Fanless Silverstone ST30NF / Etasis EFN-300 caps busted
  • cheater
    • Nov 2017
    • 5
    • Biz
    Re: Fanless Silverstone ST30NF / Etasis EFN-300 caps busted
    Originally posted by Exim
    Fanless Silverstone ST30NF, also known as Etasis EFN-300, doesn't power up anymore. Was working 24/7 for about seven years until it switched off itself.
    This thing is massive, even with the thick aluminum case removed. Components squeezed into every corner. Three daughter boards.
    There's 3 KMG 400V 150 uF on primary. And a KMG 50V 1uF close to it.
    On secondary four of five black Teapo C3 10V 3300uF are blown.
    There's a green Teapo C1 16V 2200uF.
    A bunch of other caps are hiding below the heatsinks. One is bulged. Can't really identify them, looking at the sleeve color and at the top vent I'd say it's all Teapo C1 ones.
    In standby temperature LED shows green ("ok"), fault LED shows orange/amber, it turns red when trying to switch it on. Power supply make one "click" noise for each power up attempt. +5VSB is available and stable.
    I'm not sure if I wanna invest the time to disassemble this beast, just recapping secondary probably won't fix it, I guess. Any ideas?
    Have you ended up recapping yours? I have a similar unit (450W) and am debating it. Same symptoms. Visual inspection (without pulling the board out) shows one capacitor is bad, but I haven't looked under UV yet (leaked electrolyte glows in UV). The insides look somewhat different to yours, slightly different sizes and configurations of passives, but it's all variations on a theme.
    What is a current good capacitor line to use in a "hot pocket" on the secondary side? Someone mentioned non-aqueous. What do I get? I think I only have to replace a handful, so I can afford to splurge on something that isn't crap.
    • cheater
      • Nov 2017
      • 5
      • Biz
      (PS sorry about necroing this for those who feel offended by my actions )
      • Behemot
        • 4845
        • CZ
        Not sure about this particular unit, but the fanless FSP ones I had in my hands always got busted caps. So it's worth at least trying to recap it IMO.
        • Exim
          • May 2011
          • 64
          Sorry for bringing this back up. Just realized I never gave feedback
          I didn't recap it. There were too many reasons against it, as already written in this thread: Unefficient design, compared to other PSUs it was already not-so-efficient when it was new (the machine it was in puts just 1/3 load on it), no airflow, caps pocketed so new caps would cook as well, lots of time and effort to dis-/reassemble the whole thing stuffed with components and heatpipe and whatever. Also in case more components died and recapping wouldn't be enough: I don't have the knowledge to test and fix a whole ATX PSU of this caliber.
          Around here Silverstone PSUs with active cooling have a solid reputation. But from what you can read the fanless 300W and 450W ones just seem to have died, all of them, and fanless ones from other companies/brands weren't any better. Dunno about current models.
          Yes, it was expensive when it was new. But to me that's the price paid to learn: No more fanless ATX PSU, never ever again.
          I replaced it with the most efficient 300W-active-cooling-PSU-from-a-trustworthy-company I could find, turned out to be a FSP, 12cm fan, basically inaudible, less than half the price. Chances are high at 1/3 load it will survive more than 7 years.
          • Behemot
            • 4845
            • CZ
            Not really but that's your choice
            • iMic
              IBM NetVista Pentium III - USI Motherboard w/ Teapo SC
              by iMic
              Hi folks,
              I have a couple of IBM NetVista desktop computers from around 2000-2001. They have Universal Scientific Industrial (USI) Pro286i motherboards, 733MHz Pentium III processors, and a whole bunch of bad Teapo capacitors. One board has visibly bad and venting capacitors, while the other doesn't look too bad so far.
              The board with venting caps works fine, while the good looking board occasionally refuses to power on unless it's left for about 30 seconds after connecting the power - even with a known good power supply. (I am however aware I'll need to check the PSU...
              11-29-2023, 06:44 AM
            • harp
              can fanless heatsink replace poor original on RX26PG2
              by harp
              I have RX26PG2 graphic card with incomplete original heatsink, only aluminium plate... but in original solution it look like such bad termal design that I asking if is proper fanless heatsink be adequate replacement ot better... what you think? Till powering on, it is propper hot......
              06-25-2025, 10:56 AM
            • alindumitru46
              SilverStone UC01 USB Power Adapter
              by alindumitru46
              Initially, it started to give random failures, 3 months ago, after which it stopped delivering current. In addition, there was some noise in it.
              After another month he died.
              I thought that some filter capacitor had found its way to the end, so I started doing some research and remembered that there is a really complete review on tomshardware:
              https://www.tomshardware.com/picture...tear-down.html
              So I started to take it apart, and upon very careful analysis I discovered that:
              1. the fixing silicone against shocks/vibrations...
              05-29-2023, 04:22 AM
            • x_orange90_x
              Busted panel corners... Repairable?
              by x_orange90_x
              I have a 50" Toshiba bezel-less that I replaced backlights in a few weeks ago. The tape didn't hold well so the panel started hanging from the top. The pressure caused the two bottom corners to shear off. I can see a court contact on the right corner, but the left is gone in assuming. The screen is not cracked anywhere else, but it displays no image.
              Is it at all repairable? I'm assuming not....
              02-02-2025, 04:17 PM
            • jguy
              etasis 600w 1u Psu or mobo?
              by jguy
              Hi guys, basically i fired up a server rack i had by my mum for the last 2.5yrs unplugged. It has a etasis 600w 1u psu and dell t1600 motherboard. It went through all sorts of random reboots and power cycling for about 2 minutes thought something was fried but suddenly it worked fine and has been even after unplugging for hours now, thoughts?
              03-11-2023, 02:44 AM
