Motormaster Eliminator 2A battery charger repair
  • CapLeaker
    Leaking Member
    • 8195
    Well, I usually don't bother with that, but for fun sakes and to keep stuff out of the landfill, why not.
    This is a Motormaster Eliminator model 011-1506-6. It's an orange little "intelligent" battery charger / maintainer 12V 2A. It was used to maintain a generator battery and it failed. Funny thing is it never blew it's fuse and had 160V at the filter cap, but didn't work of course.
    Soo... I opend her up and first thing the L6565 PWM has it's lid blown off. it also had some signs of moisture inside. The soldering is absolutely crap (unreal how many bad solder joints that lil thing has).
    After further investigation, the PWM, the 4N60 Mosfet, R9, D7 and Z2 were either shorted or open. Everything else looks to be in order.
    Here are some pix:
    Re: Motormaster Eliminator 2A battery charger repair
    When the POWER MOSFET that is driven by the SMPS IC shorted out between Gate and Drain pin, it will dump 160V in to the Gate drive output of the IC, the Gate drive R/D (Resistor-Diode) network between the Gate drive output pin and the Gate pin of MOSTFET will also be damaged.
    • CapLeaker
      Leaking Member
      • 8195
      It was budm. R9 (1k) between the Gate and the PWM was open. 2 diodes where shorted. I always appreciate your input.
      • Happy Time
        • Apr 2022
        • 7
        • canada
        Hi it happen same to me ,could you remenber the diode number.Thanks
        • CapLeaker
          Leaking Member
          • 8195
          Nope. That’s been like 7 years ago. But I’ve still got that charger somewhere. Maybe post some high resolution pictures top and back and another one with the diodes in question. Then I’ll look. Can’t find Z2 on my old pics.
          If the diodes are not completely destroyed, unsolder them and read what’s printed on it. Since I am sure I didn’t order anything these diodes aren’t anything special, besides one being a zener diode.
          • Happy Time
            • Apr 2022
            • 7
            • canada
            Thanks for the reply.When the l6565 blow some resistor and diode got heat and carbon from the explosion and even with wash it is hard to identified the color on resistor and number on diode.I'll try to unsolder like you wrote .My charger is identical to your pic but more carbonised.
            Again thanks Best regards
            • Happy Time
              • Apr 2022
              • 7
              • canada
              I did expect replacing mosfet Q1 4n60,R9 I kohms ,r7 22 ohms, and mesure r10 and r 46 that look 1 ohm,D7 is ??,and Z2 =??,plus of course with your post is L6565 because it is all destroy.
              • R_J
                • 9551
                Post a clear picture of the trace side of the power supply. I suspect D7 could be across R10/R46 and will check shorted. Are R10/R46 the source resistors for the modfet? if they are, lidt one end of D7 to check if it is shorted or not.
                Where is Z2 in the circuit? it might be across the vcc line for the ic, and be used for over voltage protection (15volt?) on the vcc line.
                The diodes should be marked with there part number
                • redwire
                  • 3910
                  I think a sketch of the schematic around the two diodes would help (with IC pin numbers), or pictures. L6565 datasheet.
                  • Happy Time
                    • Apr 2022
                    • 7
                    • canada
                    I had lots of damage and printed circuit board are very week like someone alreadt wrote.Please find pic of my circuit
                    • R_J
                      • 9551
                      I can't make out the markings on the diodes, but they are there. can you read them and post the numbers? I suspect the zener Z2 is likely around 15v, D7 is in the gate drive circuit and like the datasheet is likely a 1N4148
                      • Happy Time
                        • Apr 2022
                        • 7
                        • canada
                        Z2 is close of H1 print,R10 and R46 are open
                        • Happy Time
                          • Apr 2022
                          • 7
                          • canada
                          R J ,i was able to read D7 and look like 1N4148 you are wright but Z2 couln't read
                          • CapLeaker
                            Leaking Member
                            • 8195
                            I think a 15v zener makes sense to be there and also sticks in my head. Unfortunately I can’t find that charger to look.
                            • Happy Time
                              • Apr 2022
                              • 7
                              • canada
                              Ok thanks i'll try to do my best with that piece of shit.
                              • CapLeaker
                                Leaking Member
                                • 8195
                                Yeah, those Motomaster chargers are junk.
                                  NVDC charger configuration...
                                  11-05-2024, 03:28 PM
                                  ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
                                  Highly Integrated Narrow VDC Battery Charger for Notebook Computers
                                  The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
                                  for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
                                  Narrow VDC applications where the system power source is
                                  either the battery pack or the regulated output of the charger.
                                  This makes the max voltage to the system equal to the max
                                  battery voltage instead of the max adapter voltage. Operating
                                  at lower system voltage can improve...
                                  11-05-2024, 04:43 PM
                                • flat-earther
                                  how to prevent a connected charger from draining battery when not charging?
                                  by flat-earther
                                  I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
                                  So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
                                  but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
                                  So the battery is backfeeding the charger and being drained.
                                  How can I prevent...
                                  08-07-2025, 01:04 PM
                                • Bowline
                                  by Bowline
                                  06-11-2025, 10:13 AM
                                  Bauer tool battery pack charging with a HERCULES charger modification
                                  by sam_sam_sam
                                  The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
                                  Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
                                  05-06-2023, 12:17 PM
