Blade BM7000s Satellite reciever PSU issue
  • TheDragon
    • Feb 2011
    • 69
    • UK - 230 v
    Hi all, Hope everyone is well. Need some help please.
    I have a Blade BM7000s SAT receiver that is determined to be a PSU issue.
    There is an issue that could happen known as the 'blinking red light'
    and a software/reset type solution works in many cases and if not
    it is determined as a PSU problem.
    Those who have had their PSU replaced or repaired then have working units again.
    Mine is the aforementioned PSU problem.
    I have uploaded 2 start up pics for starting purposes.
    I have replaced a 47uf 450v (large brown) and 100uf cap (marked red)as they were laying around but the problem is still there.
    I have tested the power output points and only the 5v (marked red) has power, with the ctl (marked red)also having 3v.
    The rest have nothing.
    As the front red led is blinking, there is a buzzing noise that is also present that syncs with the led flashes. Higher buzz with led on and lower when blinking off.
    I would welcome any advice or clues. Thank you
  • CapLeaker
    Leaking Member
    • 8184
    Re: Blade BM7000s Satellite reciever PSU issue
    I guess the standby voltage (5V) is o.k. if it is constant, or is it going on and off all the time? Did you check the diodes for short?
    • TheDragon
      • Feb 2011
      • 69
      • UK - 230 v
      Hi CapLeaker. Is that particular 5v for standby? It is constant at exactly 5v. Only the standby LED flashes.
      I have only tested the zener diodes. Though I'm not sure if I get correct readings in circuit.
      Would I need to check all diodes out of circuit?
      Thanks for looking into this.
      • CapLeaker
        Leaking Member
        • 8184
        Yeah, 5v is the standby and that is always on and goes to the main board. When you press the on button, the main board uses the control wire and tells the power supply to turn on all the other supply rails. So I am thinking there is a short on there some where on the power supply, or the main board has a problem. If you find a short in circuit, take it out or lift one leg and retest it again.
        You can force on any power supply that has standby voltage and a PSON pin with a 500 to 1k ohm resistor. Unplug the main board, and wire the standby to the control with a resistor. Once power is applied, the power supply should turn on and you should be able to measure all the voltage rails.
        • fingersd
          • 4
          Hi all, I'm hoping someone here may be able to help me regarding my 7000S.
          I've a completely different issue where the box boots fine but does not respond to either the remote or the front buttons.
          I've checked the PSU voltages and am concerned by one and wonder if anybody had tested there's during either a repair or PSU replacement.
          The board has outputs printed as follows:-
          Gnd my value 0.0v
          23v my value 25.0v
          12v my value 12.3v
          Gnd my value 0.0v
          7.0v my value 11.2v ***
          Gnd my value 0.0v
          5.0v my value 5.2v
          5.0v my value 5.2v
          Gnd my value 0.0v
          CT my value 3.3v (expected value unknown)
          12v my value 0.0v (Rail components missing on PSU so presumed OK)
          5.0v my value 5.5v
          What concern's me is the 7v rail operating 11.2v
          Can anybody confirm the true load voltage of the 7v rail.
          I'm just hoping someone can confirm these for me as I'm reluctant to purchase a new PSU in the off chance it may fix my fault.
          Thanks All, Dave.
            • 31051
            got any photo's?
            • CapLeaker
              Leaking Member
              • 8184
              did you reset the box or done a firmware upgrade?
              • R_J
                • 9551
                Trace the 7volt line on the power supply board, does it go to a regulator ic? or does it just go back to the diodes off the transformer.
                It could also be that there is no load on that line so look on the main board for an open component (fuse, fuse resistor) on that line.
                If you remove the power supply and post a clear picture of the bottom of the board that would help.
                • fingersd
                  • 4
                  appears to be to a pair of 31DF Diodes from the larger transformer
                  Yes, I've reset several times
                  Wouldnt 11.1v be a little high for a 7v rail with no load?
                  also the front buttons and remote appear to work from the rescue flash screen
                  I do wish i had a working unit for voltage comparison...
                  Thanks for your help guy's
                    • 31051
                    check the caps on the 7v line.
                    • fingersd
                      • 4
                      my thought exactly, there's 2, a 1000uf @ 25v plus a 470uf @ 16v (which i've already swapped out for a new components) and made no difference.
                      I've ordered a LM2596 adjustable step-down buck converter from ebay, I'll use that to regulate the 11.1v back down to 7v and see if that helps, it's not an ideal fix but will at least verify weather or not I need a new PSU or it's something else completely.
                      Cheers all.
                      • wizard13
                        Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                        by wizard13
                        I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                        I have checked the forum and the available documentation but could not find a solution specific to my issue.
                        • Brand & Model: Dynabook Satellite Pro C50D-B-100
                        • Part Number (P/N): PYU13E-00C00PFR
                        • Serial Number (S/N): 22028896H
                        • System Configuration (SC): A1PYU13E1127
                        • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                        • Power Input: DC 19V –
                        02-28-2025, 02:43 AM
                        Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook Specification for Upgrade or Repair
                        This specification for the Dynabook Satellite Pro Satellite Pro A50-E-209 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro A50-E-209 boardview and Satellite Pro A50-E-209 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        09-06-2024, 12:08 PM
                        Dynabook Satellite Pro Satellite Pro R40-D-11P Notebook Specification for Upgrade or Repair
                        This specification for the Dynabook Satellite Pro Satellite Pro R40-D-11P Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro R40-D-11P boardview and Satellite Pro R40-D-11P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                        Dynabook Satellite Pro Satellite Pro C50D-B-11Y Notebook Specification for Upgrade or Repair
                        This specification for the Dynabook Satellite Pro Satellite Pro C50D-B-11Y Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C50D-B-11Y boardview and Satellite Pro C50D-B-11Y schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                        09-07-2024, 05:50 AM
                        Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook Specification for Upgrade or Repair
                        This specification for the Dynabook Satellite Pro Satellite Pro C40-G-13E Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Satellite Pro C40-G-13E boardview and Satellite Pro C40-G-13E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
