PSU Load Testers - Designs?
  • PCBONEZ
    Grumpy Old Fart
    • Aug 2005
    • 10661
    I'm interested in eventually building a load tester... someday...
    .... like I'll have time anytime soon... even this year!
    But if I trip over a surplus bulk lot of power resistors that may change....
    Anyway, has anyone seen any scats or plans, interesting articles, or have one they built.
    Both cheesy-basic and whamidyme hi-tech my apply.
    Opened as more of a casual interest discussion topic than anything else right now.
    Mann-Made Global Warming.
    - Dr Seuss
  • zandrax
    Hit and miss
    • Dec 2007
    • 1157
    • Italy
    Re: PSU Load Testers - Designs?
    Since good load tester are expensive, Xbitlabs reviewers made one from scratch, adding sensors and a recording interface: the whole article is about psu basis and test methodology, but at page 11 they describe their loader.
    If I get into some others DIY projects, I'll post here.
    Zandrax
    Have an happy life.
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Good info Zandrax.
      Thank you.
      - Dr Seuss
      • shadow
        • Feb 2007
        • 732
        The review looks quite interesting. The project seems to be fairly challenging, however not completely out of grasp for those that do not have all the required know-how yet on all these electronic circuits. Such as myself.
        Good find!
        • starfury1
          • May 2006
          • 1256
          yeah when I read the post thats the page that come to mind.
          (of course wouldn't have a clue were it was in the book marks)
          I did see another somewhere which had a stack of power resistors (big ones in heat sinks)
          in I think it was an old computer case with fans and large toggle switches.
          I was thinking about this awhile back and there has been a bit of discussion on it.
          Yanz I think used automotive bulbs (they suck a bit of juice).
          you can get those multimeter's el cheapo ones something like $10.
          Get a few of them and dedicate them 2 per rail V/A with power resistors
          a switched bank for each of the rails so you can vary the load
          Ideally an "electronic dummy load" thats variable would really be more the go.
          Another thought is a bit cruder
          one of those psu testers (like here) with the voltage meters in it but a double type power lead and a salvaged MB connector to setup some real resistive loads on it
          the psu tester would monitor ( not overly accurately) the voltage.
          you would have to make provision for current monitoring.
          Yeah somewhat crude as I said.
          none of the above are a SunMoon but could be done for reasonable price if you are prepared to scrounge around for the stuff.
          Digital meters are nice for accuracy but when you consider the dynamics of what your looking at a few analog meters would probably give you a better visual feel for whats going on with a psu on varying loads.
          Think for the voltage (due to the small amount it should change) you would really need to have some sort of expanded range, like say between 10 and 15 for the 12 volt range etc
          (I have to think about that one but you get the idea)
          Anyway they were my thoughts when I was thinking about building one.
          beats stuffing around with meters and loads I suppose.
          another thing as JG has got, perhaps one of the USB CRO HW SW devices if you really want to get a bit more to the nitty gritty with them.
          (although if you got a reasonable CRO then thats probably all you need)
          OK my 2 cents worth
          Hope its of some help or gives you a few ideas
          Cheers
          You step into the Road, and if you don't keep your feet, there is no knowing where you may be swept off to." Bilbo Baggins ...
          • starfury1
            • May 2006
            • 1256
            on dummy loads
            I actually built something like this for testing Audio Power Amps years ago.
            http://www.k4eaa.com/dummy.html
            Didn't fully read this, but it looks along the lines of what you might call an
            http://www.fraw.org.uk/download/ssp/sspji-05.html
            if the unit its self isn't much use it would I think give you the theory to adapt
            to your purpose I supose
            Here's another and again might be the basis for a more heavy duty unit.
            http://tangentsoft.net/elec/smarty-load.html
            note the heat sinked power resistors
            a page I found (well article really)
            http://www.pcper.com/article.php?aid=187&type=expert
            Here's another electronic type (doc with schematic a PDF)
            http://www.geocities.com/hagtronics/load.html
            just mention this anyway
            Normally we talk of "resistive load", which is to say current and voltage are in phase (0 degree's phase shift)
            power or wire wound resistors do have a reactive element
            (being a coil of wire, inductor)
            Not that I think it will overly matter with a DC psu but it is there and just something to be aware of
            In the case of audio amps (depending) it can be a real problem
            Hope the links help somebody anyway
            Cheers all
            • PCBONEZ
              Grumpy Old Fart
              • Aug 2005
              • 10661
              The only time I can remember using dummy loads of any size as a testing device was messing with Radar units back in school. (I have worked on equipment that had huge banks of foot long power resisters built in.)
              What I had in mind for PSU's is along the lines of using banks of wire wound resisters with current controls so I can set the amps on each rail to say 60% rated, then 70% rated, and so forth. Set all the rails at a % rated point and check DC volts for a drop and the wave form for noise.
              It wouldn't do anything for transient response measurement but it would at least verify if a PSU is actually going to handle the amps you need for the system without the voltages dropping out of spec.
              Also if you have a situation where one rail is always low or high or too noisy you might be able to figure out a circuit mod to bring it in range.
              Unfortunately my brain can think of cool projects a lot faster than my time or wallet allows actually doing them.
              [Doesn't kill the interest though.]
              - Dr Seuss
              • starfury1
                • May 2006
                • 1256
                Yes power resistors and switching is probably the cheapest lest headache way to go
                (not after lab 12 decimal point accuracy etc)
                these following articles are probably more useful for setting up pwr resistors
                http://www.silentpcreview.com/article683-page1.html
                This page here
                now this is the one I was looking for...it also came to memory when I read the post.
                (not that I am saying its a perfect idea or anything..just found it a bit of novel idea, although there is a reason behind it)
                http://www.extremeoverclocking.com/a...Testing_3.html
                forum page I found the links on here
                Another link I found Why 99% of Power Supply Reviews Are Wrong
                just skimmed it so pro and cons no real idea
                for those with very very fat wallets
                chromaate
                Anyway plenty of ideas, and by the sounds of it bonez you got a few of your own.
                Cheers
                • i4004
                  • Oct 2006
                  • 2029
                  he says measuring is not the path only to endn up with another type of measuring.
                  what interests me the most is reliability and diurability, and the only way to find out about that is the real-world experiences of people who actually repair pcs.
                  accelleratred tests and voltage/current measuring won't do.
                  most psus will power the machine and work while they're new.
                  what i'm interested in is "HOW LONG" will it work, and as i mentioned in other thread, can i trust it won't blow up my machine; durability and reliability, with an accent on rleiability, as i don't mind it lasting 2-3years if it won't kill mobo and everything else.
                  my requirements are pretty low, then, aren't they?
                  so hooking up to right people is more important for psu testing than load testing, as majority of the pople don't do video-encoding or simillar system loading tasks(then again, system loading doesn't neccesarily mean psu is loaded etc.).
                  • zandrax
                    Hit and miss
                    • Dec 2007
                    • 1157
                    • Italy
                    You can say if a psu is a good or a bad one by looking its components' quality and by mesauring its temps while it's running: you can estimate if it will more likely fail or survive in few months, but there isn't a thing such as a reliability test.
                    Zandrax
                    Have an happy life.
                    • starfury1
                      • May 2006
                      • 1256
                      that being the big question
                      yes feedback is important, I agree
                      and so is the conditions they are (were) being used in are important to know if one fails.
                      I guess the only why your going to tell with say a new production is who possibly build it (as in the design) quality of build components used
                      how well it handles stress
                      Hopefully someone that reviews it knows there stuff and what to look for.
                      The manufactures past reputation, that doesn't mean they wont go cheap or just possibly have a somewhat suspect lemon of a new product.
                      I haven't read the article was more looking for resistor setups
                      I suppose I should since I open my big trap and posted it
                      Cheers
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        I understand where you are coming from but the problem with that idea is by the time you have the reliability data the equipment is obsolete anyway.
                        - Dr Seuss
                        • mpilchfamily
                          • Mar 2008
                          • 3
                          Thought this may help you out in your future build plans. Just last month i completed my own Load tester. Here is the Work Log of that build.
                          http://www.xcpus.com/forums/other-mo...ate-984-a.html
                          Here are the threads for the planning stages of the build.
                          http://www.xcpus.com/forums/mods/458...-test-bed.html
                          http://www.xcpus.com/forums/mods/543...ad-tester.html
                          http://www.xcpus.com/forums/mods/684...esign-4-a.html
                          It was 4 months of research before i was able to secure funding to start the build. The system is built and ready to test save for 4 resistors that where on back order. Finally got those in the other day but haven't had the chance to install them. Its going to be a bit of a choir to pull the system apart to get the resistors installed.
                          Here is another custom built load tester. He hasn't finished it yet but he is going all out to make it just like a nice $10K professional tester.
                          http://www.themodnation-forums.com/viewtopic.php?t=333
                          You will also find a copy of my Work Log at The Mod Nation.
                          Now one of the best places for PSU information and getting your PSU testing methods right is here.
                          http://www.jonnyguru.com/forums/index.php
                          Hope some of that information will help. If you have any questions please ask.
                          • starfury1
                            • May 2006
                            • 1256
                            I'll have a read later but "thanks" for the links...
                            wow certainly some effort went into that
                            (OZ slang, like that LOL)
                            If anyone can find me a DPDT switch that can handle no less then 41A then let me know
                            don't know if you got an answer to that but I think you would be shopping at an "electrical" wholesaler for something that can handle that
                            Like a Mains Switchboard Switch (not cheap either)
                            I Dont know about "double throw" thought (probably available)
                            Just looking at some prices for electrical gear
                            I thought they said Ned Kelly was Dead.
                            Welcome to the forums
                            Cheers
                            • i4004
                              • Oct 2006
                              • 2029
                              why not load it with a bunch of car headlight lamps?
                              • kc8adu
                                • Nov 2003
                                • 8832
                                • U.S.A!
                                the cold surge current will likely trip ocp.
                                had 2 astron rs35m here that would not light a test headlight.
                                the ocp was that fast.
                                • mpilchfamily
                                  • Mar 2008
                                  • 3
                                  Lamps will work but then you have to use allot more of them and the cost goes threw the roof. As for the DPDT i figured out that i didn't need it to handle 41A. Any DPDT will do since there is only a small amount of current and voltage passing threw it. The DPDT switches are tied to the Shunts for each Load bank. The only power going threw that is the voltage drop across the shunts which is used to measure the Load on each bank.
                                  • starfury1
                                    • May 2006
                                    • 1256
                                    Lamps will present a dynamic load at startup with a large current surge.(as KC8 said)
                                    I know there is one forum member that uses them but this is as a lighter load I think not trying to max out the psu.
                                    doable yes,
                                    (depending on lamps, maybe throw a power resistor in line to limit surge)
                                    but better power resistors
                                    This is really a side point
                                    Don't know how really relevant it is in the real world
                                    power resistors (wirewound) I suppose have another effect which "could be" helpful and thats "inductance."
                                    this would to some extent (if I remember my theory correctly) soften any surge at startup
                                    This means you do have a reactive element to your resistive load but I think thats not really an issue (it may be of some effect with regards to ripple, I dont know)
                                    All I know for sure is they do have a measure of inductance, being wire wound
                                    (unless its "Noble" brand which I don't think exist any more, they from what I understand were wound in a way to reduce inductance, double the wire over then coil, a mutual inductance thing)
                                    Cheers
                                    • mpilchfamily
                                      • Mar 2008
                                      • 3
                                      Well there will always be some short fall to whatever you use as the load. The problem is it isn't a dynamic load. Its very hard to simulate real world conditions. Unfortunately you can't get a good review of a PSU while in a normal system. For one you can't really test the full ability of a 1KW unit. Also you have no way of knowing the actual load. The ideal way to test would be using a system that is able to fluctuate the loads similar to the way you PC does when starting up, Idling, and under heavy loads. The system would have to record the load about every 10th of a second. It would also have to keep track of the voltages at the same rate. A good PSU needs to be able to react to sudden changes in loads without the voltage dropping outside of the +/-5% tolerance in that split second. Then of course you would need to compile all that information to get the average efficiency of the unit. Placing set loads on a PSU is nice but only tells you it can sustain a certain load. But PC loads are never sustained for very long and tend to rapidly peak and fall. Many PSUs out there can easily handle a heavy and consistent load. Its the constant fluctuation that they are not able to keep up with and kills them. Especially when the load Goes quickly form a relatively small load to nearly max of the PSU's capacity. Its hard to properly test a PSU.
                                      • starfury1
                                        • May 2006
                                        • 1256
                                        True a resistive load is fix, all you can really do is just have it at different load levels for the PSU
                                        mostly here people just need a decent type of load(s) for load for testing.
                                        Power Resistors are the best option for a somewhat cheap load
                                        which is all thats really need for the majority repairs I suppose.
                                        True though, to look at the dynamics & response behavior, you would need to emulate those conditions of use in a controlled way.
                                        Me, still a bit of a noob really on switchers.... understand some of the theory and some of the problems but no design engineer here.
                                        BTW I only mentioned the "side point on inductance" because we were talking initial surge currents
                                        Steady state DC it wouldn't matter at all.
                                        (if it even really does factor in with ripple I wouldn't have a clue)
                                        for the purposes of just testing a PSU under loads, the above
                                        (using power resistors) would be fine.
                                        lamps too I suppose if you got nothing else
                                        but just beware as pointed out by KC8 they could be a trap
                                        they are probably not the best idea
                                        Cheers
