Achme 200W Switching Power Supply AM630BS20S Fault
  • TomFortune
    • Jun 2015
    • 4
    • United Kingdom
    Hi guys,
    I have a Shuttle PC that runs on a Achme 200W Switching Power Supply AM630BS20S. Yesterday i went to turn the pc on and nothing happened, i immediately thought it could be the power supply so tested it with a power supply meter. As i first thought there is no power to any of the board and therefore i decided to remove the metal cover to investigate. Upon opening the cover i noticed that there were three 10v 1000uf capacitors that had blown and therefore i decided to replace them. Whilst replacing these capacitors i noticed that the transformer in the middle of the board had blown the legs off of its body. Luckily i had a replacement transformer from a old identical power supply (the old power supply had a wiring harness short). On the casing of the transformer it was printed TOP222Y which when googled stated that it is a AC to DC transformer! is this correct? After further research i found that the circuit board had a fuse covered in black heat shrink which i have also replaced. Upon doing all this, i hoped it would work but unfortunately there is only a slight humming sound coming from the output side of the board. I am unsure as to where to go from here any help would be much appreciated
    Many Thanks
    Tom
    • 31304
    Re: Achme 200W Switching Power Supply AM630BS20S Fault
    it's not a transformer, it's a psu chip.
    anyway, top's use a starting capacitor.
    you need to find an replace a small capacitor near the top, it will be 10uf to 100uf usually.
    it dries up inside and then the top wont start.
    look at the attachement
    • TomFortune
      • Jun 2015
      • 4
      • United Kingdom
      Hi stj,
      thanks for the quick reply ive just replaced the capacitor i think you mean't it was 10uf and 50v but it still wont fully turn on as small pulses can be heard. any other ideas??
      Many Thanks
      Tom
        • 31304
        small pulses may indicate a short on the output.
        if you have a meter, check any diodes to see if any are shorted.
          by sam_sam_sam
          03-31-2024, 02:12 PM
          by sam_sam_sam
          07-01-2024, 06:34 AM
          by sam_sam_sam
          After all of...
          07-13-2024, 08:14 PM
          DVR camera recorder switching power supply capacitor failure really
          by sam_sam_sam
          These cheap non brand capacitors at it again
          Last night we had a power outage [ long drawn out trying three to come back up before going out completely ] and when I went to turn the DVR camera recorder back today no go 3 bad capacitors ( one capacitor no ESR reading on DVR board the other 3 capacitor on the power supply board over 40 ohm this is not a misprint ) on the external switching power supply and one capacitor on the DVR camera recorder board where the power supply that goes to the hard drive disk is
          Well at least I have the cameras back on line I to try the...
          01-22-2022, 06:28 PM
          DVR recorder Switching power supply Failure
          by sam_sam_sam
          When I originally started with my DVR recorder it had 4 individual switching switching power supply’s that were sh*t so I bought a 7 amp 12 volt switching power supply and modified the output plug and put a four output power supply cable to match the input power supply cable inputs
          Which worked for over 14 years until a few days ago when the cameras went dark no picture anymore well it turns out now the switching power supply has stopped working altogether now so I have to troubleshoot what has happened to this power supply more later on today what I found
          This...
          05-27-2023, 03:03 AM
