Modifying AT or ATX SMPS for 15V instead of 12V.
  • Wizard
    • Mar 2008
    • 2296
    One notebook I'm aquiring doesn't have power brick needs 120W on 15V (8A)
    One thing I was wondering about the doughnut shaped coil that have multiple voltage windings through it to the capacitors from the transformer. What is it? I forgot that term.
    I'm not going to use other windings but leave it alone for feedback and add one or few windings to the 12V winding on the transformer to get 15V output. Possible?
    Cheers, Wizard
  • linuxguru
    • Apr 2005
    • 1564
    Re: Modifying AT or ATX SMPS for 15V instead of 12V.
    It's fairly easy to modify an AT SMPS for +/- 13.2 V, as long as the other rails are left unregulated/unused. It requires only the removal/alteration of a few voltage-divider resistor networks that control regulation and overvoltage protection. You may have to remove the +5v power rectifier, but it's usually not necessary.
    If you want +/- 15v, some complications arise because the power for the TL494 controller IC is drawn from the same windings as +12v - and this voltage will increase along with the rail voltage, which can cause certain TL494-clones to fail. The solution is to add a suitable power zener in series to drop the rail voltage for the controller to a convenient voltage, but this needs experimentation on a case by case basis. Something between 5.6v and 8.2v in series is usually about right.
    In both cases, it is not necessary to add any windings to either the transformer or the secondary inductor.
    • Wizard
      • Mar 2008
      • 2296
      Excellent!
      I'll pull up the 494 datasheet and any recommendations on tweaking the resistors network to output 3V more? Like a "formula" to figure out the new value?
      I recall that brand name like TI and like TL494 is specified to stand up to 18V unregulated input supply pin. Been awhile last time I consulted the datasheet.
      Cheers, Wizard
      • Briesmith
        Can High Side damage on an SMPS get across the Transformer to the Low Side?
        by Briesmith
        I have a blown smps and I am looking for some reassurance as to the amount of diagnosis I have to do. It blew the instant I plugged it in not under any load.
        As you can see from the attached pix, the damage is located around the main or bulk capacitor (since removed for testing) and the resistor array/network that drives it (the bunch of SMD components to the left of the YAMAHA YC775 AMPS logo). The burn mark on the frame clearly shows the pins of the capacitor. And, for the avoidance of doubt, there is no way the board could have contacted the frame, it was correctly mounted on...
        05-06-2023, 09:36 AM
      • peter_wheat
        Looking for SMPS flyback tranformer TAM TO-5622 or equivalent?
        by peter_wheat
        Hi All,
        I'm looking for a SMPS flyback transformer TAM TO-5622, or equivalent, or any information on it? Company is Tamura Corp (https://www.tamuracorp.com). It has Primary, Secondary, and Auxiliary windings. Have emailed the company, but no info back yet. It is out of a Makita DC24SC battery charger.. This transformer has a burnt out the primary (caused by a failed MOSFET). Secondary, gave me a reading of 0.49 Ohms, and Auxiliary a reading of 0.93 Ohms. I took it to bits, thinking I might try and re-wind it, but it was more complex than I realized, and had difficulty removing...
        08-28-2025, 02:03 PM
      • mikey5791
        Is it possible for transformer substitution?
        by mikey5791
        Got this local made DC power supply (12/14V) given free as the transformer has melted. There is no marking or indication to identify what type or rating of transformer used.
        Fyi,. I had a busted autogate mainboard with transformer with marking 13-0-13 . Is this the 13v dc type transformer?
        My questions are
        1. How do i test to see if the transformer is in good working condition?
        2. Can this transformer (marking 13-0-13) be used to replace the melted transformer on the DC power supply?
        Hope you guys understand what i was asking. My intention is...
        11-03-2022, 02:11 AM
      • PlayerOne
        Velodyne SMPS, power transformer
        by PlayerOne
        I need help in finding a schematic or otherwise identifying the electrical characteristics of a transformer in a SMPS having the following marking:
        042-010214-000ZR
        ELY 1317
        A photo of the transformer is attached. In particular, this is a PCB mounted transformer and I need the pinout.
        I've tried Google searches of various portions of the part number with no luck, however managed to find posts with photos of this transformer having the same markings, except for the numbers following the “ELY” which leads me to believe they must be date code...
        03-31-2020, 12:37 PM
      • dennis_elx33
        3PHASE STEP-DOWN Transformer in Check
        by dennis_elx33
        Hello All,
        i would like to post an interesting topic regarding 3-phase stepdown transformer which we suspect to cause an overcurrent (138A) which resulted to power tripped off of the HV power supply (80KV output).
        Problem statement: Power tripped Off
        Initial Problem: Found 2 IGBT and 2 rectifier diodes shorted (burnt).
        Action Done:
        1) Replaced the faulty parts with good spare.
        2) Measured impedance of the 3phase input lines and found that L2 to L3 has 23.3ohm while other pairs are 51Kohm. This pins will...
        12-02-2024, 06:52 AM
