PowerMust 600 dead
  • alindumitru46
    • Aug 2015
    • 255
    • Romania
    PowerMust 600 dead
    I have this Mustek PowerMust 600 UPS for years, received as defective.
    Now, waiting for some parts to repair motherboards/videocards already presented, I decided to seek competent help here to fix it.
    The fuse was blowed but I replaced with a similar one.
    UPS battery was drained, but I replaced it with a good battery, charged to 12V.
    I inspected visually the board and there are no over hot traces of circuits or swollen capacitors; verifying CET / CEP50N06-680FZ not look shorting.
    Unfortunately it does not start at all. No beeps, no led light. No communications of the UPS with PC.
    I did measurements on CET mosfets and found 2.87V for top3 and ~ 7V for last mosfet(gate to drain, gate to source). The LM 317T MOSFET does not look voltages at all.
    Any ideas?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: PowerMust 600 dead
    That LM317 is a linear voltage regulator, NOT a MOSFET.
    Pin 1 = Adjust
    Pin 2 = Output Voltage
    Pin 3 = Input Voltage
    Check datasheet for details. That LM317 is perhaps used to power the logic circuits? And with no voltage on the input pin, maybe that's why the UPS is dead?
    Try tracing the input and output of that LM317 and see where they go to. Perhaps that might give us a clue. As would pictures of the solder side so we can help you trace stuff.
    Lastly. check the small TO-92 transistors. When severely overloaded, they can sometimes go partially or completely open-circuit without looking burned at all. So definitely check the Base-Collector and Base-Emitter voltage drops with a multimeter set to continuity/diode test. Do this with battery and power DISCONNECTED from the UPS.
    • alindumitru46
      • Aug 2015
      • 255
      • Romania
      I checked all CET-CEP50N06-680FZ for continuity/diode test, I think all are ok.
      And the transistors seems to be ok, no continuity. I checked and all diodes, additionally, looks in good condition.
      The values from spreadsheet are measured by diode test.
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Like I said, start with the LM317. That is a linear regulator and likely used to provide a clean voltage for the logic circuitry. Pin 3 is the input voltage and Pin 2 is the output. First see where the input voltage is supposed to come from and then see where the output goes to.
        As for the 2SC1815 TO-92 transistors, those are NPN BJTs. Here's how to test them:
        1) Set multimeter to diode test
        2) Put red (+) multimeter probe on Base pin (pin 1)
        3) When you put black (-) multimeter probe on Emitter pin (pin 3), you should get a reading of about 600 to 800 mV (or 0.6 to 0.8V depending on multimeter models)
        4) When you put black (-) multimeter probe on Collector pin (pin 2), you should get a reading of about 600 to 800 mV (or 0.6 to 0.8V depending on multimeter models)
        For PNP transistors, simply reverse the multimeter probes and repeat the same steps above.
        That said, are you sure that "MPS3 097A" is not a MPS3904? Because if so, that would be another NPN transistor.
        Finally, the "MC19L 05ACP"... check the number again. It could be a MC79L05ACP. The "79L05" is a common -5V regulator. Comes in various cases - from TO-220 to TO-92.
        Oh, and check all larger resistors for open-circuit or higher than 5% tolerance. Some may be fusible, so they will go O/C when overloaded severely.
        • alindumitru46
          • Aug 2015
          • 255
          • Romania
          The only correction is for MC79L, otherwise everything is exactly as I wrote on each row.
          I completed xls file with the values obtained and links for the datasheet.
          For backside no pictures until now.
          • Behemot
            • 4845
            • CZ
            Check small caps, many of them tend to go bad in these craps. Be extremely carefull when soldering this - they make the traces from some shit and it is incredibly easy to tear them off. Often you remove a cap and part of the trace just disappears.
            • alindumitru46
              • Aug 2015
              • 255
              • Romania
              Yep, sir!
              So fast the true problem with routes arise... one of the smallest capacitor is victim already.
              I measured and put the results. Obviously I'll try to change them quickly as I can.
              I have 2 solid capacitors, is a good option?!
              • Behemot
                • 4845
                • CZ
                Seems like they are already going bad, though not SO bad it should not work, yet.
                These are usually crappy 85° C generral purpose, polymers won't do good. Use 105°C GP caps like Chemi-con KMG, Nichicon VZ, Rubycon PX.
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  It's not unusual for small general purpose caps to show "high" ESR in the range of 1-2 Ohms. Virtually every 100 uF, 16V cap out of the Xbox 360 motherboards I've tested has read at least 1 Ohm ESR (these are usually Chemicon KMG, Nichicon VZ, and/or Rubycon YXA).
                  As I stated in my earlier posts, find out why that LM317 voltage regulator doesn't have any voltage going to it - that is, if you want to fix/troubleshoot this UPS.
                  • double_DD
                    How can I be sure that my EC chip is dead?
                    by double_DD
                    As the title suggests, how can I be sure that my EC chip is really dead?
                    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                    03-12-2025, 07:47 AM
                  • disorder
                    ps5 edm-033 dead after hdmi/usb ports destroyed
                    by disorder
                    hello guys,
                    i need help to repair a edm-033 ps2
                    history : as always hdmi port and usb ports destroyed after unplugged
                    after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                    so i changed it
                    now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                    but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                    i don't see any projection of liquid metal on pcb.
                    01-14-2025, 12:48 PM
                  • zunasthegreat
                    Chieftec GPS-450-AA with dead 20N60C3
                    by zunasthegreat
                    Hello everyone hope all doing well!
                    I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                    09-01-2024, 07:12 PM
                  • Beton
                    Finding a dead short component
                    by Beton
                    Hi guys!
                    I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                    So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                    I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                    I have a bench PSU and if I try to inject voltage the voltage...
                    12-10-2021, 01:05 PM
                  • FiguringITout
                    MSI Raider GE75 - Not posting, probable dead CPU
                    by FiguringITout
                    Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                    Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                    07-25-2024, 07:27 AM
