ATX restart troubleshooting.
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Hi guys,
    Have a couple of PCs at the moment that are rebooting on site. So we have the usual situation where you dont know if it is the PSU or the board/processor.
    Most of the ATX troubleshooting documents and books that I've read suggest you get out the multimeter and test the 12v, 5v, and 3.3v rails to see if they are within spec, but this is far too simplistic when it comes to a PSU that is rebooting. Invariably the PSU will measure perfect 12v, 5v and 3.3v when you measure with the multimeter, but then will still randomly reboot. I understand that if the voltage goes out of spec for a second, whether trigger by the motherboard or PSU, then the Power_Good causes a reset, but you have no way of knowing what triggered this..
    The best option I've come up with at the moment is to use a junk mother board with the PSU and see if it reboots with a different motherboard/processor combination, but this is hardly scientific. Is there any better software/hardware way of checking this in place.
  • Agent24
    I see dead caps
    • Oct 2007
    • 4951
    • New Zealand
    Re: ATX restart troubleshooting.
    Are you sure it's the PSU and not Windows crashing with BSOD and autorestart is turned on?
    -David VanHorn
    • CapLeaker
      Leaking Member
      • 8127
      What you mean on site? Remote site or some office? If it is a remote site, try a UPS. I have a remote site that has computer freezing issues. OS is Linux no GUI, so should be rock solid one would think. After lots of troubleshooting it was a power quality issue. Installed an Online UPS ( conditions the power all the time) and no more problems.
        • 30985
        start the machine and go into the bios.
        then go to the system monitor section with the voltages listed.
        2 things of interest.
        1: does it sit there no problem without resetting.
        2: are the voltages stable or going up&down?
          master hoarder
          • May 2008
          • 12170
          • Bulgaria
          Exactly, this isn't all that useful.
          This is the kind of problem you have to investigate on site or bring the hardware home and test carefully. No other way. Best bet is inspect both the motherboard and PSU for bad caps and any other anomalities.
          • c_hegge
            • Sep 2009
            • 5219
            It's common for BIOS voltage readings to fluctuate, even if the voltage is actually stable going by a DMM. BIOS voltage readings should never be taken seriously or ever used in any form of troubleshooting.
            The first thing I would try is Agent24's suggestion of disabling the Automatic restart after system failure option and seeing if the symptom changes from a reboot to a BSOD.
            • jeewantha
              Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
              by jeewantha
              Dell Venue 10 Pro Restart at "rebooting system to make tpm2 settings in effect"
              I already write 2 bios files. For both files it is not on.
              Only light up top cover LED..
              Machine Model : Dell Venue 10 Pro 5055
              Service Tag: GWV0G32
              Board Model Number : SILVERTON MB
              14238-1
              WX4XD
              Please help to fix this problem. ...
              06-22-2024, 09:54 AM
            • shouri
              Dell latitude e5490 auto restart
              by shouri
              Hi guys, can someone help me?
              I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
              Board model is dm70 la-f401p rev:1.0 2017-09-20.
              At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
              After a few days test, is seems ok.
              Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
              12-10-2024, 09:27 PM
            • TR103
              by TR103
              - it keeps rebooting
              01-22-2025, 04:12 PM
            • plytek
              Samsung QE50Q60TA rebooting
              by plytek
              Hi all.
              I'm trying to fix my Samsung QE50Q60TA TV.
              IT's rebooting every few seconds.
              I have done some tests and it looks like it stops rebooting when I tape pin 46 (I thinks it's FB_1) on the ribbon tape that connects two boards atteched to screen, but nothing is visible, just backlight is solid and I can hear sound. Taping over other pins doesn't work.
              Have also soldered two pins on the motherboard to check if I can get an image on the rights side of the tv, but it keeps rebooting.
              Can anyone suggest what I can test and do to get it working again please?...
              02-08-2025, 06:02 AM
            • blues_spirit
              practical courses for troubleshooting pc motherboards
              by blues_spirit
              Hello from France,
              mon2 kindly advised me to post a thread to ask the question(s) I'm concerned about. I'm new to the forum and I'm looking for practical courses for troubleshooting pc motherboards especially laptops in Europe, if possible in France. I have been a computer network system administrator and a corrector of administration modules for automated programs under Unix. But I really miss the practical "ops" side of troubleshooting. So I would like to start from the beginning: 1.8V, 3.3V, 5V and 19V tests for example, etc...
              Do you think this is feasible for me? I...
              12-18-2022, 12:56 PM
