Buzzing Sound coming from transformers
  • ITSYSTEMSALBANIA
    • Mar 2015
    • 37
    • Albania
    Hi all
    I repaired an dell psu model H280P-01 which was dead i replaced some 10v capacitors and the power supply its fixed but when i power on the psu i hear a buzzing sound coming from this two transformers.Is this sound normal or not.Thank you.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Buzzing Sound coming from transformers
    How loud is the buzzing is it abnormally loud ?
    Normally the ac switching frequency noise that passes through the transformers is slightly audible but shouldn't be too loud. If its very loud it could indicate a short on the secondary side of the psu.
    • R_J
      • 9633
      Yes they make noise, some louder than others, a loose winding or core lamination can even sound louder. If the supplies are working I would say they are ok and normal.
      • ben7
        Capaholic
        • Jan 2011
        • 4059
        Might want to check the capacitors in the PFC circuit (if it has one), it might be 120 or 100Hz noise you hear. It might also be normal no-load (or light load) oscillations.
        -Ben
        Muh-soggy-knee
        • ITSYSTEMSALBANIA
          • Mar 2015
          • 37
          • Albania
          The psu makes the buzzing sound when no load is connected when i conect a load the buzzing sound stops.Thank you all for your replies.
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Yep it's because of the very light (almost none) load. The power supply does provide a slight load for it's internal circuitry, but that's only a few watts at most.
            It basically ends up skipping pulses, hence you get a sound that humans can hear.
            You can add some minimum-load resistors if it bothers you.
            -Ben
            Muh-soggy-knee
            • LEECH666
              Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
              by LEECH666
              Good day ladies and gentleman!
              I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
              This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
              I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
              01-19-2024, 05:46 PM
            • Kartowl
              philips 47pfl6158k/12 image faded away, sound still coming from TV
              by Kartowl
              Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
              04-23-2024, 12:57 AM
            • ChaosLegionnaire
              by ChaosLegionnaire
              09-13-2022, 09:02 AM
            • valente222
              LAPTOP HP 15-DY2059LA / i3-12gen has stability problems in vccpu coils, BUZZING SOUND. ¿Coil whine?
              by valente222
              Hello friends, I just received this equipment, it has a strange hum on the board. The computer works fine, outputs an image and starts Windows. But the problem is when charging the battery, a constant loop to charge. In short, it never charges the battery. When the charger is connected, the stability of the CPU is stressed and it seems that the coils make that electrical sound louder. This board is modern and I don't have a schematic. I have checked with a microscope and the pcb is completely new. Has anyone had this happen to them before? defect in driver ic?...
              11-18-2024, 03:21 PM
            • proxneo
              Bose Wave I AWRCC1 - intermittent to no sound output - loud popping & crackle sounds
              by proxneo
              Dear reader
              I have been asked to check out a faulty Bose Wave system belonging to a relative. The faulty unit produces loud intermittent pops and crackles. Sometimes there is speaker audio output (FM/AM, CD etc.), most of the time there isn't. This behaviour degraded over time fairly quickly, to the current situation where no sound is put out at all. Gently messing and wiggling wires, connectors or heatsink has no effect in force-replicating the problem. I have little experience in audio repair when it comes to (main)board electronic component faults. Bose repair WAS about 140$ (most...
              12-02-2023, 09:27 AM
