Dell 550w Power Supply Shorted Outputs
  • mmartell
    • Oct 2013
    • 3189
    Re: Dell 550w Power Supply Shorted Outputs
    For completeness
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
      03-31-2024, 02:12 PM
    • guizmo1967
      Dell Latitude 5501 LA-H181P shorted power rail
      by guizmo1967
      This is my problem:
      Laptop: Dell Latitude 5501
      Motherboard: EDC51 LA-H181P
      I have two power rails shorted to ground, +1.0V_PRIM and +3.3V_ALW_PCH. I removed solder on PJP302, +1.05VALWP (pad1) not shorted but +1.0V_PRIM (pad2) shorted.
      I also cleaned PJP38, pad1 not shorted, pad2 (+3.3V_ALW_PCH) shorted to ground.
      I measure the resistance of all the coils on the motherboard and they all were not shorted to ground except coil PL301 before I removed the solder on PJP302.
      I injected +1.05V - 2A...
      07-25-2023, 06:56 PM
    • reessi
      Acer Alienware Nitro 5 (GH51G LA-L181P Rev: 1C) & Dell Alienware M15 (GDP50 LA-k452P Rev:1) - Both Shorted PCH (SRKMA)!
      by reessi
      Hello:
      I have both these laptops that appeared to have the same fault so I thought I would have a go at replacing the PCH as something to learn, they both are using the same PCH.
      I started on the ACER:
      Up on connecting power no signs of life but current is consumed from the bench power supply and the PCH is hot.
      All the caps on the top of the PCH are showing 0 ohms and the 3.3v rail is shorted.
      I followed the videos from Sorin, Electronics Repair School on Youtube heating from the bottom to install. I practised on around 10 scrap...
      10-29-2024, 11:31 AM
    • TevasLT
      Dell G3 3779 CPU and GPU vcore shorted
      by TevasLT
      I have water damaged Dell G3 3779.
      Things I did. During visual inspection i noticed PL911 filter was blown up and caps around it PC901, PC902 .. all up to PU901 shorted, found culprit shorted cap on top side of board PC905, removed cap and short up to PU901 is gone. Shorted PJP901 to bypass filter for the moment.
      problem is CPU and GPU vcore coils are all shorted aswell and I don't know where can I safely inject power to test which component or driver is bad.
      PLA01 20.8 Ohm PLI01 3.8 Ohm, PLI02 3.8 Ohm, PLI03 3.8 Ohm, PLI04 3.8 Ohm...
      11-10-2022, 06:55 AM
