Meanwell SP-100-24
  • hbizri
    • Nov 2015
    • 6
    • KSA
    Meanwell SP-100-24
    I am looking for service manual for a Meanwell SP-100-24, I have one that I am trying to repair myself, I collected many notes on this, tested all components, still dead. I am new to this but I am learning thru this.
    I hope of any help or support on this.
    Regards,
    • 31047
    Re: Meanwell SP-100-24
    service manual? i dont think they exist - even the maker probably only has a schematic and board layout
    • hbizri
      • Nov 2015
      • 6
      • KSA
      Schematic Diagram will be fine, I found one for the SP-320-24 but it is not clear.
      Any repair Tips/notes on this?
      • Sparkey55
        • Jan 2010
        • 1523
        Can you attach some photos of the PSU?
        • hbizri
          • Nov 2015
          • 6
          • KSA
          I applied 20VAC, and tested the waveform on the filter CAP C5, show proper DC ... I checked the pin7 on the PWM shows shorted it should be the VCC.
          I tried to identify the components as much as I can as per the attached photo,
          but still I need more info identifying the following:
          1- Startup & run DC DC components.
          2- location of the B+ in the sampling circuit. F/B
          3- How to check the regulation circuit? & identify the sampling, error & feedback circuits.
          4- Identifying the protection circuit? SP, OVP is it only the PWM?
          5- PFC circuit ? only D1 & Q1?
          Regards,
          Hani
            • 31047
            make sure it's not just that shit chipsocket.
            it's rare to find a socket in a psu unless it's a machined-pin type because of contact problems or chips working lose as they get old.
            • hbizri
              • Nov 2015
              • 6
              • KSA
              The IC U3-FAN4803 socket I installed myself, just for easy replacement & testing other IC's, the original unit comes with no Socket.
              • hbizri
                • Nov 2015
                • 6
                • KSA
                I found this interesting document includes the SP-100-24 schematic diagram.
                Nice document.
                But will be nice to ad more info to this, key testing points/to verify proper functionality of the power supply.
                Regards,
