ADT MPT-301 – an early CWT ISO unit?
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: ADT MPT-301 - more testing
    Originally posted by momaka
    Thus, I'll go ahead and call this PSU complete.
    I'm going to call it Censius!
      master hoarder
      • May 2008
      • 12170
      ...Censius...
      Something seems to be going over my head here. Google isn't helping either.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        Re: ADT MPT-301 – an early CWT ISO unit?
        Do a search on the previous page of your post
          master hoarder
          • May 2008
          • 12170
          Really now?! :\ :\ :\
          Well, not sure how the "L" in Celsius got switched with an "N" ... meh.
          • Nagy Daniel
            Lowest possible resistance on laptop motherboard rail - Guide Table request
            by Nagy Daniel
            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
            So, I generated a table with AI so I can...
            03-04-2025, 08:24 AM
          • bimole
            Weird behavior on 3.3V rail of a CORSAIR CX600
            by bimole
            A colleague gave me an apparently ill CORSAIR CX600.
            He told me that he heard a banging noise, and smelt the magic smoke.
            After tearing down the PSU, no burnt component, everything seems OK, but the PSU often refuses to stay ON. When shorting PS_ON to GND, the fan spins a bit a finally stops. No output voltages.
            I tried to treat some apparently bad solder joins and finally it seems to work OK... on the 12V and 5V rails!
            It's another story on the 3.3V rail...
            I have some devices to test deeply PSUs (scope, AC source, electronic load)...
            02-13-2025, 04:49 AM
            KingWin ABT-650MM 650 Watt ATX PSU [PCB: SW8835REV:A]
            by momaka
            For today's thread, I have a KingWin ABT-650MM ATX PSU. Official web page with the PSU specs is still up and can be found here:
            http://www.rmac.kingwin.com/products.../abt_650MM.asp
            I just can't help it when I see a broken / for parts PSU on eBay that's listed for cheap and looks at least somewhat interesting. Well, OK, I won't lie – on the outside, this PSU looks anything but interesting. It's a plain gray box with colorful “spaghetti cables”.
            What mostly drew me into buying it is its 2x PCI-E power connectors...
            03-29-2022, 11:34 PM
            Casing Power MPT-301 [PCB ATX9806b-p REV: A3]
            by momaka
            This one should make @Pentium4 smile (if he is still reading BCN forums) – I got a new old stock / open box Casing Power MPT-301 PSU on eBay for $4 total.
            Yes, it’s a very generic-looking box, but the manufacturer isn’t (at least not back in the days), which is…
            Macron Power Technology Co. LTD.
            Let’s look at the PSU itself.
            The shell/case also appears quite generic, like many “sold-with-the-PC-case” units. However, the shell is well-formed and has decent steel thickness. In terms of...
            06-02-2021, 10:05 PM
          • jinu_j
            by jinu_j
            Hi
            05-03-2025, 10:51 PM
