Recapping of FSP Hexa 500
  • shakaboonga
    • Jan 2016
    • 5
    • RO
    I got this older Fortron Hexa 500 PSU pretty cheap, it seemed to be a good unit from a reputable manufacturer. My joy was quickly curbed after discovering that it is filled with CrapXon caps. Even the primary cap is a strange looking 270uf / 420v beast @ 85 deg. C. Everything looks OK, except for that primary cap which looks a tiny bit bulged.
    I have decided to recap it completely since I hate the guts of Capxon and otherwise the unit looks pretty solid. The only thing is that here I could only find the following higher quality capacitors:
    - Nichicon LGU2W271MELC (LGU series, CAP ALUM 270UF 20% 450V SNAP)
    - ELITE PL2W471MND3551 (PL series, 470uF; 450V; Ø35x51mm; ±20%; 2000h)
    - Samwha CE-330/450SNP (unknown series, 330uF; 450V; Ø34x45mm; Pitch:10mm)
    Which one should I choose for the primary? Price wise, Nichicon is more affordable than the others.
    Thank you .
    • 31020
    Re: Recapping of FSP Hexa 500
    go with the nichi i say.
    the samwha is CE series btw.
    • shakaboonga
      • Jan 2016
      • 5
      • RO
      Thanks for the input, I'll go with them. Regarding this PSU model, would it be a keeper after the recapping (e.g. are they known to contain any flaws besides the poor choice in caps)?
      Another thing I wanted to ask if you don't mind: In PSUs with active PFC iirc the voltage on the primary cap is pushed close to 400V. Judging by this, it would be a bad idea to use a 400-volt rated cap right? Cause those are an order of magnitude cheaper :P.
      • slybunda
        Elite Capacitors? (450v 47uf power board Toshiba Vestel TV)
        by slybunda
        anyone heard of these caps before? at first glance i mistook them to be Elna caps but closer look and it was elite. not sure if they are known failure prone brand.
        also they are 47uf and 450v. why are they so large in height? i can get replacement 450v 47uf caps that are a quarter the height. what am i missing here?
        if i were to replace them what should i be looking for?
        they are on the power board of a toshiba (vestel) tv power board.
        pic attached...
        11-13-2023, 06:33 AM
      • ChanHa
        Help me Resistor on FSP Hexa ATX 500w
        by ChanHa
        My ATX FSP HEXA 500W was broken, lost 5vol stand by , ic TNY 277PN is broken, and R26, but i dont know what is R26. Help me...
        06-04-2025, 08:44 PM
      • samoelec
        Trying to understand how to find best replacement cap for old parts.
        by samoelec
        Disclaimer: This is the first time I step into the realm of analog electronics and my natural language is not English, so please forgive me if I failed to use the correct terms when describing things.
        Recently I purchased a Tektronix TDS1012, a 20 years old product for cheap and I thought it could be a nice opportunity for playing (i.e. recapping) and learn something in the process.
        The power supply board is exactly the same from this post so I'll just steal it for now.
        I'm trying to find replacements for all those Lelon electrolytic caps, but then quickly...
        04-01-2024, 03:39 AM
      • proxneo
        Recapping Sony ICF-SW55 - verifying cap values
        by proxneo
        Dear reader
        I am performing a repair on a Sony ICF-SW55, which includes recapping (some) of the SMD capacitors on the mainboard. I am looking for verification of their values. At the moment, I'm 95% sure I've got the right values, but it is hard to find some official, credible or multiple independant sources on this.
        At the moment, I have selected replacements based on the following list of values:
        3 x 470uF 10VDC
        3 x 4.7uF 35VDC
        4 x 47uF 50VDC
        8 x 22uF 6.3 VDC
        1 x 220uF 6.3VDC
        5 x 100uF 6.3VDC
        Which...
        06-21-2023, 12:38 AM
      • jojo88
        LG LED (LCD) TV 50LN5600-UI flashes logo, red LED 3x blink
        by jojo88
        This 50 inch LG LED (LCD) TV was given to me not working. Powering it on, the logo flashes once for 1/4 second then black. Front panel red LED blinks 3x (I think... see below) then the LED turns off. TV stays on until I press the Power button again. There is an image on the LCD panel--I press the "Settings" button on the TV and this brings up menus I can see with a flashlight / torch.
        (The front panel red error code LED blink sequence is a bit confusing to me. The LED is on when the TV is off. I press the Power button and the LED *very briefly* goes off--maybe 1/10 second--then...
        03-29-2023, 11:20 AM
