Been reading and researching on ways to improve the questionable caps used in the Silverstone SX600-G power supply. The issues with these power supplies tend to stem from a lack of airflow and cooling on the secondary side, along with the use of Teapo caps for the secondary. From my understanding (and please correct me if I'm wrong) the Teapo caps are at best, average quality, and when subjected to higher heat (like in this instance) they don't have the best reliability record.
Because of packaging constraints I need to use the SFX form factor. From a power requirement standpoint I also need a unit of around 550-600 watts. This Silverstone is the only SFX based power supply that is gold rated that meets those two requirements. The small size of the unit make cooling more a challenge, and the tight constraints have forced the secondary caps into a spot where there is not any airflow.
I believe this unit would perform well and be durable with a couple of modifications. The first being modifying the housing to get additional airflow over the secondary caps. This part I can do without too much trouble.
The second modification I think that is needed is swapping out the cheap Teapo caps for much better caps. This is where I need to gather more information from those more experienced and knowledgeable. I'm fairly proficient at soldering and desoldering, and I have a solder rework station. So that part I don't think I'll have any issues with. Where I could use some guidance would be the capacitors themselves, as well any kind of pertinent information relative to work like this. I would gladly take additional suggestions as well.
If I get some pictures of the two Teapo caps, along with their part numbers and so forth, and post them here, would it be possible for someone to advise me on replacement options? From my reading the following brands seem to be the best options
1) Rubycon
2) Sanyo/Nippon
3) Nichicon
4) Mallory
5) Panasonic
From my research I've also found that some brands and types of caps are better at handling heat than others, is this true?
My goal is to source premium caps to replace the ones that came with the PSU. I don't mind paying for the top tier, best available caps (I'll choose a $10 cap over a $3 cap if it's that much better). In regards to the work itself I've worked with capacitors a little before, and am somewhat familiar with discharging them, checking them with my meter, and in general, being safe around this stuff as I know it's deadly. But I'm again very open to any suggestions from those in the know about how they would go about this procedurally.
I'm here to learn, so any information people are willing to share would be very appreciated.
1) Rubycon
2) Sanyo/Nippon
3) Nichicon
4) Mallory
5) Panasonic
