Digimess HV30001 repair - 300V 1A bench DC power supply
    Re: Digimess HV30001 repair - 300V 1A bench DC power supply
    Originally posted by stj
    JST-VL series connectors.
    20A 600v
    I'm talking about connectors you can easily screw in or use test leads with.
      • 31067
      4mm shrouded jacks - like on meters?
      some of those are rated 1000v and upto 32A
      http://www.rapidonline.com/4mm-single-pole-connectors
        It's pretty difficult to find ones that will allow wires to be mated to easily. Anyway, this is a project that will be done after 50 others on the list.
        What I really want is something like this unit with these kinds of jacks on it:
        http://www.ebay.co.uk/itm/Electronic...AAAOSwF1dURMd2
          • 31067
          insulated binding posts?
          http://www.rapidonline.com/rvfm-4mm-30a-terminals-63907
            You'll find those are typically not rated to 300VDC, more likely something around 60VDC. They'll handle it fine for most cases, but you don't want the exposed conductors anyway when you're dealing with anything around that kind of range. This comes down to insulation ratings in the plastic and the design with the exposed conductors which electronic loads don't generally have.
            The other issue - is handling both extremes of high voltage and high current. You can get 400V rated MOSFETs cheap, but on resistance is pretty bad - like 0.1 ohms is the minimum for anything cheaper than "silly price". And if you want say 30A full load current, you're going to get a load of voltage drop across just one FET. So you need many in parallel. And this increases gate capacitance and control loop design complexity considerably.
              • 31067
              those are shrouded and rated for 250v
              • Behemot
                • 4845
                • CZ
                #27
                Originally posted by tom66
                I pulled the bulk mains caps which are rated at 1000uF 200V a piece while replacing the transistors on the heatsink. To little surprise they test considerably below rating at 850uF each, so they are probably 820uF caps.
                That's still within +-20 %. Most even new large-can caps I've ever measured with ESR Micro or UNI-T UT210E always showed lower capacity. No reason to call them fake right away. Usually only Rubycon caps measure close to full.
                • shamsudeen
                  Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                  by shamsudeen
                  Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                  I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                  i know that in linear power supply the noise will be very low comparing to SMPS supply....
                  07-19-2025, 07:14 AM
                • rabsonnjala
                  LENOVO IDEAPAD 100 works only on bench power supply
                  by rabsonnjala
                  Hie I have a Lenovo laptop
                  Lenovo Ideapad 100-14IBY AIVP1-AIVP2 LA-C771P rev 1.0
                  it's working only on the bench power supply when I put the battery it doesn't power on. when I also use the original charger it doesn't power. the batter Is fully charged, I used another laptop to charge the battery. but when I use a bench power supply it works perfectly
                  below are my readings
                  with the original charger only
                  JBATT1
                  PIN1 0.22V
                  PIN2 0.22V
                  PIN3 0.45V
                  PIN4 0.45V
                  PIN5 O.43V
                  PIN6 0V
                  PIN7 GND
                  PIN8...
                  11-20-2021, 08:32 AM
                • FrancescoV
                  Onkyo HT-R390 no sound output, video output ok
                  by FrancescoV
                  Good morning everyone,
                  I'm trying to repair an onkyo ht-r390 that has no sound output, despite the volume being at maximum, the rest seems to work; the video output signal (coming from an hdmi input) is present, but the audio is absent. Similar situation if I send an audio signal from any input I have no output.
                  The firmware reported is the following:
                  M:1.00/11107BLP
                  D:?.??/????????
                  O:1.00/11107AL
                  The DSP firmware given the question marks seems corrupt.
                  On the BCHDM-0678 - 25140678 - QPWBCHDM0678A0 board the chip that usually seems...
                  05-11-2025, 02:59 AM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
