Q about CAPS on Enermax EG451P-V 431W
  • grss1982
    • Mar 2007
    • 225
    • Philippines
    Just bought this baby off a surplus store here in Cebu: Enermax EG451P-V 431W
    I opened it to check for any sings of cap failure and I was suddenly curious of the quality of the caps on this thing. The caps PCE-TUR (thats with a stylized P). Anybody heard of them? Are they any good (Yeah, I know the units an Enermax, which speaks volumes about the PSU's quality)?
    BTW, Searched google using "pce-tur +badcaps" and this was the result:
    http://www.google.com/search?num=100...ps&btnG=Search
    Interestingly it lead back here to badcaps.
    Anyways thanks in advance for any comments. :-)
    CPU: Sempron 2500+ / P4 2.8E / P4 2.6C / A64 x2 4000+ / E6420 / E8500 / i5-3470 / i7-3770
    GPU: TNT2 M64 / Radeon 9000 / MX 440-SE / 7300GT / Radeon 4670 / GTS 250 / Radeon 7950 / 660 Ti / GTS 450
    Main Driver: Intel i7 3770 | Asus P8H61-MX | MSI GTS 450 | 8GB of NO NAME DDR3 RAM (2x4GB) | 1TB SATA HDD (W.D. Blue) | ASUS DVD-RW | 22" HP Compaq LE2202x (1920x1080) | Seasonic S12II-620 PSU | Antec 300 | Windows 7 Ultimate with SP1
  • Spacedye69
    • Nov 2005
    • 698
    • US
    Re: Q about CAPS on Enermax EG451P-V 431W
    Search the forum. I dont think the caps are any good. I personaly have not seen any bad. Wher the H*** is Cebu?
    • grss1982
      • Mar 2007
      • 225
      • Philippines
      Cebu City, Philippines
      Thanks anyway Spacedye69. :-)
      • starfury1
        • May 2006
        • 1256
        well not considered good ones I think from opinions around here
        but seem to last OK in the Enermax psu.
        Found them listed here in the willawakes's "List of Bad Cap Manufacturers"
        So guess that says it all
        I suppose if you going to keep that psu for a while a recap wouldn't really hurt
        (also since its seconded hand, giving the pcb the once over (visual) won't hurt either, might have a dry joint or something)
        HTH
        Chees
        • gonzo0815
          • Feb 2006
          • 1600
          As long as the dual fan cooling system with it`s stupid hot air short back into the case is not altered, i think it should last remarkably long.
          So i think you can use it, if it is working fine.
          If caps are cheap and handy, it would not hurt to replace this caps with any long endurance low esr series of caps.
          There is no need for a bleeding edge low esr cap series.
            by momaka
            03-12-2025, 03:42 PM
          • eryjus
            by eryjus
            05-10-2023, 11:21 AM
          • Paxman_Swede
            by Paxman_Swede
            Hello!
            01-14-2025, 09:51 AM
          • captain150
            by captain150
            03-16-2025, 07:34 PM
          • Foetuss
            Gigabyte GA-6OXT :: caps question
            by Foetuss
            Good evening
            I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
            Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
            But I was also suprised about the bigger boys, which are 330µF 25V.
            Could it be they used 25V caps because they were cheaper / available at that time?...
            02-11-2025, 12:22 PM
