LiteON PS-6401 400W OEM PSU - Bad caps!!?
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Hello again, long time no troll
    I picked up this LiteON 400W OEM PSU from a PC recycling shop for not much (I don't remember how much exactly, but it wasn't very much), took it home and tested it with an old Skt370 junk M/B I had lying around. It turned on fine but the fan sounded a bit noisy, so I was going to open the unit up to oil the bearings. And when I popped the case open, I discovered a blown 16v 1200uf TAICON HD on the secondary circuit.
    GRRRRRR!
    Anyway, I looked up the Taicon HD, it is equivalent to Chemi-Con's KZE and (somewhat) to Sanyo's ME-WX. However, I don't have any of those caps, but I do have access to some Rubycon MBZ 1200uf 16v, which seem to have better ESR (50% lower it seems) and comparable ripple current, but they're only rated at 2000 hrs @ 105c, whereas the HD are 5000hrs @ 105c.
    So the answer is, would it be possible for me to use these MBZ as long as I keep the PSU really cool? (I do plan on powering a Prescott P4 with this PSU.)
    Thanks for any help,
    Aaron
    The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
    I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
  • UraBahn
    Scrapheap Hound
    • Nov 2004
    • 165
    Re: LiteON PS-6401 400W OEM PSU - Bad caps!!?
    If the Ruby MBZ isn't adequate to replace the busted Taicon HD, would the Sanyo WG do?
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      sure.
      mbz will be overkill in a psu.
      but it cant hurt to use them.
      • linuxguru
        • Apr 2005
        • 1564
        For the 12v rail, I would go with a slightly larger value, non-aqueous cap. The Chemi-con LXZ 1500/16v/10mm is a reliable and inexpensive replacement. If you can fit 12.5mm caps, a wide variety of Nichicon PJ/PL/PM/PW etc. are possible, as well as Chemicon LXF, which was the endurance champ for many years with a 15k hour endurance.
        BTW, those green-sleeved Taicon HD 1200/16 usually fail when hot and under high ripple current - check your airflow as well, substitute a ball-bearing fan and disable the fan speed control if you can.
          by momaka
          03-12-2025, 03:42 PM
        • Paxman_Swede
          by Paxman_Swede
          Hello!
          01-14-2025, 09:51 AM
        • captain150
          by captain150
          03-16-2025, 07:34 PM
        • Foetuss
          Gigabyte GA-6OXT :: caps question
          by Foetuss
          Good evening
          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
          But I was also suprised about the bigger boys, which are 330µF 25V.
          Could it be they used 25V caps because they were cheaper / available at that time?...
          02-11-2025, 12:22 PM
        • madscientist750
          Replacing electrolytic caps by solid caps on old motherboards
          by madscientist750
          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
          10-19-2025, 06:10 AM
