another sticker) - did corsair sell me "B" stock/a refurbished PSU?
                        Another Corsair AX850 (single stickers this time) just over a year old then suddenly no start with powerful burning smell - then....
                        AX860i TEN months of use only - total hell using the included digital link to USB interface gadget to control the PSU fan behaviour using Corsair supplied windows software - managed to get the fan to run constantly as I wanted for reliability BUT only from cold boot - any subsequent auto hibernation and the fan would never run again until a cold reboot - eventually AX860i would not allow PC to start until you had applied mains power and waited for an hour then PC would finally start.
                        Finally couldn't take any more suspense with Corsair and bought a Seasonic P1200 1200W PSU 80+ Platinum in 2014 with a MANUAL switch to make the fan run slowly all the time and so far all is OK.
                        Since then have got rid of all my Corsair Memory chips etc. as well - there are better brands out there!
                        I managed to send them all back to Corsair for warranty replacements and then sell off the brand new complete retail boxed Power Supplies they sent me under warranty - you might be able to do that yourself.
                        I know Seasonic was the manufacturer for the Corsair HX620 but not the others which were far worse - who is the manufacturer Corsair are using for the one you are working on?
                        Exploding Corsair PSU's were part of the reason I got more involved in fixing things/capacitors etc. the disruption and hassle every single time a Corsair PSU went Ka-Boom was such a waste of time it makes you realise it is useful to carry out reliability upgrades as well as the actual repair.
                        However some of the capacitors for the Corsair PSU's were listed at around £30 at RS Components with no real viable alternative / substitute part so a pair of those £30 capacitors suddenly makes cashing in the warranty very appealing!
                        PS Love the concept of using the Thermal Imager to look for heat anomalies as a clue.
                          • 31015
                          £30 caps? got a part number / type?
                          • Gabriel
                            • Jan 2010
                            • 620
                            • Norway
                            This one is built by Channel Well Technology (CWT).
                            • Behemot
                              • 4845
                              • CZ
                              Eh, 30 pounds, are you kidding me? That's already more than half the price of a used, working unit.
                              • UHU
                                • Sep 2016
                                • 35
                                Part number for an item I did not buy - sorry not from 6-7 years years ago!
                                It was from the first AX850 (the one that exploded).
                                It was one of the (from what was left of it) hefty sized capacitors inside - one of which (literally) went Ka-Boom - therefore replaced the exploded AX850 PSU under the manufacturers warranty (had to ship it out to the Corsair Netherlands Return center first - they accept just the PSU alone without any modular cables etc.) and eventually sold its identical replacement off to get it out the door and away from me!
                                Is Channel Well Technology (CWT) known / well regarded?
                                Some of these OEM manufacturers Corsair (and others) use do not even have a website and like to stay well hidden - which does make you wonder about them.
                                Just looked at Amazon UK
                                https://www.amazon.co.uk/Corsair-CMP.../dp/B00154QAXQ
                                if this is the same PSU it is no longer sold but it does mention that Corsair give a FIVE year warranty on your PSU - could be a way of turning a PSU doorstop into something useful/cash - if Corsair no longer make it Corsair can probably no longer supply you the same item under warranty which might be a good thing?
                                Check first what Corsair are planning to send you as a replacement before you ship them anything.
                                  • 31015
                                  chances are the part was £5 and you didnt notice it was a "u.s." item that invokes an £18 shipping charge!!
                                  • UHU
                                    • Sep 2016
                                    • 35
                                    Well either way it still created a barrier (I am not paying that!) to repairing the PSU - 6 years ago alternative capacitors in the right values and life ratings etc. were not easily available in the UK so I didn't waste any time dwelling on it - I just warranted it!
                                    At those prices I realized it was total waste of my time to even attempt a repair - Corsairs PSU had created a problem so I found the most efficient way was to dump the problem back onto Corsair by actually cashing in on Corsairs Warranty.
                                    If you ask Corsair nicely they will arrange a UPS Courier pick up at their cost to ship it to the Netherlands - then they ship one to you from Hong Kong by UPS - once did a (refunded later) charge card deposit on one of those PSU's so did not have to wait for mine to first get to the Netherlands and be processed - Corsair just shipped one immediately from Hong Kong.
                                    Got sick of Corsair when their AX860i had a built in test switch that lit up an LED when you pressed it and the manual said something like test it before you fit it with test switch - well when it failed as well guess what Corsairs test switch still lit the LED to indicate test passed! What total rubbish - the test switch implies Corsair PSU's need to be tested before being fitted implying that Corsair don't have much faith in their own (outsourced) product - I expect a brand new PSU to work and not to be in need of a pre-fitment test as Corsairs manual recommends!
                                    Anyway who in this thread is going to suggest an actual solution to fix the Thread posters PSU and get their Corsair PSU working again? That is after all why they started the thread in the first place.
                                    Personally my suggestion is to use the Warranty to get a new one then sell it off as brand new (it will be) and buy a different make of PSU - it worked for me!
                                    The Thermal Imaging Camera was a good idea - but who will actually give the winning suggestion of exactly how to fix it?
                                    If nobody has any worthwhile suggestion on how to actually finally solve the original problem by fixing it - Warranty it! Problem solved.
                                    • Gabriel
                                      • Jan 2010
                                      • 620
                                      • Norway
                                      Wish I could let Corsair have the problem but I bought this psu a few years back defective so I will keep working on it
                                      • h0m3w0rk
                                        Random Shutdowns/Startup Failure with Corsair SFX 450
                                        by h0m3w0rk
                                        I'm encountering a frustrating issue with my Corsair SFX 450 power supply. After an undefined period of operation, my PC will either suddenly restart or, in some cases, it won't start at all until I disconnect the power cable and reconnect it. This erratic behavior occurs intermittently, making it difficult to pinpoint the exact conditions under which it happens.
                                        For context, I have tested the PSU using an electronic load at 150W, and under those controlled conditions, it functions flawlessly. This leads me to...
                                        02-09-2025, 03:19 AM
                                      • valvashon
                                        LG 55UH6150- trouble powering up, then half lit screen (pictures!)
                                        by valvashon
                                        The 55" LG has been in the basement for a few months without being used. Turned it on yesterday, set came on as it should and showed a complete screen for about 5 seconds (was on a broadcast channel but no antenna was connected), then the screen went mostly dark with about 1/3 of the screen on the right lighting up with brighter lines in that lit part (sorry, no pictures of that). Power LED was cycling too, preventing the TV from fully powering up.
                                        Pulled the back off, all boards looked OK. Pulled the LED connector, turned the set on to see if it would power up but I don't belive it...
                                        11-24-2024, 12:08 PM
                                        Corsair CX750M [Model 75-002019] - burned output toroid inductor
                                        by momaka
                                        Looks like I may need a little help from the PSU experts (or anyone really! ) I have a Corsair CX750M (Model 75-002019) that I picked up for free about 4 years ago. This is the PSU:
                                        So here’s what’s strange about this one: it appears to work normally (normal output voltages) and any PC is stable with it. However, after a while (typically 10-20 minutes, but time can vary depending on the load), there is a sweetish smell of burned magnet wire insulation emanating from the PSU. Upon opening the PSU after this happened (many times), I was able to confirm...
                                        09-19-2021, 08:44 PM
                                      • DarKHawK
                                        Asus 2021 ROG Strix G17 G713 not powering on and not charging.
                                        by DarKHawK
                                        I have an Asus 2021 ROG Strix G17 G713 that is not powering on and not charging. Board number is G533-6050A3250201.
                                        When plugged in, I found that the 3.3v/5v regulator was getting extremely hot, so I removed, next I found a short on the 3.3V rail. Removed the two 3.3v mosfets and found one of them shorted, but still the short on the rail did not clear. Then I injected voltage at that rail, and found out that U60400 the 2.5v rail was also getting hot. Removing it changed the short from 0 ohms to about 5-6 ohms, then I remove a bunch of other suspect components but that did...
                                        07-11-2025, 05:24 AM
                                      • serious_electron
                                        Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                        by serious_electron
                                        Hello Everyone!
                                        I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                        06-28-2025, 02:57 PM
