Smps converter showing weird behavior !
  • SM-Piyes90
    • Feb 2014
    • 120
    • Morocco
    Hi everybody .
    I have recently been busy trying to resolve a problem concerning a high current smps converter.
    The problem is when I power the unit , I get :
    1- no fan rotation.
    2- over temp led that lights up fir 5 seconds and goes off as soon as a relay de-energizes ( RL001A) .
    I checked the fan circuit witch mainly consists of a tip122 transistor , but every component around is good .
    Here is a schematic , and thanks in advance .
  • rievax_60
    • May 2012
    • 897
    • australia
    Re: Smps converter showing weird behavior !
    It looks like a welder. Not all of the schematic makes sense to me. U1PB is used as a timer. I would expect RL001A is turning on after the 5 seconds after mains is applied.
    There is a control path from U1PB to U1PA via QR2 and QR3 that also causes the temperature LED to turn off at the same time.
      Did you check all the DC regulated power supplies:The +15-HAUT, VCC-U2P, +13V?
      Also the +HT for the main power supply section.
      • paulstef
        • Dec 2013
        • 724
        As budm said, what are the voltages when RL001A is on?
        For the fan to run TR1 must be working, therefore the 8 power transistors to the right must be switching.
        First, when RL001A closes you should get +HT (unless D1P is faulty of course).
        The overtemp LED, is that the yellow LED to the left?
        What is connected to MES-TEMP? Should be an NTC (heats up, lowers resistance, U1PAs' output goes high, activates LED.)
        It looks (just had a quick look) to me that when the LED is on then:
        - Q8P npn is off
        - Q8P pnp is on (are those two complemenatry in the same package?)
        - pin 2 VFB of U2P gets some voltage from REF-5V, should then cut or limit pulses (or width) to OUT pin 6
        -U3P is a gate driver, should then disable its outputs, therefore power transistors are off
        - no output voltage from TR1.
        I would check first where the temperature sensor goes to, probably near the power transistors, check if any of them is shorted
        The temperature sensor or circuit could also be faulty, ideally you would measure input current while RL001 is on.
        • SM-Piyes90
          • Feb 2014
          • 120
          • Morocco
          Hi again everyone and thanks for your comments .
          As a response to your previous questions , i was wrong about the relay , actually the relay turns on as soon as the temp led goes off but the relay seems to energize very slowly and not instantly .
          I get 13 volts , 320 volts , but i don't know about the 15 v HAUT (?) (top left) , maybe used for IGBTs gate triggering ?
          Anyways the conversation is still open for more ideas guys .
          • SM-Piyes90
            • Feb 2014
            • 120
            • Morocco
            could the problem be the lm324 ?
              I do not know what is going on with BADCAPS site, I cannot download the picture of the diagram on post 1.
                • 31247
                it's not an attachement, he posted an inline image.
                do a right-click save-as on it.
                  I did and never have problem download the inline or attachment pictures, and now I get server error.
                  The picture used to show right on the page before because I did downloaded before.
                  Right now you only see small icon instead of the in line picture.
                  • SM-Piyes90
                    • Feb 2014
                    • 120
                    • Morocco
                    OK here it is :
                      So you do not have +15V-HAUT output which is the bootstrap for driving the upper set of the Q1~4.
                      • SM-Piyes90
                        • Feb 2014
                        • 120
                        • Morocco
                        I will check the 15 v section as well as the part related to the gate driver .
                        • dkneyle
                          Onkyo DX-V500 Laser Disc Player - weird SMPS fault
                          by dkneyle
                          This relic from a technology path that came to a dead end (but still has historical interest) was brought in with a dead SMPS, which is based around a MK1210 device. I got it going after a battle. It seems to have a strange design - if it's not getting feedback that the secondary is OK it cause the big FET to go into full conduction and overloads resulting in a blown fuse at best or something worse! I'm using a Dim Bulb Tester (70W/230V) which thankfully has saved the day a number of times whilst repairing.
                          Now, it loads a CD OK. The motor voltage output (which is built onto the SMPS...
                          02-01-2022, 02:08 AM
                        • lordmmx
                          Lenovo Legion 7 16ithg6 NM-D721 weird behavior
                          by lordmmx
                          Hello guys,
                          I have recently aquired Lenovo Legion 7 16ithg6 NM-D721, with weird issue. From time to time it will POST fine, boot to windows and work without a single issue. After restart however, it will not post again and then it will not post at all.
                          After messing around with bios (reflashing it), removing ssd, wifi, battery, etc, none of helped, I checked 5v and 3.3 coils and to my surprise, multimeter showed both coils hovering around 4V for 5V coil and 2V for 3.3v coil.
                          Thermal camera did not showed anything hot, but I'm sure something is either going...
                          06-30-2025, 03:54 PM
                        • Benchaton
                          Weird Charging behavior Aspire A517-51G
                          by Benchaton
                          Ok so, I've got a 17" Aspire 5, when I put it under any sort of medium high load it just stops charging and show blinks the status LEDs which I suppose mean it get's in power safety mode. Only notable things I can see being an issue are my CSME firmware which isn't the one from Acer because the Acer one was a vulnerable version relative to the current firmware I have installed (latest for KabyLake / KabyLake Refresh), the PC being only able to supply 0.05W to the battery on load spikes, and the slightly loose power inlet.
                          I mostly suspect the latter but it seamingly started happening...
                          07-30-2025, 04:43 PM
                        • RotVik
                          ASUS PRIME B550M-A AC weird behavior
                          by RotVik
                          Hello, I need a little help
                          I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
                          I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are...
                          05-01-2025, 04:59 PM
                        • dj-bobr
                          Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
                          by dj-bobr
                          I kindly ask for help with Thinkpad BIOS/ME repair.
                          Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
                          It worked fine until I tried to remove whitelist.
                          Steps taken:
                          - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
                          - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
                          03-05-2024, 04:28 AM
