CoolerMaster RS-450-ACLY PSU issue?
    master hoarder
    • May 2008
    • 12175
    • Bulgaria
    Re: CoolerMaster RS-450-ACLY PSU issue?
    Okay, so upper CPU VRM MOSFETs are not shorted, at least.
    I just had another idea before digging into further motherboard troubleshooting...
    Connect that MSI motherboard to a PSU (doesn't matter if it's the Cooler Master or some other one), and with everything connected properly, short the PSU's green (PS_ON) wire to ground. Does the PSU stay on, or does it do the "short spin of fans" again?
    Also, I would advise you disconnect the HDD from that PCs while doing these tests. Every time the PSU powers ON and OFF, the HDD goes through a power cycle (or possibly at least counts it), so it is not so good for it. Once you get that motherboard running, then you can connect the HDD again.
    • alindumitru46
      • Aug 2015
      • 255
      • Romania
      Ok, the CM psu used keep "power on" without booting mobo....
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        That rules out short-circuit on the motherboard. However, the circuit on the motherboard that controls PS_ON may have some problems. Was this motherboard ever running before? And if yes, when did it stop working?
        • alindumitru46
          • Aug 2015
          • 255
          • Romania
          I must admit that the test was wrong approached, because MSI 770T-C45 is not fully functional (has moments when lose BIOS settings and gives a long beep and two short and recovers after 2-3 restarts), because I considered the starting sequence does not necessarily require a verified mobo.
          MSI 770T-C45 will be a subject of diagnosis, after a perfect cleaning and strict visual check with a magnifying glass.
          Therefore I rebuilt tests with DFI P35 T2RL Blood Iron motherboard, E6300 cpu, 2x1GB Team Extreem dark , Asus HD2400 Pro, the default computer psu - Codegen 350W as "another psu":
          1. CM psu 24pins+12V cpu: short spin of fans and shut down;
          2. CM psu 24pins only: short spin of fans and shut down;
          3. CM psu 24pins+12V cpu from another psu: short spin of fans and shut down;
          4. another psu 24pins+12V cpu CM psu:short spin of fans and shut down;
          5. another psu 24pins+12V: normal boot to Windows.
            master hoarder
            • May 2008
            • 12175
            • Bulgaria
            So the Cooler Master still does the same thing now, even with the DFI board?
            • alindumitru46
              • Aug 2015
              • 255
              • Romania
              #26
              Yep, almost the same problems DFI P35 T2RL Blood Iron motherboard...
              DFI nF4 Ultra-D Expert motherboard was suspected for problems, the MSI mobo was received recently and did not have time to dwell on it, but I thought it's okay to use to verify the CM psu.
              DFI BloodIron go smoothly with Codegen psu of 350W, even an ock of E6300 CPU from 1800MHz to 2000MHz for (I tried it 2-3 years ago and she can run loose 500MHz FSB).
              I do not know what to say ...
                master hoarder
                • May 2008
                • 12175
                • Bulgaria
                #27
                I guess you should try a recap on that Cooler Master PSU then. In particular, change all of the very small caps on the secondary side first. Perhaps one of them is messing with the PS_ON or PG signals. It's rare, but I recall someone did fix their PSU here by doing just that. If not, then change the big caps too.
                • rounin
                  MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                  by rounin
                  🛠 Original Issue
                  ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                  04-19-2025, 01:18 AM
                • ugamazing
                  by ugamazing
                  12-17-2024, 07:05 PM
                • elmark
                  HP 15-cw1002ua strange keyboard issue
                  by elmark
                  HP Pavilion 15-CW1002UA
                  S/N 5CD0251CBC
                  P/N 7KE54EA
                  Hello guys!
                  I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
                  It powers on OK and has no other issues except the following:
                  • CAPS LOCK does not work at all
                  • Fn button toggles Flight Mode
                  • When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
                  • (with SHIFT pressed: 't%' and 'y^' respectively)
                  I initially thought it was a keyboard malfunction (internal short, etc.),
                  but when I press and hold...
                  06-27-2025, 01:10 AM
                • Simone Vergani
                  Alienware 15 R2 Service Tag: DL7NN32 ISSUE (Battery is not charging)
                  by Simone Vergani
                  I'm experiencing an issue with my Alienware 15 R2 (Service Tag: DL7NN32). The laptop works perfectly when connected to the AC adapter — it powers on and functions normally. However, the battery does not charge. If I disconnect the DC adapter, the laptop shuts down immediately, as the battery is at 0%. I have replaced the battery with a new compatible one, but the issue persists. I also replaced the AC adapter with a compatible one, but the battery still doesn't charge.
                  To assist with troubleshooting, I'm attaching two power circuit schematics:
                  • Power
                  03-05-2025, 02:25 PM
                • wizard13
                  Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                  by wizard13
                  I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                  I have checked the forum and the available documentation but could not find a solution specific to my issue.
                  • Brand & Model: Dynabook Satellite Pro C50D-B-100
                  • Part Number (P/N): PYU13E-00C00PFR
                  • Serial Number (S/N): 22028896H
                  • System Configuration (SC): A1PYU13E1127
                  • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                  • Power Input: DC 19V –
                  02-28-2025, 02:43 AM
