Need a server power supply
  • Maxxarcade
    • Jul 2006
    • 973
    What kind of power supply do I need to run an Intel STL2 motherboard? It has a 24 pin ATX, 10 pin ATX12V, and another odd inline type connector. I'm only familiar with AMD stuff, so I don't know what that standard is called.
    Also, I'll be running 8 320GB hard drives in RAID 5. Any recommendations on a suitable power supply for this system? It is going to be a file server with 24/7 duty.
    I'm getting all the parts on Ebay except for the hard drives, because I'm trying to keep the cost down, so I'd like a PSU that is around $50-75 if possible.
  • Maxxarcade
    • Jul 2006
    • 973
    Re: Need a server power supply
    Is this a good PSU for a dual PIII system with 8 hard drives? I don't think the 300W Sparkle I have right now is up to the task.
    http://www.newegg.com/product/produc...82E16817703011
    • Maxxarcade
      • Jul 2006
      • 973
      Actually this one has a very attractive price, and the +12V ratings are the same as a 400W unit.
      http://www.newegg.com/product/produc...82E16817103012
      EDIT: Looks like I'm going to need something pretty big. Each hard drive draws 2.8A peak on the +12v, so that's around 28A for 8 hard drives, a DVD drive, and a floppy
      • gg1978
        • Dec 2004
        • 431
        Well, the STL2 does like to have the 24 pin ATX, which just happens to match the latest 24 pin atx.. As for the 10 pin connector, IIRC that's for PSU management, and the 6 pin inline is an older standard more like 2000 era Pentium II and III series, server grade. It carries two +3.3's and one +5, with three grounds.. YOu can probably get away without using it, but if you can find a PSU that has it, it certainly doesn't hurt..
        Any good PSU should be able to sustain at least 30% overcurrent on one rail for a period of at least 30 seconds with no harm to the PSU or reliability.. If you can enable staggered spinup on your drives, that would help a lot. On SCSI drives, that's really easy, but a bit more difficult on SATA drives...
        • Maxxarcade
          • Jul 2006
          • 973
          Just bought a Zippy/Emacs HG2-6400P Looking forward to seeing what is inside.
          It is rated for 30A on the +12v, which is about what I need. Hopefully it is worth the $80 I paid for it.
          • gg1978
            • Dec 2004
            • 431
            Oooh, nice.. I'd love it if Delta would actually sell to end-users.. Zippy/Emacs is good though. I'd love to have an ATX12V 600 or 700 W Delta to play with.. Given how nice their ancient 300W BB series is, when it comes to heft and cap quality, their 500+ W PSU's must be of legendary quality..
            • gg1978
              • Dec 2004
              • 431
              Oh yeah, almost forgot about this post i made a while back..
              https://www.badcaps.net/forum/showthread.php?t=3741
              Probably not quite what you're looking for, but damn good for $30....
              • Tynan Dill
                by Tynan Dill
                Assuming...
                11-22-2024, 01:46 PM
                03-31-2024, 02:12 PM
                07-01-2024, 06:34 AM
              • JimBanville
                Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                by JimBanville
                The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                09-13-2023, 07:21 AM
              • CMCM
                Russound CA4 Power Supply Repair
                by CMCM
                Hello Everybody,
                Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                The outputs marked 12v and 20v are all measuring only 1v.
                The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                The capacitors physically look clean (no bludgesor leaks) and...
                07-03-2025, 01:12 PM
