Which optocoupler to buy?
  • mpadilla
    • Dec 2015
    • 24
    • US
    I must say it's great the amount of guidance that's available in this forumn!
    I have this LN32A550P3FS, that when plugged in the standby light blinks steady. Following on guidance from this forumn and others, I opened up the tv and found on visual inspection some capacitors were bulging. I replaced the capacitors minding polarity. I put the tv back together with same results of standby light blinking. By the way all voltages are correct after replacing capacitors except for the standby voltage. The board stamp says it should be 5.2 but it measures as 4.19. The power supply is BN44-00208A (PSLF171501B). I did more research and found this zip file and this post that basically state a certain optocoupler needs replacing. However, this zip file and post were for a slightly different model. But I believe the problem might be the same. I see in the schematic that the optocoupler is tlp781. When I search (digikey and others) many different types come up.
    Can someone possibly point me to the correct one to buy?
  • fzabkar
    • Mar 2009
    • 772
    Re: Which optocoupler to buy?
    I would check capacitors CB852 (the 5V filter) and CB802. CB802 filters the auxiliary supply for the PWM controller IC.
    Also measure the voltages between pins 1 & 2 and 3 & 4 of PC804S, but be mindful of the HOT side.
      From your link:
      http://www.electronicspoint.com/thre...2#post-1603408
      'Problem: optocoupler PC801S defective - replace. Then replace the RP809, RP810, RP811, RP812, RP816! Good luck! BART'
      That opto PC801S has nothing to do with low 5V STBY, that OPTO is used for turning on/off the rest of the power supply when the power supply get the PS-ON control signal from the main board.
      Opto PC804S is the one used for voltage regulation feed back to main tain 5V output.
      So chekc what fzabkar has suggested.
      • mpadilla
        • Dec 2015
        • 24
        • US
        I will test and get back. Thank you for the feedback.
          BTW, this series is know for bad C102 47uF 10V SMD Tantalum cap on the main board, one of the symptom is LED blinking continuously.
          For example:
          https://www.badcaps.net/forum/showth...911#post616911
          http://www.shopjimmy.com/catalogsear...t/?q=LN32A550P
          • mpadilla
            • Dec 2015
            • 24
            • US
            Thank you for pointing that out budm. Of course this tv has that exact board. I'll replace that cap on the main board and report back.
            • mpadilla
              • Dec 2015
              • 24
              • US
              Ok, I was super tired the first time I measured and it came out that the stby voltage was low. However, today I have had rest. I went back and re-measured everything. Here's the results. PS looks good to me based on measured values? I'm thinking now all I need is C102 as budm mentioned. Can you provide feedback?
              CNM801
              1 - B/L ON/OFF
              2 - ADIM
              3 - PWM
              4 - GND
              5 - SCHEMATIC SAYS 24V DETECT; BOARD STAMPED DET. 5V: MEASURED 5.5V
              CNM802
              1 - PWR-ON/OFF
              2 - N/C
              3 - ST-BY5.2V: 5.3V
              4 - GND
              5 - GND
              6 - GND
              7 - 12.8V: 12.3V
              8 - 12.8V: 12.4V
              9 - GND
              10 - GND
              11 - GND
              12 - GND
              13 - 5.3V: 5.2V
              14 - 5.3V: 5.3V
              15 - 5.3V: 5.2V
              16 - 5.3V: 5.3V
              17 - GND
              18 - GND
              19 - 12V: 12.1V
              20 - GND
              21 - 12V: 12.1V
              22 - 12V: 12.1V
              23 - N/C
              24 - N/C
              CNM803
              1 - 24V: 24.7
              2 - 24V: 24.7
              3 - 24V: 24.7
              4 - 24V: 24.7
              5 - 24V: 24.7
              6 - GND
              7 - GND
              8 - GND
              9 - GND
              10 - GND
              11 - N/C
              12 - B/L ON/OFF
              13 - ADIM
              14 - PWM
                At this point go ahead and replace that c102 cap, if you do not have it, you can use 100uF 10~16V LOW ESR lytics cap for testing by putting it in parallel with C102, notes: the bar marking on the C102 is the POSITIVE leg of the cap.
                • mpadilla
                  • Dec 2015
                  • 24
                  • US
                  Thank you for the advice! Unfortunately, out of all the components I have, I don't have a 100uF 10~16V LOW ESR lytics cap for testing.
                  I'll just order the C102 cap linked to digikey in the linked post. Thanks budm! I'll report back in a few days with my results.
                  • mpadilla
                    • Dec 2015
                    • 24
                    • US
                    Worked like a charm! After soldering the new c102 cap, TV is functional again. Thank you again for the guidance!
                      Thanks for the repair follow-up.
                      • japlytic
                        • Oct 2005
                        • 2086
                        Care should be taken in substituting the optocoupler since I have read in Power Integrations Application Note AN-14, the Current Transfer Ratio (CTR) of the optocoupler should be within a certain level (and not have an uncontrolled value) suitable for the controller; otherwise, the power supply could oscillate, or for too low CTR, excessive photodiode currents are required to properly control the controller duty cycle, and if CTR is too high, the shutdown latch or other protection features on the controller could be triggered during startup or load transients.
                        • fharris1977
                          Vizio D50u-D1 Dead Set No Standby
                          by fharris1977
                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                          12-28-2023, 10:25 AM
                        • Crystaleyes
                          Samsung BN44-00259A standby question
                          by Crystaleyes
                          Hi all.
                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                          08-11-2023, 05:15 AM
                        • psssst
                          Yamaha TSX 120 Standby Problem
                          by psssst
                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                          03-01-2024, 07:25 AM
                        • ChristianBr01
                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                          by ChristianBr01
                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                          04-23-2025, 01:48 AM
                        • reessi
                          JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                          by reessi
                          I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                          You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                          Years ago it had some bulging caps...
                          04-26-2021, 11:42 AM
