ASUS PRIME B550M-A AC weird behavior
This topic has been answered.
  • RotVik
    Learning...
    • Feb 2016
    • 56
    • Mexico
    Hello, I need a little help
    I got an ASUS PRIME B550M-A AC Motherboard, bad BIOS, it wont display or boot, unless I did CMOS Restart first, after that It will boot but if I modified the configuration of the bios and saved it ,again no image
    I got the BIOS .CAP file from ASUS official support, used a tool called ASUS CAP to BIN, and programmed it to the IC, soldered to the board and got it to boot correctly, all the way to Windows, but now the CPU fan stays at full speed all the time and if I try to power it off with power button it will restart instead, and there are probably more issues I have not seen.
    Any help will be appreciated
    Original dump attached
    Thank you in advance, cheers!
    post moved...
  • Answer selected by RotVik at 05-09-2025, 10:03 AM.
    peste
    • 13217
    • ROMANIA
    Originally posted by RotVik
    Thank you your answer and you are right, I uploaded it wrong, here is the correct one I hope 32,768KB
    Cheers!
    try..
    • peste
      • 13217
      • ROMANIA
      post moved...
      the bios posted is longer...copy and post again...
      The bios chip must be unsoldered from the board before writing or reading..
      do not use the clip, you may have errors..if you do not have anything to unsolder it with,
      solder wires between the programmer and the bios chip..​
      • RotVik
        Learning...
        • Feb 2016
        • 56
        • Mexico
        Cheers!
        • peste
          • 13217
          • ROMANIA
          Cheers!
          try..
          • RotVik
            Learning...
            • Feb 2016
            • 56
            • Mexico
            try..
            Hello!, I can confirm that this BIOS is working, CPU Fan and QFan control are responding and not at full speed all the time anymore, also powering off is working correctly, will continue testing all the way to Windows and report if necessary.
            Thank you very much for your help!
            • Cyber Pck
              Will Zurdo
              • Mar 2024
              • 8
              • México
              Hello Your MotherBoard its ok? I have the same problem , can you say me if your motherboard work fine.
              • RotVik
                Learning...
                • Feb 2016
                • 56
                • Mexico
                Working OK so far as stated before
