Hi
Pulled this from an Advent 3316 D1 Case
This PSU is good - tested (at least) with a PSU tester.
I have another Advent 3117 D1 Case - same PSU.
I found this PSU dead as well as the mobo.
Have seen comments in the forums here indicating 5VSB
problems with these PSUs (going to 12V) and killing
the mobo in the process.
So far...
I have tested for any shorts to ground, visual inspection
for bad caps - anything physically loose and the like.
Result - nothing immediately apparent.
Have replaced the PSU in failing 3117, no start up
Suspect - start up logic and/or VID logic in the CPU VRM
consistent with fault described in the forums.
The regulator is a Intersil ISL6556CBC. Replace reg?
Any other help, insight and advice greatly appreciated
So far...
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
