Synchronization of ringing choke converters
    Depending on the design, some ringing choke converters can be synchronized from an external source - a common example were the "live chassis" TV sets, mainly from the 70s to 80s of which the converter was synchronized to TV Horizontal frequency.
    I've even seen a ringing choke converter which the synchronization signal is electrically isolated by an overwind on the flyback transformer in a Casper TM5158A monitor (the circuit diagram should show this winding is actually isolated).
    Syncrhonizing ringing choke converters should be done with caution, since a frequency which is out of range (or something incorrectly designed) can cause failure of the converter.
    Re: Synchronization of ringing choke converters
    I had a feeling that is so .. :P
    Muh-soggy-knee
      Yes, I've seen those, although I've never really understood why this was done. Would the B+ capacitor be charged by the SMPS at the same time as the pulse from the horizontal output stage is discharging it, and would this then minimise the ripple?
