Why don't we see bad line input capacitors?
  • berniedd
    • Mar 2007
    • 119
    I've yet to see a report on bad line input capacitors. The ones after the diode bridge connected to AC. Is it because of the low line frequency (60 Hz)?
  • Harvey
    • Apr 2007
    • 264
    Re: Why don't we see bad line input capacitors?
    They are made to a higher standard - they have to be to withstand the high voltages, and they are relatively low value for their size, and generally they aren't under as much electrical 'stress' as VRM caps get.
    I've seen a few fail before now in TVs etc., but its always been simple age related faults rather than anything catastrophic.
    • Wizard
      • Mar 2008
      • 2296
      True. I have seen rare few that failed early in newish TVs. Some of these big failed cap either vented it's top or can hear or feel it rattle when shaken after taken off from board.
      Cheers, Wizard
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        the crappy ones fail often.
        ones from reputable brands you find bad are either very old or were killed by overvoltage/temp.
        • EasyGoing1
          Reading input and output of bridge rectifier on the same scope?
          by EasyGoing1
          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
          06-26-2022, 12:52 AM
        • ugamazing
          820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
          by ugamazing
          So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
          1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
          2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
          04-10-2024, 08:06 AM
        • feliks912
          ThinkPad T490 20N2000CSC NM-B901 no signs of life - short on 5V SMPS, ThinkEngine-3 hot - *speculations*
          by feliks912
          Attached schematic 🙂.
          Laptop gives no signs of life. No fan and no CPU heat.
          Think Engine BD4179MWV is hot on plugging in *AND* pressing the power button.
          Discovered short to ground on VCC5M power delivery IC NB690GRP (5 volt line, not the high current VCC5M_PD) which is one of the ways that chip is powered. I'm puzzled.
          Nothing else is warm on the board. CPU resistances are OK, 9V VSYS line is present from the BMIC. All misc and cables are disconnected.
          What do you guys think happened? I've got two theories:
          If the...
          I think ThinkEngine shorted first
          50.00%
          1
          I think 5V SMIC shorted first
          0%
          0
          I think something else happened
          50.00%
          1
          05-07-2024, 04:44 PM
        • dragon3x
          by dragon3x
          power on.
          Here are some examples :
          switching supply area).
          than 6.3 V.)
          03-21-2025, 02:46 PM
        • Mark R
          The Overseas Only Kenwood Model KR 790
          by Mark R
          I am Repairing this unit. It had many problems. One major one was the power transformer being about 4-5 volts low on the main B+ line which called for 66.5 Vols after the Main Filter caps but only showing about 62 Volts. Caps and the 5 amp Diode bridge were replaced which helped slightly.
          The other strange problem was the small secondary winding from the PT which supplies 18 Volts AC to the "FM FLUORESCENT DISPLAY" circuit, and the small winding that supplies 8 Volts AC to the push button grain of wheat lamps. Those voltages were down from 18 Volts to 16 volts. Which was...
          09-23-2025, 08:27 PM
