Hi there, thanks for the great advice in these forums. I'm hoping to find a bit of specific advice on a Noma-branded Xantrex Powersource 1800 battery backup.
It's an old unit, with maybe 10yrs service as a sump pump backup, so the batteries inside are not holding a charge anymore, but it does still supply non-sine AC power when connected with booster cables to a running automobile's red battery terminal and engine block.
It is rated 1800W continuous and 3600W peak, but it is cutting out with an overload error (E03) with even just a 900W space heater or 1/2hp water jet pump plugged in by itself.
None of the components on the circuit board seem to show any signs of physical damage or burn marks, and all eight 30amp fuses look ok.
It might possibly have received a shock when a tree in the backyard was hit by lightning while it was in the basement, unsure on that.
Here are a few pics of the setup and circuit board.
There are reports online of this Powersource unit having transformer problems.
Can these components be DIY repaired or otherwise jury rigged for a quick fix?
I only have a basic digital multimeter for testing, and am learning as I go what can be tested for what.
Thanks for any advice that will get this unit running strongly again, it'd be great if it could power the oil furnace too!
 Xantrex Powersouce 1800 Overloading (Error E03)
								 Half of the computer problems is caused by bad contacts
