OMG... I sure hope I NEVER see this in a circuit I buy...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    I was browsing around how USB OTG power negotiation works and how it deals with wall wart "dumb" supplies (since these OTG need to both supply and sink) and ran across this fairly irrelevant webpage from Google:
    http://emproj.com/AC_DC_LM2575
    OUCH OUCH OUCH OUCH...
    Ok, back to our normally scheduled programming...
    • 31028
    Re: OMG... I sure hope I NEVER see this in a circuit I buy...
    lol - that's why they glue the case shut!!!
    • mariushm
      • May 2011
      • 3799
      Technically, it's a correct circuit (if you're nitpicking, i'd be concerned about the fuse being too large but whatever)...
      In real world, the lack of isolation makes this a killer circuit. For example, someone could plug his mp3 player in the charger and get killed due to metal contact in some faulty headphones or something like that.
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        Due to the lack of mains isolation, this circuit will never make it in a wall wart type supply.
        However, it's not like cheapo Chinese wallwarts are any better - if you took apart a transformer from one of those, what's keeping the mains away from your 5V-powered device is literally ONE LAYER of ridiculously thin yellow tape on the transformer, plus the enamel coating on the wires. Yet they work fine... for the most part. Occasionally they blow up, taking your device with them, and sometimes they even electrocute somebody. But as long as dumb, uninformed penny pinchers will keep buying them, the Chinese will keep making them.
        The wall warts that have (real) safety markings on them use much thicker insulation on the transformer, and have all the required input and output filtering components, making the supplies intrinsically safe under all operating conditions specified in the manual.
        A working TV? How boring!
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8701
          Yes, it was the isolation and the fact the first "preregulator" is linear, which would basically drop the efficiency...
          The cheap Chinese wall warts at least tried to isolate, this PSU doesn't even try, plus it has awful efficiency (I'd think that the more common capacitive reactance transformerless PSUs would be more 'efficient' than this circuit...)
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Don't the russians have different electrical wiring systems in their buildings? It might be OK for their buildings. Would never pass for manufacture/retail in the US, etc... though!
            Muh-soggy-knee
              • 31028
              no, electricity flows the same way in the ussr.
              it's just the car/truck drivers that seem to make the place look like a different planet!
              • ben7
                Capaholic
                • Jan 2011
                • 4059
                Well I'm talking about maybe different grounding etc... hey, I was just an idea/thought.
                The only way I'd see this as an acceptable circuit is if the WHOLE load on it is isolated (and isolated well enough) from any possible electrical contact with the outside world. Like, in an LED light bulb. They use high voltage buck converters, with no isolation transformer. It's acceptable because the LED is protected from any contact with the outside world.
                LOL
                Muh-soggy-knee
                  • 31028
                  https://www.youtube.com/watch?v=6syBu8KjcIQ
                    • 31028
                    https://www.youtube.com/watch?v=BAh6KoPfMkQ
                    • ben7
                      Capaholic
                      • Jan 2011
                      • 4059
                      I have a cheap one that won't output it's full rated load, the output voltage just drops. The transformer looks like it barely has any windings. Must not have insulation...! I'm thinking about putting some voltage (500V for starters, then maybe 1000V?) across it and testing the insulation. Might even put it across a MOT (Microwave Oven Transformer, outputs about 2000V at around 1000W) for a finale! xD
                      Not to keep this thread off topic, but this is a LOT funnier...
                      https://www.youtube.com/watch?v=gi-CgXWxO8M
                      Muh-soggy-knee
                        • 31028
                        fake, the bag normally inflates a hell of a lot faster and that car has something like 5 of them.
                        • Alimash
                          op amp circuit function?
                          by Alimash
                          I am repairing a ups which doesn't turn on ,it has the following ICs:
                          SG3525 used to drive inverter mosfets.
                          couple of uc3483, one for the power supply and another to drive a big mosfet at the output stage(i think the technique is called boost)
                          A LM358 and TL074 for control mechanism and of course the uController.
                          The SG3525 is shutting down every time the ups is turned on.
                          I want your help to know the function of LM358 and TL074 in the system.
                          I reverse engineered the LM358 circuit and i think that one of the block(A) is used for battery level...
                          07-31-2025, 07:45 AM
                        • Astonished
                          Fixing the Charge Circuit of the Batteries of the DC Motor
                          by Astonished
                          Hi friends of electronics
                          What you see in the video and pictures attached is the circuit for charging the batteries of a DC motor.
                          The problem is that this circuit cannot charge the batteries (3 1800mAH NiMH batteries) any more. When the circuit was OK, its green LEDs lit up one at a time to show that the batteries have charged more. But now that the circuit is flawed, LEDs light up as you see in the video and at the same time successive beeps are heard.
                          Please help me fix this circuit.
                          (the datasheet of the IC: https://pdf.datasheet.live/28...
                          01-28-2025, 06:24 AM
                        • rddube
                          Lenovo L490 Ram voltage circuit malfunction
                          by rddube
                          Hello friends,
                          Looking for some guidance here. The RAM voltage circuit on this motherboard keeps burning out PU301 which is a RT8231AGQW. Copy of the board with the burnt chip attached with some voltage measurements and copy of the schematics also included.
                          I think I've checked almost every component in the circuit, but when I change the RT8231, the laptop starts I have 1.2V on the inductor for about 10 seconds and then the RT8231 goes south and no more voltage on the inductor. All other voltages on the laptop are good, this is the only one conking out for a reason I...
                          07-15-2025, 04:41 PM
                        • Tarot Superstars
                          Short Circuit tester
                          by Tarot Superstars
                          Hello.
                          I have seen a short circuit tester made with 3 * 9V batteries, a voltage limiter component and a resistor connected to the probes of a multimeter.
                          The theory is that the meter becomes sensitive enough to read very low resistances and the lowest resistance to ground on a circuit is likely to be a short circuit in that area.
                          Link
                          The Amazing $1 Short Finder Upgraded! Convert ... - YouTube
                          https://www.youtube.com/watch?v=0eixDdCpiO4
                          My multimeter isn't normally sensitive to very small resistance, but when I put a 1 mega ohm resistor...
                          09-25-2023, 09:11 AM
                        • M1NEBLANK SHOW
                          MSI B250 Gaming M3 Short circuit in CPU power supply circuit
                          by M1NEBLANK SHOW
                          Hello. MSI B250 Gaming M3 board, short-circuit on the power supply. Found a problematic mosfet VQ1
                          (N-PK616BA_PDFN8-HF) soldered it out - short circuit is gone. I replaced VQ1 + VQ5 (N-PK632BA_PDFN8-HF). VQ1 was replaced with PK618. After starting attempt VQ1 is lit again. What can be the problem? In the driver?
                          Schematic and Boardview here
                          04-04-2025, 03:57 PM
