It took a while to find this site and I hope I am posting this in the proper forum and that perhaps someone can help me.
I have an Antec SL400 psu (31/2 years old, so it is out of warranty) which did a slow burn on me a couple of months ago. Essentially it took a full ten hours for it to fry some wires. It managed to do this over a ten hour period. Anyway, all the +5vdc wires are burned (wires 4, 6, 19, 20 on the psu connector). Obviously, pins 4, 6, 19 & 20 on the motherboard side are also toast. The psu and motherboard connectors were fused together just enough, that I had to remove the the two as a single unit in order to separate them. When I pulled the motherboard connector off the board, the male portion of pin 4 came with it, stuck in its male pin.
After doing some lengthy research ( and coming upon this site) and reading the forums, I opened the psu and found at least 2 bad caps.
Seems most of the caps in this particular psu are of the Fuhjyyu brand. At least two of them have popped tops and the eloctrlytic is leaking out. The two huge Fuhjyyu caps have some goopy looking stuff at their bottoms, but can't really tell what it is.
I replaced the motherboard and psu (had a spare lying around). I purchased a new motherboard, swapped the cpu on to it and connected everything else up. I then powered the system up and everything seems to be ok.
So, the questions are:
1) were the shorted wires caused by the bad caps? (I am not an electrician or super-savvy pc expert),
2) would it be worthwhile to have this psu recapped?,
3) who would I contact about having it recapped?
and 4) any ideas where I might be able to get my motherboard repaired? It is a Gigabyte GA-7VAXP v1.0 socket A. Yeah, I know, socket As are out, but I like this board and I don't really want to upgrade to a newer board. Everything was working fine until the psu went bad. And still is.
