Jig (tool) for testing PSU's?
  • dnorm
    • Mar 2008
    I just signed up on this site... I know that a P.S. must be tested 'under load'...
    one told me there is a 'jig' available at low cost, that provides a load for the P.S., and indicates performance by LED's... prob a 'quick', not 'deep', diagnostic tool, but it is all I have need for right now... have looked for, and have not found, such a thing...
    Can one point me toward it?
    Thanks in advance, for any and all responses...
    regards... dnorm
  • btfsc
    • Jan 2008
    Re: Jig (tool) for testing PSU's?
    Here is a link for one. $13.69 plus shipping
    http://www.mcmelectronics.com/produc...me=MCMProducts
    • dnorm
      • Mar 2008
      btfsc,
      thank you, I think that is what I was looking for...
      regards... dnorm
      • starfury1
        • May 2006
        • 1256
        This below is
        NO substitute for a "real load" and a "real meter"
        but if you want a quick way to kick one over and get an idea of whats happening
        its not bad
        https://www.badcaps.net/forum/showthread.php?t=2856
        there are LED versions, but like I said only as an indication, don't take what they say as being true that the supply is ok
        there is another thread going on building dummy load setups
        https://www.badcaps.net/forum/showthread.php?t=4874
        HTH
        Welcome Cheers
        • gonzo0815
          • Feb 2006
          • 1600
          Serious load for testing ATX PSU`s would be at least about 100w to 200w. I think a PSU who can give out that amount of power, would probably not the culprit.
          • AJ847.63e
            Testing ATX PSUs under load - Does loading the ATX 24 pin also load EPS & PCIE?
            by AJ847.63e
            Hi Folks,
            Just wanted to clear up a misunderstanding of mine (or what I expect is one). Isn't the 12V rail from the 24 pin, EPS and PCIE separated? IE if I put a power resistor on the ATX 12V pin that is not going to load, thus tell me if the EPS or PCIE rails are fine?
            I was recently watching ArIs from Hardware Busters video on how to properly test ATX PSUs without using 5 figure Croma substations.
            The PCB adapter he used breaks out the 12, 5 and 3.3V pins from the 24 pin and gives you banana plugs to connect to. That is a bit useless is it not? Aren't...
            05-06-2025, 10:37 PM
          • rex98
            HP DMI Tool
            by rex98
            HP DMI Tool is used to Extract DMI information from a HP BIOS Bin.
            DISCLAIMER: badcaps.net and its members do not support unlocking stolen or company-owned devices.
            The DMI Tool given here are for personal use only.
            DISCLAIMER: THE HP DMI Tool IS FREE AND ARE INTENDED FOR EDUCATIONAL PURPOSES ONLY.
            You CAN download it, use it.use it.I only ask that you DON'T modify it ,sell it or try to make a profit
            from it, and that you please credit the author...
            07-02-2025, 05:51 AM
            Some New Preliminary testing of 21700 Tool battery cells to 2.00
            I decided to try a new approach to testing unbalanced battery cells with my battery testing machine that has more graph curve information and it looks like if you discharge them to 2.00 volts if the battery voltage does not come back to over 3.something volts you have some kind of issue with that battery cell
            I going to do more testing and see if is the case or not
            More to come later
            05-04-2023, 05:11 AM
          • dicky96
            Load Testing Audio PA Amplifiers
            by dicky96
            Hi, one of my customers who rents out equipment for events and carnivals asked me to make a passive dummy load so the can test amplifiers under full power without causing noise problems to other nearby businesses.
            He wants 8 ohm and 4 ohm loads, originally he asked for 8 ohm 500w resistors, and I said we could use two resistors in parallel for 4 ohm 1000W
            Then I found these cheap power resistors on Alibaba. It says they are 'Braking' resistors, but they seem to be suitably rated for my purpose
            https://www.alibaba.com/product-deta...w-Resistor-8-o...
            01-12-2021, 10:31 AM
            HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
            This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
            09-12-2024, 02:20 PM
